    [Plugin] Edge Tools
    211 Posts 74 Posters 323.4k Views 74 Watching
    • jeff hammondJ
      jeez 😲 .. i missed this plugin too.. some awesome stuff in there!
      thanks.
      re: this post:
      404 Not Found
      (forums.sketchucation.com)
      i think what i'd like for it to do might complicate the 'simplify curves' option.. it works great now in many cases (setting to 0 which joins all applicable edges)
      what i'd like to be able to do is have it weld everything except there would be some sort of filter(?) in place that won't weld anything less than a certain angle... like if the angle between two edges is sharper than, say, 1 radian then the edges won't be joined..
      just an idea and one that i personally wouldn't use very often (and i imagine i'd use it more than most people.. maybe once or twice during a heavy modeling session..)
      if you like the idea then go for it.. otherwise, don't sweat it πŸ˜„
      • H
        hhdk
        So useful! it's also perfect for solving line problems that occurs on autocad imports.
        • guanjinG
          guanjin
          The first tool, if the offset of the linear, such as CAD
          CAD.gifPowerful, can change? Perhaps my request is too much! ! πŸ˜„
            That you can do with the native Move - using the copy array modifier.
            • guanjinG
              guanjin
              Not quite understand,Can only offset the surface line,As above, and CAD functions.I'm just too greedy,Tool itself is very strong
                SketchUp's Move Tool
                http://support.google.com/sketchup/bin/answer.py?hl=en&answer=94867
                You just need to do a linear array to do what you showed in the CAD animation.
                • guanjinG
                  guanjin
                  Thank you thom thom
                  This is very complex, πŸ˜„ πŸ˜„
                  • brookefoxB
                    brookefox
                    Please see the image for a use of 'face divide' for quickly uniformly hatching a face. It works very well for this as I understand it: click an edge, move to the farthest edge to check distance (and alternatively input a distance), then divide by a number which will result in the size hatch you want.
                    Thank you.
                    FORGET THIS: Any chance for a mod so it can be used like copy multiple, thereby saving a step, or is this already possible? I see up above that you say it is... I guess your way only takes two steps, just like copy multiple. So, yeah, forget it.edge tools -1.JPG
                    With this hatch roads to be abandoned are indicated. The potential transparency of such edge hatches reads much better than textures, IMO. Yes, I agree, it is surely not the best way to do this, creating as it does 500 or so new edges.edge tools -2.JPG
                    ~ Brooke
                    • F
                      function
                      Hi, I updated to ttLib 2.6 and the new edge tool and it no longer gives me thr heads up display or red circles 😞
                        Any errors in the Ruby Console?
                        Are you sure you installed the updates correctly?
                        • F
                          function
                          Ill have to look when I get home. I installed fredos multi directory at the time, and since it wasnt working I installed it back to root plug folder.. Maybe it is the division of the lib in different directories
                            rv1974
                            I'm really missing 'divide face' tool working with multiple (connected) edges. πŸ˜’
                              Wouldn't Tools on Surface do what you want there?
                                rv1974
                                doh! I forgot TOS offset works non-curves. thanks!
                                  rv1974
                                  I re-found why TOS offset is no good for me. Can one make it to extend the resulted curve to the face border?
                                    It is doing what it should do and it it mathematically correct. You can extend those line segments with the Line tool. You could also try using Matt666's ExtendTool.
                                      rv1974
                                      Yes captain I realize that it's undoubtedly correct behavior. Initially I just asked Thomthom to extend his 'divide tool' (by accepting multiple edges)
                                        The key concept of the Divide Tool was that you didn't pre-pick edges. It was to allow you to quickly pick a reference edge and make a split. Multiple edges would be a completely different tool.
                                          rv1974
                                          ..would be completely different amazingtool πŸ˜‰
                                            Put file In V6 πŸ˜‰
                                            It's better for everybody! πŸ˜„
                                            An image ist sufficient! πŸ€“
                                            • 11
                                            • 7 / 11
