    [Example] V-Ray Displacement
    renderpluginsextensions
    54 Posts 27 Posters 173.8k Views 27 Watching
    • fuzzionF Offline
      fuzzion
      Displacement mapping made with 1.49 vfsu. Texture taken
      from http://luzindirecta.luxisessentia.com/
      HDRI sky hyperfocal
      Eye in the Sky
      "Only the dead have seen the end of war" - Plato
      • V Offline
        valerostudio
        Did we ever figure out the workaround for the 1/2 res LC IR saving in 1.49.01?
          bhbarchitects
          The scene that ThomThom has been good enough to supply has a link to the displacement on a local machine.
          If you save this map to your pc and then link to it, the scene should render fine.
          Hope this helps
          Matthew
          disp file for glass
          displacement settings
          • V Offline
            valerostudio
            I might have been clear. I apologize for that. What I am referring to is the workaround that lets you rendering at 1/2 res with displace off and then you load your IR Map and LC Maps and render at full res. Andy mentions that he thinks there is a bug in the latest version that will not let you load the IR and LC maps properly. That's my issue right now.
            • andybotA Offline
              andybot
              @valerostudio: I had a thread about this on the Chaosgroup forum. There is a trick that's worked most of the time - has to do with autosave. As long as you have a file name selected in the IRmap autosave slot, the saved maps seem to work.
              bug and solution for indirect illumination autosave bug
              (registration required)
                Moderat
                @3deviator said:
                3deviator
                I followed your steps, I liked the result.
                When I preview render in the material editor it looks good, but when I do a render from my scene it doesn't show the displacement.. I have this when rendering other kind of materials with displacement too. So there must be something wrong, I checked all the settings from your images with mine.. and they are the same. Any idea? Really frustrating, been looking for days now (reason why my water material isn't working properly too, see other thread).
                grass
                waterrender
                Thank you,
                Bert
                  Note that the material editor scene isn't well suited to preview architectural materials. When you create displacement materials you will see that the displacement amount will look different. The displacement multiplier represent inches, so calculate how big your multiplier need to be.
                  Then you also need to make sure that any displaced geometry is completely isolated. A geometry with a displacement material must not touch any geometry with any other material. That is very important.
                  • andybotA Offline
                    andybot
                    also, make sure also that any edges in your group do not have any other material applied. That's tricked me up once or twice...
                      Moderat
                      I switched the displacement multiplier up to 50, but it doesn't change a thing.
                      I created a grey rectangle outside my model to check if it would work there (so it isn't connected to another material).. still the same?
                      Can someone check my sketchup file? Really stuck here. As far as I know I'm not using any groups for the model, maybe by accidence a while ago (been working on it for quite some time now..).
                      http://www.mediafire.com/?pxmhwih5p0t5li3
                      (if you open it, does it look like a heavy file? Sketchup blocks from time to time for a minute or 2..)
                      Thank you!
                      Bert
                        Still downloading, but did you isolate the geometry? That is the most important thing to do.
                        Also, exactly what version of VfSU do you use?
                        • andybotA Offline
                          andybot
                          i wonder if he's confused that isolating geometry is not just having it separate but to actually make a "group" or "component" out of it. Haven't had a chance to look at the model either.
                            Just opened the model - looking....
                            (Just a note on the model in general - I purged the model. erased all the scenes. Erased everything except the test square the camera was focused on and saved it - 1.9MB ... from 40MB. Please purge your model before sharing - everything will be smaller and quicker. People find a 2MB file easier to initiate a download for rather than 40MB.)
                              This is true - everything was ungrouped.
                              Once grouped it worked fine.
                              (Though, I found that any geometry in the same context - connected or not - prevents displacement. Wonder if that changed since earlier versions. Before it could be in the same context. But alas not not. Complete isolation is required.)
                                Moderat
                                thank you both for helping me out. It was the group thing that caused the render to 'misbehave'
                                I tried it on a small patch, and it worked. But it took a half an hour to render a small piece.. so I'm not going to use it in my large scene (will take ages to find the right settings & get the final render). Very frustrating that all your materials have to be put apart from each other to get a working render.. don't see how you can get walls aligned to each other properly if you have consider this. Going to try the sea water later this evening, it's crucial to get it right for this project.
                                Thank you again, and sorry for the large file. Will keep it in mind for the next time.
                                  Yea - I never liked displacement grass anyway. Just end up looking like a spikestrip.
                                  I assign a colour to the Colour ID of the material and render out a Material ID pass which I use in Photoshop as a mask where I overlay real grass from photos.
                                    @andybot said:
                                    which you can see a tutorial I did a while back on that method.
                                    πŸ‘ πŸ‘
                                      Moderat
                                      Yes, seems a lot easier to do it post-rendering. Thanks, I'll be using it for my grass.
                                      Now I've been trying again to get my (sea)water working. I managed to let vray render my material, but now it's coming out all wrong.
                                      It looks exactly the same in the preview in material editor as in the youtube tutorial (http://youtu.be/vbHdi5bEdlI), but when rendering it comes out very pure blue and not transparent. I redid the whole process 3 times.. still the same result.
                                      Anyone an idea? I'm really getting tired of this same kind of problem over and over again πŸ˜„.
                                      http://www.mediafire.com/?52she3kywadj4yz
                                      (I copied the water to another file so my SU-file isn't too big to download. )
                                      Now to bed! 3 am here.
                                      Thanks in advance,
                                      Bert
                                      • majidM Offline
                                        majid
                                        dear mate, do you mind to try this one?
                                        it is just a quick tweak over glass material..... I'vnt changed the refraction IOR ( it is now 1.5 and must be 1.3 for real water) so you may yourself do it... or maybe you prefer a differend wave "size" on bumb section
                                        waterminipack.zip
                                        • Whiteowl77W Offline
                                          Whiteowl77
                                          Hi Thomas, SU Modelers
                                          I am working on an exterior Rendering of a residence and currently working on the materials and textures. I have created my own custom stone from a photo I took and manipulated in photoshop. I was able to manipulate the displacement/bump-map images needed for that as well, as I found some good video tutorials on such.
                                          I am wondering: Are there any repositories/resources for SketchUp/Vray exterior material displacement/bump-map images (alpha channel), or does the artist need to make each one him/herself?
                                          Can you recommend any settings for painted wood siding -- I downloaded some siding from: http://www.vray-materials.de/register_complete.php?regkey=923c1bebe6cc014330075ecca8a6f87f -- but , as mentioned above, this is formatted for 3DS Max not SU. I am trying to use it regardless to create the displacement image. I cannot get the image to tile or repeat, or any effect to take place. I dont want to use the "out of the box" siding material in SketchUp due to the continuios lines that make up the generic pattern.
                                          Maybe, I will take the siding image texture material in SU, save it, edit it in Photoshop, and use the B&W/grayscale to make the displacement, and then leave the material fill color/diffuse a solid color, and see if that renders correctly.
                                          Any thoughts?
                                          Whats the best way to render/depict exterior siding?
                                          Andrew
                                          • broomstickB Offline
                                            broomstick
                                            Hi there! Can you tell me exactly which siding material you are trying to use? I'll have a go to convert it into vismat πŸ˜‰
                                            • 3 / 3
