    [Plugin] AreaTextTag
    97 Posts 27 Posters 89.2k Views 27 Watching
      Jorgensen
      Hi TIG
      Would it be possible to add the "generate faces via excel / csv" ? Maybe as an comercial plugin?
      Thanks ๐Ÿ˜„
        @jorgensen said:
        Hi TIG, Would it be possible to add the "generate faces via excel / csv" ? Maybe as an commercial plugin? Thanks ๐Ÿ˜„
        My current toolset's code XLS>geom/geom>XLS toolset is subject to an NDA etc... BUT if you want to continue this discussion through PMs then I might be able to come up with something to suit you/others... ๐Ÿ˜‰
          Michaelv
          Thanks TIG, great plugin again.
          I don't use area but it could be useful for tagging surfaces with any text.
          So would it be possible to include a first choice in the settings yes or no as to "Automatic area". Yes would leave it as is, No would only put the area if <> is not erased or added, but if <> is erased then only the text is used (not automatically including the area).
          If you want me to code it in there I probably can. (it's not as obvious as I thought when I first looked, but it could be a good exercise for me)
            Michaelv
            I don't think you need to reinvent the wheel...
            There is my 'old' 2dText which already lets you stick a piece of text onto any surface AND has far more control over its 'format' [height, color, etc], and it is fully 'editable' later, with a right-click Edit option...
              Michaelv
              OK Thanks.
              Indeed. I never realized 2D text was working like that as I usually only use the 2D tools in the top view.
              Thanks for all.
                arqitect
                ๐Ÿ‘ Great job TIG,
                Just checked it, really useful now..
                Many thanks
                • brookefoxB Offline
                  brookefox
                  Thank you for sharing, TIG.
                  Very, very useful for me...
                  ~ Brooke
                    brookefox
                    Is there a way to add multiple faces to get one total area? I see I can handily do multiple individuals to get multiple results...
                    ~ Brooke
                      The areas of 'surfaces' made from faces with smoothed edges are reported as 'one' if the edges; visibility is 'off'.
                      You can of course report areas of selected/all tagged faces using a CSV file and the appropriate tool in the set...
                      Please read the notes...
                        brookefox
                        Well, thanks. I read your top notes, if that's what you mean (and the rest though less carefully). I see nothing about my question but don't doubt I may be missing it still.
                        Trying your instruction doesn't work for me. Please see this pic:
                        http://img831.imageshack.us/img831/2294/areaacres1.jpg
                        ~ Brooke
                          It's not so clear from your image what it is you are trying to tag...
                          If the boundary edges between two faces are 'smoothed' [and not visible] then the picked/selected area-tag reports the area of the 'surface' - i.e. the two combined faces - otherwise each face gets an individual area-tag.
                          If you want to show an area split into 'parcels' provided that the dividing lines don't split the face then the area-tag will refer to the underlying face. To stop the face splitting you could either leave a small gap in the line so there is no loop and therefore the face isn't split, or you could use a group to separate the 'dividing' lines from the face so that whilst the face might look like it was divided up it is not, OR draw two sets of faces - one set sub-divided and tagged individually and the other made as a copied group of faces on its own layer with dividing lines removed so there is one face to take the 'combined' tag... Also if you know the total area of a group of plots [found from a temporary outline say] you could add that to each tag's suffix - e.g. "Plot 1 <>\nof 12.3acres", "Plot 2 <>\nof 12.3acres" etc where each <> will contain the actual area, then if you adjust the dividing lines between plots an auto-recalc will adjust each plot's area but display the total consistently ?
                          You can export a CSV file listing areas-tags and any text you might associate with the area-tags to help identify them. The total is easily got for the area-tags in a column...
                            brookefox
                            Thank you. My problem was with the 'visibility off', by which you were not referring to hidden or not as I had assumed, but rather to smoothing aspects.
                            Work-arounds are easy enough.
                            To clarify what I'm trying to tag:
                            http://img16.imageshack.us/img16/3326/areaacres2n.jpg
                            ~ Brooke
                              If it's a single face it gets one area-tag - delete the intervening edges if it's all coplanar.
                              If it's a single surface that's not coplanar you must 'smooth' the common edges between faces [not just 'hide' them] - i.e. with view>hidden-geometry 'on' use Erase+Ctrl. Then with view>hidden-geometry 'off' place an area-tag on one of the surface's faces - now it'll report the 'surface area' - i.e. the combined areas of all of the connected faces...
                                castaway
                                Thank you for such a useful plugin, TIG.
                                I am having some trouble with accents though, take a look at the screenshot, it should read "HABITACIร“ 1 ..." "HABITACIร“ 2..." and "DISTRIBUรDOR". Should I change any setting to adjust the text language or character set?
                                  If you use those accented characters in 'plain' Text does it then work OK ?
                                  The tool should simply concatenate the same text/areas into one string...
                                  ๐Ÿ˜•
                                    castaway
                                    Do you mean creating a text label through Tools > Text? If so then yes, accents are displayed just fine.
                                      Here's v1.4 http://forums.sketchucation.com/viewtopic.php?p=373717#p373717
                                      The correct interpretation of UTF8 accented characters etc in customized area-tags has now been resolved.
                                      โ˜€
                                        OK...
                                        You have the area-tags inside a locked-group.
                                        It [should***] only reports on tags in the active_context.
                                        So unlocking the group and editing it should then produce the CSV...
                                        ***BUT it fails - I am investigating why... ๐Ÿ˜•
                                        If I explode the group the area-tags export OK, BUT I notice the Unicode accented-character errors recurring - so I'll fix that at the same time...
                                        Watch for an update soon...
                                          castaway
                                          Hi again,
                                          I noticed the behaviour you described and was about to post about it when I saw your comment.
                                          One more thing about the exported cvs file if I may: as you can see I am using the following structure for the labels: label name, a new line and the area. The exported cvs outputs exactly this, in the form of "LABEL NAME\n<>", which does not seem very clean. What I can do is run a "find and replace" operation for "\n<>" in LibreOffice and delete it, but imo it would be cleaner if that information was not in the cvs exported file.
                                          Thanks for looking into this.
                                            castaway
                                            โ˜€
                                            Wow, that was quick and effective. Now it works beautifully, thanks a lot!
                                            I am having some trouble exporting to cvs though, the only contents of the exported file is "LAYER,TEXT,PERIM,AREA,UNITS". Perhaps I am doing something wrong, but I think I have followed the instructions properly (save as and then export to cvs). I am attaching you the skp file used in my tests.
                                            areas_v4.skp
                                            • 2 / 5
