    [Plugin Library] LibFredo6 - v15.8b - 12 Jan 26
    2.2k Posts 571 Posters 4.1m Views 573 Watching
      @wt00320371 said:
      I can't download?
      What file?
      What problem/error messages?
      More information, please...
      πŸ˜•
        supercylon
        I think that I've installed LibFredo6 v.4.3 and the Round corner plugins correctly. But when I launch SketchUp (I'm using Version 7 on Mac OS 10.4.11) is get this error message: Error Loading File LibFredo6.rb
        can't convert nil into String
        What does this mean and how can I fix it? Can someone assist me.
          supercylon
          I'm running SketchUp 7 on Mac OS 10.4.11. I've downloaded and installed both LibFredo6 v4.3 and Round Corner plugin and both are not working. When I start up SU7 I get the error message: "Error Loading File LibFredo6.rb
          can't convert nil into String". I have no idea what this means. Can someone help?
          Thanks a million!
          Here is a screen shot of my plugins folder
          My plugins folder
          • fredo6F Offline
            @supercylon
            Just in case, can you type ENV["TEMP"] in the Ruby Console and tell me what you see.
              I use
              tempdir=ENV["TEMP"] ### it's a PC == 'TEMP' or 'TMP' tempdir=ENV["TMPDIR"] if not tempdir ### it's a Mac
              πŸ˜•
                This is what I use to detect temp path:
                TEMP_PATH = File.expand_path( ENV['TMPDIR'] || ENV['TMP'] || ENV['TEMP'] ).freeze
                • fredo6F Offline
                  @tig said:
                  I use
                  πŸ˜•
                  TIG,
                  Actually, my mistake. Yes indeed, I use TMPDIR for Mac environment (or /tmp which may be more secure)
                  @supercylon
                  Can you type ENV["TMPDIR"] in the Ruby console
                  Fred
                    supercylon
                    @supercylon
                    Hello Fredo,
                    Thanks for your assistance. I did what you asked and here is a screenshot of the result.
                    ![Results of ENV["TEMP"] in Ruby Console](/uploads/imported_attachments/iUOu_Picture2.png "Results of ENV["TEMP"] in Ruby Console")
                    Thanks Supercylon
                      supercylon
                      @tig said:
                      I use
                      πŸ˜•
                      TIG,
                      @supercylon
                      Fred
                      I didn't notice this message, here is the screen shot of the result of your second request.
                      Thanks,
                      Supercylon
                        And ENV['TMP'] ?
                          supercylon
                          @supercylon
                          Can you try withe attached file to see if your error disappear and SU starts OK.
                          [attachment=0:2f69w8lx]<!-- ia0 -->LibFredo6.rb<!-- ia0 -->[/attachment:2f69w8lx]
                          Fredo,
                          Thank you!Thank you! It works!
                          Supercylon
                          • fredo6F Offline
                            Supercylon
                            I will release the change tomorrow as v4.3c
                            It is strange however that on your Mac, the TMPDIR Environment variable is not defined.
                            @TIG, Thomthom: I just use /tmp when TMPDIR is not defined.
                            • fredo6F Offline
                              @supercylon
                              EDIT: file removed. Now part of the release 4.3c, 31 Jan 12
                                baranya
                                Under Ubuntu makes SU to crach on startup
                                • fredo6F Offline
                                  It's difficult for me to diagnose on this platform which I don't have.
                                  I think there are a few users running Sketchup on Linux flavors, and they may help you to troubleshoot.
                                  • Y Offline
                                    yogaseeker
                                    I ran into some trouble when I placed this plugin in the SU plugin folder. I thought this solution might help others.
                                    "LibFredo6 4.3c - 31 Jan 12" is the name of the folder that I unzipped and I placed in my plugins folder. But that didn't work. You have to drag the contents of the "LibFredo6 4.3c - 31 Jan 12" folder (LIBFREDO6_Dir_43 and LibFredo6) out of that folder and put it in the plugins folder.
                                    THanks so much for this wonderful plugin!!!
                                      mingjae
                                      Hello Mr.LibFredo..
                                      I have a diifficulty to install curviloft using libfredo in my SU8,
                                      it wont load and something wrong with the fredo, this is the picture :
                                      http://img594.imageshack.us/img594/7065/99471562.jpg
                                      I dont have lib tranductor.rb in Libfredo6 package neither on curviloft,
                                      how to solve this Mr?
                                      I also trying to copy the lib_tranductor.rb in my SU7 to SU8 plugins folder but it always crash after copying it... 😒
                                      • fredo6F Offline
                                        I would suggest you redo a clean installation and make sure you overwrite all existing files.
                                        Just in case, can you type in the Ruby Console and report what you get:
                                        Sketchup.find_support_file('LibTraductor.rb', "Plugins")
                                          mingjae
                                          Hi, thank for your reply
                                          my SU8 in plugin folder have not installed by LibFredo and curviloft before,
                                          so I just put all unzipped libfredo and curviloft in my plugins folder,
                                          after I redo to overwrite it, it result the same, it not load "lib traductor.rb
                                          and here is I copy paste after I enter it on ruby console:
                                          "Sketchup.find_support_file('LibTraductor.rb', "Plugins")
                                          C:/Program Files/Google/Plugins/LibTraductor.rb"
                                          edit: perhaps the lib traductor.rb crashes in the Google/Plugins folder?
                                          I copy the "Plugins" folder from my friend notebooks and place it there.
                                          I cut the lib traductor there and place it in SU8 plugins folder and the curviloft success to load...
                                          but, where can I get "lib traductor.rb", there's no in lib fredo zip and curviloft zipped file installer right?
                                          • fredo6F Offline
                                            Actually you do not need LibTraductor.rb for Curviloft (it's only for backward compatibility that it is checked).
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 108
                                            • 109
                                            • 13 / 109
