    [Plugin] AreaTextTag
    97 Posts 27 Posters 89.2k Views 27 Watching
      @jorgensen said:
      Hi TIG, Would it be possible to add the "generate faces via excel / csv" ? Maybe as an commercial plugin? Thanks 😄
      My current toolset's code XLS>geom/geom>XLS toolset is subject to an NDA etc... BUT if you want to continue this discussion through PMs then I might be able to come up with something to suit you/others... 😉
        Michaelv
        Thanks TIG, great plugin again.
        I don't use area but it could be useful for tagging surfaces with any text.
        So would it be possible to include a first choice in the settings yes or no as to "Automatic area". Yes would leave it as is, No would only put the area if <> is not erased or added, but if <> is erased then only the text is used (not automatically including the area).
        If you want me to code it in there I probably can. (it's not as obvious as I thought when I first looked, but it could be a good exercise for me)
          Michaelv
          I don't think you need to reinvent the wheel...
          There is my 'old' 2dText which already lets you stick a piece of text onto any surface AND has far more control over its 'format' [height, color, etc], and it is fully 'editable' later, with a right-click Edit option...
            Michaelv
            OK Thanks.
            Indeed. I never realized 2D text was working like that as I usually only use the 2D tools in the top view.
            Thanks for all.
              arqitect
              👍 Great job TIG,
              Just checked it, really useful now..
              Many thanks
              • brookefoxB Offline
                brookefox
                Thank you for sharing, TIG.
                Very, very useful for me...
                ~ Brooke
                  brookefox
                  Is there a way to add multiple faces to get one total area? I see I can handily do multiple individuals to get multiple results...
                  ~ Brooke
                    The areas of 'surfaces' made from faces with smoothed edges are reported as 'one' if the edges; visibility is 'off'.
                    You can of course report areas of selected/all tagged faces using a CSV file and the appropriate tool in the set...
                    Please read the notes...
                      brookefox
                      Well, thanks. I read your top notes, if that's what you mean (and the rest though less carefully). I see nothing about my question but don't doubt I may be missing it still.
                      Trying your instruction doesn't work for me. Please see this pic:
                      http://img831.imageshack.us/img831/2294/areaacres1.jpg
                      ~ Brooke
                        It's not so clear from your image what it is you are trying to tag...
                        If the boundary edges between two faces are 'smoothed' [and not visible] then the picked/selected area-tag reports the area of the 'surface' - i.e. the two combined faces - otherwise each face gets an individual area-tag.
                        If you want to show an area split into 'parcels' provided that the dividing lines don't split the face then the area-tag will refer to the underlying face. To stop the face splitting you could either leave a small gap in the line so there is no loop and therefore the face isn't split, or you could use a group to separate the 'dividing' lines from the face so that whilst the face might look like it was divided up it is not, OR draw two sets of faces - one set sub-divided and tagged individually and the other made as a copied group of faces on its own layer with dividing lines removed so there is one face to take the 'combined' tag... Also if you know the total area of a group of plots [found from a temporary outline say] you could add that to each tag's suffix - e.g. "Plot 1 <>\nof 12.3acres", "Plot 2 <>\nof 12.3acres" etc where each <> will contain the actual area, then if you adjust the dividing lines between plots an auto-recalc will adjust each plot's area but display the total consistently ?
                        You can export a CSV file listing areas-tags and any text you might associate with the area-tags to help identify them. The total is easily got for the area-tags in a column...
                          brookefox
                          Thank you. My problem was with the 'visibility off', by which you were not referring to hidden or not as I had assumed, but rather to smoothing aspects.
                          Work-arounds are easy enough.
                          To clarify what I'm trying to tag:
                          http://img16.imageshack.us/img16/3326/areaacres2n.jpg
                          ~ Brooke
                            If it's a single face it gets one area-tag - delete the intervening edges if it's all coplanar.
                            If it's a single surface that's not coplanar you must 'smooth' the common edges between faces [not just 'hide' them] - i.e. with view>hidden-geometry 'on' use Erase+Ctrl. Then with view>hidden-geometry 'off' place an area-tag on one of the surface's faces - now it'll report the 'surface area' - i.e. the combined areas of all of the connected faces...
                              castaway
                              Thank you for such a useful plugin, TIG.
                              I am having some trouble with accents though, take a look at the screenshot, it should read "HABITACIÓ 1 ..." "HABITACIÓ 2..." and "DISTRIBUÏDOR". Should I change any setting to adjust the text language or character set?
                                If you use those accented characters in 'plain' Text does it then work OK ?
                                The tool should simply concatenate the same text/areas into one string...
                                  castaway
                                  Do you mean creating a text label through Tools > Text? If so then yes, accents are displayed just fine.
                                    Here's v1.4 http://forums.sketchucation.com/viewtopic.php?p=373717#p373717
                                    The correct interpretation of UTF8 accented characters etc in customized area-tags has now been resolved.
                                      OK...
                                      You have the area-tags inside a locked-group.
                                      It [should***] only reports on tags in the active_context.
                                      So unlocking the group and editing it should then produce the CSV...
                                      ***BUT it fails - I am investigating why... 😕
                                      If I explode the group the area-tags export OK, BUT I notice the Unicode accented-character errors recurring - so I'll fix that at the same time...
                                      Watch for an update soon...
                                        castaway
                                        Hi again,
                                        I noticed the behaviour you described and was about to post about it when I saw your comment.
                                        One more thing about the exported cvs file if I may: as you can see I am using the following structure for the labels: label name, a new line and the area. The exported cvs outputs exactly this, in the form of "LABEL NAME\n<>", which does not seem very clean. What I can do is run a "find and replace" operation for "\n<>" in LibreOffice and delete it, but imo it would be cleaner if that information was not in the cvs exported file.
                                        Thanks for looking into this.
                                          castaway
                                          Wow, that was quick and effective. Now it works beautifully, thanks a lot!
                                          I am having some trouble exporting to cvs though, the only contents of the exported file is "LAYER,TEXT,PERIM,AREA,UNITS". Perhaps I am doing something wrong, but I think I have followed the instructions properly (save as and then export to cvs). I am attaching you the skp file used in my tests.
                                          areas_v4.skp
                                            Here's v1.5 http://forums.sketchucation.com/viewtopic.php?p=373717#p373717
                                            The CSV reporting is fixed - it now uses correctly accented UTF8 characters, and now reports Tags in the active context properly [so if they are inside a group edit that group before running the reporter].
                                            It now also strips all '\n' from reported 'names'
                                            It substitutes '/' if there is multi-line text, other than 'name\n<>' which becomes 'name' anyway, whereas 'name\nmore\n<>' becomes 'name / more' in the reported name.
                                            If the name includes text other than '<>' then the '<>' is always omitted - so 'name <>' becomes 'name '.
                                            However, a Tag with just a '<>' [or '<->'] is still reported as named '<>'.
                                            • 2 / 5
