    [Plugin] Edge Tools
    211 Posts 74 Posters 283.4k Views 74 Watching
    • xiombargX Offline
      xiombarg
      Man, I am just amazed. Your plugins are the zen that I've wished Sketchup had. Great work, seriously.
        rock1
        on dividing a face with lines is there a way that the divisions go at a fixed distance. for. e.g. we copy one line at 1m and repeat copy it, we press 6x to make 6 copies for it. the same thing i want to do with this plugin, hw is this possible ❓
        Signature removed by SCF Admin
          By using the VCB - similar to how you use the native Move tool.
            chango70
            Very useful, thank you!
            • jeff hammondJ Offline
              jeez 😲 .. i missed this plugin too.. some awesome stuff in there!
              thanks.
              re: this post:
              http://forums.sketchucation.com/viewtopic.php?p=365178#p365178
              i think what i'd like for it to do might complicate the 'simplify curves' option.. it works great now in many cases (setting to 0 which joins all applicable edges)
              what i'd like to be able to do is have it weld everything except there would be some sort of filter(?) in place that won't weld anything less than a certain angle... like if the angle between two edges is sharper than, say, 1 radian then the edges won't be joined..
              just an idea and one that i personally wouldn't use very often (and i imagine i'd use it more than most people.. maybe once or twice during a heavy modeling session..)
              if you like the idea then go for it.. otherwise, don't sweat it πŸ˜„
              • H Offline
                hhdk
                So useful! it's also perfect for solving line problems that occurs on autocad imports.
                • guanjinG Offline
                  guanjin
                  The first tool, if the offset of the linear, such as CAD
                  CAD.gifPowerful, can change? Perhaps my request is too much! ! πŸ˜„
                    That you can do with the native Move - using the copy array modifier.
                    • guanjinG Offline
                      guanjin
                      Not quite understand,Can only offset the surface line,As above, and CAD functions.I'm just too greedy,Tool itself is very strong
                        SketchUp's Move Tool
                        http://support.google.com/sketchup/bin/answer.py?hl=en&answer=94867
                        You just need to do a linear array to do what you showed in the CAD animation.
                        • guanjinG Offline
                          guanjin
                          Thank you thom thom
                          This is very complex, πŸ˜„ πŸ˜„
                          • brookefoxB Offline
                            brookefox
                            Please see the image for a use of 'face divide' for quickly uniformly hatching a face. It works very well for this as I understand it: click an edge, move to the farthest edge to check distance (and alternatively input a distance), then divide by a number which will result in the size hatch you want.
                            Thank you.
                            FORGET THIS: Any chance for a mod so it can be used like copy multiple, thereby saving a step, or is this already possible? I see up above that you say it is... I guess your way only takes two steps, just like copy multiple. So, yeah, forget it.edge tools -1.JPG
                            With this hatch roads to be abandoned are indicated. The potential transparency of such edge hatches reads much better than textures, IMO. Yes, I agree, it is surely not the best way to do this, creating as it does 500 or so new edges.edge tools -2.JPG
                            ~ Brooke
                            • F Offline
                              function
                              Hi, I updated to ttLib 2.6 and the new edge tool and it no longer gives me thr heads up display or red circles 😞
                                Any errors in the Ruby Console?
                                Are you sure you installed the updates correctly?
                                • F Offline
                                  function
                                  Ill have to look when I get home. I installed fredos multi directory at the time, and since it wasnt working I installed it back to root plug folder.. Maybe it is the division of the lib in different directories
                                    rv1974
                                    I'm really missing 'divide face' tool working with multiple (connected) edges. πŸ˜’
                                      Wouldn't Tools on Surface do what you want there?
                                        rv1974
                                        doh! I forgot TOS offset works non-curves. thanks!
                                          rv1974
                                          I re-found why TOS offset is no good for me. Can one make it to extend the resulted curve to the face border?
                                            It is doing what it should do and it it mathematically correct. You can extend those line segments with the Line tool. You could also try using Matt666's ExtendTool.
                                            • 11
                                            • 6 / 11
