    [Plugin] Edge Tools
    211 Posts 74 Posters 316.8k Views 74 Watching
      πŸ‘
      • EarthMoverE Offline
        EarthMover
        Nice update. Thanks Thomthom!! πŸ‘
        Content Creator at Skapeup
        • mitcorbM Offline
          mitcorb
          Hi, ThomThom:
          Thank you again for this excellent tool. And thank you for the 2.0.4 update. Will you be inserting info on the update in the first post?
            hm.. was just a minor update, really needed?
              MartinK
              Thanks for the plugin. I'm getting ready to try the simplify curves routine on a large number of contours. As always, these plugins you and others generously make available are great time savers, and I appreciate your efforts. Thanks again. πŸ‘
              • xiombargX Offline
                xiombarg
                Man, I am just amazed. Your plugins are the zen that I've wished Sketchup had. Great work, seriously.
                  rock1
                  on dividing a face with lines is there a way that the divisions go at a fixed distance. for. e.g. we copy one line at 1m and repeat copy it, we press 6x to make 6 copies for it. the same thing i want to do with this plugin, hw is this possible ❓
                  Signature removed by SCF Admin
                    By using the VCB - similar to how you use the native Move tool.
                      chango70
                      Very useful, thank you!
                      • jeff hammondJ Offline
                        jeez 😲 .. i missed this plugin too.. some awesome stuff in there!
                        thanks.
                        re: this post:
                        404 Not Found
                        (forums.sketchucation.com)
                        i think what i'd like for it to do might complicate the 'simplify curves' option.. it works great now in many cases (setting to 0 which joins all applicable edges)
                        what i'd like to be able to do is have it weld everything except there would be some sort of filter(?) in place that won't weld anything less than a certain angle... like if the angle between two edges is sharper than, say, 1 radian then the edges won't be joined..
                        just an idea and one that i personally wouldn't use very often (and i imagine i'd use it more than most people.. maybe once or twice during a heavy modeling session..)
                        if you like the idea then go for it.. otherwise, don't sweat it πŸ˜„
                        • H Offline
                          hhdk
                          So useful! it's also perfect for solving line problems that occurs on autocad imports.
                          • guanjinG Offline
                            guanjin
                            The first tool, if the offset of the linear, such as CAD
                            CAD.gifPowerful, can change? Perhaps my request is too much! ! πŸ˜„
                              That you can do with the native Move - using the copy array modifier.
                              • guanjinG Offline
                                guanjin
                                Not quite understand,Can only offset the surface line,As above, and CAD functions.I'm just too greedy,Tool itself is very strong
                                  SketchUp's Move Tool
                                  http://support.google.com/sketchup/bin/answer.py?hl=en&answer=94867
                                  You just need to do a linear array to do what you showed in the CAD animation.
                                  • guanjinG Offline
                                    guanjin
                                    Thank you thom thom
                                    This is very complex, πŸ˜„ πŸ˜„
                                    • brookefoxB Offline
                                      brookefox
                                      Please see the image for a use of 'face divide' for quickly uniformly hatching a face. It works very well for this as I understand it: click an edge, move to the farthest edge to check distance (and alternatively input a distance), then divide by a number which will result in the size hatch you want.
                                      Thank you.
                                      FORGET THIS: Any chance for a mod so it can be used like copy multiple, thereby saving a step, or is this already possible? I see up above that you say it is... I guess your way only takes two steps, just like copy multiple. So, yeah, forget it.edge tools -1.JPG
                                      With this hatch roads to be abandoned are indicated. The potential transparency of such edge hatches reads much better than textures, IMO. Yes, I agree, it is surely not the best way to do this, creating as it does 500 or so new edges.edge tools -2.JPG
                                      ~ Brooke
                                      • F Offline
                                        function
                                        Hi, I updated to ttLib 2.6 and the new edge tool and it no longer gives me thr heads up display or red circles 😞
                                          Any errors in the Ruby Console?
                                          Are you sure you installed the updates correctly?
                                          • F Offline
                                            function
                                            Ill have to look when I get home. I installed fredos multi directory at the time, and since it wasnt working I installed it back to root plug folder.. Maybe it is the division of the lib in different directories
                                            • 11
                                            • 7 / 11
