    1.3k Posts 299 Posters 2.9m Views 297 Watching
      mac1
      @jgb said:
      @mac1 said:
      I get the two lines also and is the reason I used the skinning option and get the same result as Fredo. BTW I measure 0.5 in apart and looks like by design ???
      The 2 lines you refer to are the inner and outer edges of a very large 1/2 inch thick panel which is part of a fairing made of several adjoining panels. The 1st master panel itself (outer skin) was originally formed by C-Loft, then thickened with JPP to 1/2 inch. It formed all 4 edges. All the panels are rectangular (4 distinct corners) with that similar pronounced curve.
      Then I selected 1 edge to become the curve control for this adjacent panel, which had a different overall shape at the top, but shared an edge. I formed that panel the same way, but had to modify it for the design. In doing so, I lost the 2 side edge faces and 1 top edge face (expected). I then closed the top 2 corners. One edge immediately skinned, but this edge and the top did not. I expected the top not to skin as it had a slightly irregular profile, but this edge should have auto skinned because it was skinned prior to the mod, and the top end was redrawn. I used C-Loft to re-skin the top edge (worked 1st time) but this edge persistently refused. I have since manually skinned it in the model.
      If you want I can post the complete panel here, in its present state, but I doubt it will contribute anything to this discussion.
      Please do.
      I think we are working at cross purpose withoout seeing the whole picture ❓ ❓
        mac1
        C-Loft Problem.jpgIs this some what the goal?
        As I noted the 1/2" face is not flat so you cannot push pull a soften or curved face. TIGs extrude tools maybe better for this problem but need to see the total issue.
        This was done loft by spline but just one side of the surface. To get the thickness it will require two steps and then reconnect the ends. ❓ ❓ ❓ ❓
        • jgbJ Offline
          jgb
          Mac1; You are very close to the actual panel, except for a curve that you could not know of.
          Please note; I am not looking for a solution. I have it. The original post was for Fredo to investigate why I get a black face but an empty group.
          I've attached copies of the actual problem panel and the adjacent panel with notes. A 2nd copy has the problem face deleted and a C-Loft empty group attached.
          FYI, these panels are carbon fiber composite honeycomb sandwich, 1/2 in thick. At this point in the design development, the stiffeners and structural attachments are not yet incorporated. To all you aero engineers, these panels are NOT primary structure, and are subject only to aerodynamic loads. Even so, they are stronger than they have to be, considering the planned stiffeners/internal structure that attaches them to the primary a/c structure. As such, they are considered fairings.
          Copies of the full panels.
          jgb
          • fredo6F Offline
            I will have a look at it and come back
            PS: do not forget that Skin works on coons, that is 3 or 4 profiles in loop
            • jgbJ Offline
              jgb
              ❓ ❓ ❓ ❓ ❓ In Canada a coon is a smart thieving mammal. 🤣 (Racoon)
              jgb
                  mac1
                  Note jpg of strut deleted by poster.12/28-2011 2240 MST
                  FYI some GY70 near zero CTE tapered and curved strut. In my experience based aeroshell and fairing two differnt designs. Spent many hours on antenna range with aeroshell to reduce radar cross section so that at post planetary entry and jettison landing radar did not think it was a big target.
                  Glad you have solution I still get same results face forms ok.
                  Gday
                  • jgbJ Offline
                    jgb
                    Mac1; that was an interesting note regarding aeroshells RCS and landing radar. Would you not have jettisoned the aeroshell high enough up so it would not be a consideration on landing?
                    And my term "aeroshell" applies to the outer fuselage of my big freighter, for lack of a better term.
                    It completely surrounds the main fuselage primary structure and is subject to aerodynamic loads only. It forms a shell or fairing around various systems such as landing gear, aux power, etc. from nose to tail.
                    I've posted a picture of it to explain a bit of what it is about. I will not get into details for proprietary reasons. There is a lot not shown in the pic, as most details such as landing gear, support structure, systems etc are detailed on other drawings. This pic is of the master moldline and covers the main structure and secondary structures, aeroshell, fairings, etc. Otherwise the SU model gets too large to handle. I have about 20 such sub system drawings.
                    Think of this airplane as an Antonov AN124 on steroids. It follows that planes general configuration, but is much larger. MGTOW is about 1,700,000 lbs. Max payload is 400 tons plus fuel for 1,000 miles.
                    Cargo handling is optimized for standard shipping containers, stacked on the cargo deck 3 wide by 2 high by 8 along deck for 20ft ctrs or 4 x 40ft ctrs. There are 4 x 15 ton hoists on 2 overhead gantries to load/unload. And the cargo floor is completely removable for supersized loads. In fact it can swallow a complete Airbus A380 fuselage or a Space Shuttle fuel tank with room to spare.
                    Construction is primarily carbon fibre for about 95% of the airframe. The fabrication methodology is proprietary and novel. The main fuselage tube is fabricated in one piece about 40 feet diameter and 280 feet long. The nose cone and aft cargo doors are simply cut out and finished to be mated back. The upper fuselage is fabricated the same way, cut in 2 longitudinally and serves 2 airplanes. Each half is then cut in 2 again forming the fwd and aft upper fuselages, which are mated on top of the cargo fuselage.
                    The aeroshell is more or less conventional panel layup. Carbon fibre skins with a honeycomb or foam core.
                    Anyway, this forum is not the place to discuss my design so here I quit.BMF400b
                    jgb
                      rjjvirusx
                        martosurf
                        VERY NICE PLUG ,..... SMOUUUUVEE SMOUUUVEEE 😄 ANF GROUUVE 😄
                        THANKS 😄 😎
                          michlja
                          Hi! Thanks Fredo! This will make all the difference for me. Just a little hiccup...
                          I installed Curviloft 1.2c jsut now, and upon launch sketchup gives me the following errors:
                          Error Loading File __loader.rb
                          uninitialized constant TraductorError Loading File bootstrap_Curviloft.rb
                          uninitialized constant Curviloft::T6Error Loading File CurviloftAlgo.rb
                          uninitialized constant Curviloft::T6Error Loading File CurviloftCurveMover.rb
                          uninitialized constant Curviloft::T6Error Loading File CurviloftPalette.rb
                          uninitialized constant Curviloft::T6Error Loading File CurviloftTool.rb
                          I installed LibFredo6 immediately before, and that seems to have taken just fine.
                          I am running sketchup pro 7 on OS X 10.6.8 (snowleopard)
                            Looks like you installed Curviloft incorrectly. I expect you probably copied the contents of the folder called CURVILOFT_Dir_12 out into the Plugins folder rather than leaving them in the folder as they are supposed to be.
                              michlja
                              looks like that corrected it! Maybe I've been installing the others improperly as well... though they work LOL
                              here is the contents of the plugins folder:
                              __loader.rb
                              bezierspline.rb
                              BZ_Dir_14
                              Curviloft_donation.html
                              Curviloft_ES.lang
                              Curviloft_FR.lang
                              Curviloft.plugin
                              CurviloftAlgo.rb
                              CurviloftAlong.rb
                              CurviloftEdition.rb
                              CurviloftGeometry.rb
                              CurviloftMorph.rb
                              CurviloftPalette.rb
                              CurviloftSkinning.rb
                              CurviloftSpline.rb
                              CurviloftTool.rb
                              DEFPARAM_Dir
                              Examples
                              examples.rb
                              FredoTools__ConstructFaceNormal.rb
                              FredoTools__CountFacesBySides.rb
                              FredoTools__CurviShear.rb
                              FredoTools__MarkVertices.rb
                              FredoTools__RemoveLonelyVertices.rb
                              FredoTools__ReportLabelArea.rb
                              FredoTools__RevertCurve.rb
                              FredoTools_ES.lang
                              FredoTools_FR.lang
                              FredoTools.plugin
                              FredoTools.rb
                              IMAGES_Standard
                              jointpushpull.rb
                              JPP_Dir_20
                              LIBFREDO6_Dir_43
                              LibFredo6.rb
                              LibTraductor.rb
                              ShaderlightLoader.rbs
                              ShaderlightRubyExtension.bundle
                              Utilities
                              utilities.rb
                                @michlja said:
                                __loader.rb
                                bezierspline.rb
                                BZ_Dir_14
                                Curviloft_ES.lang
                                Curviloft_FR.lang
                                Curviloft.plugin
                                CurviloftAlgo.rb
                                CurviloftAlong.rb
                                CurviloftEdition.rb
                                CurviloftMorph.rb
                                CurviloftPalette.rb
                                CurviloftSpline.rb
                                CurviloftTool.rb
                                DEFPARAM_Dir
                                Examples
                                examples.rb
                                FredoTools_ES.lang
                                FredoTools_FR.lang
                                FredoTools.plugin
                                FredoTools.rb
                                IMAGES_Standard
                                jointpushpull.rb
                                JPP_Dir_20
                                LIBFREDO6_Dir_43
                                LibFredo6.rb
                                LibTraductor.rb
                                Utilities
                                utilities.rb
                                Well, that's proof you installed Curviloft incorrectly. All the files I marked in bold should be in that folder and not loose in the Plugins directory.
                                  christa lennert
                                  I see no download button or link on this page. What's wrong?
                                    Look on the very first post in this topic - it's the standard location for a download link for any toolset... Note that there are requirements for 'library-helper' files that are also linked for this tool...
                                    • N Offline
                                      NickGenerator
                                      Because I am really missing the feature I just cannot resist to ask here, too.
                                      If you are planning new features for Curviloft it would be great when selecting of curves that are part of different components could become possible. (I mean like the right one where two curves can be one contour.)
                                      Of course I know, that exploding is possible but it is really unconvenient. Especially, because right now you cannot have one instance of the component connected to the path you want to loft with while having the parent somewhere else where it is easier to edit. (You can but if you make the child unique for lofting the connection is gone...)
                                      • charly2008C Offline
                                        charly2008
                                        I wanted to understand this example from NickGenerator and found that these two functions are not active for me. Am I doing something wrong? Any help would be appreciated.
                                        Charly
                                        Example NickGenerator
                                        • N Offline
                                          NickGenerator
                                          Komisch auf Englisch, aber okay...
                                          I think it is, because you just have the circle and the rectangle. And not three shapes.
                                          • fredo6F Offline
                                            @Charly
                                            These 2 modes are only enabled when you have 3 shapes or more. They somehow use the fisrt and last profile and build the shape as close as possible to the intermediate ones.
                                            Note that this does not always work fine. Still some more work needed when I have time.
                                            • 31
                                            • 32
                                            • 33
                                            • 34
                                            • 35
                                            • 65
                                            • 66
                                            • 33 / 66
