    [Plugin] Pen Tool +
    126 Posts 40 Posters 121.5k Views 40 Watching
      ๐Ÿ˜’
      It works fine for me. So, you must be missing something.
      • GaieusG
        ๐Ÿ˜†
        • massimoM
          massimo Moderator
          ๐Ÿคฃ
          • GaieusG
            Ian, I see you have just joined and this was your first post. It's not too late to start over: register another account and ask nicely. No-one will know it's you and you will find these gentlemen very helpful.
            ๐Ÿ˜‰
              I was nice ๐Ÿ˜’
              • GaieusG
                I know. Me too. I was even happy! (And Massimo even happier) ๐Ÿ˜„
                • E
                  eyein12
                  ๐Ÿ˜‰
                  Lol I see you guys have a good sense of humor. I'm sorry for the harsh post. I model 3d trains for railworks 2012 train simulator and was interested in this pen tool. But for some reason it draws an edge from the origin everytime instead of a series like the pencil tool. do you guys know what is wrong? I have sketchup 8 pro. the newest patch too. Thanks for the help! ๐Ÿ˜„
                  • GaieusG
                    OK, now we are talking.
                    I cannot even imagine what may be going on there. Which tool are you actually using? (There are a bunch of them in here) Where are you starting the lines? I also have the latest SU build and have no issues at all.
                    • E
                      eyein12
                      well I got this pen tool+ v1.4 found here http://rhin.crai.archi.fr/rld/plugin_details.php?id=854; is this the same as the one in this thread?
                      I start my line just from the origin of SU to practice using this tool. but using the pen tool there are 6 different types of which only the guide pen works correctly. when i draw, it starts from the origin and ends at the endpoint, then it starts again from the origin rather than from the endpoint, unlike the pencil tool.
                      • mitcorbM
                        mitcorb
                        Is your Template or Style setting part of the problem? Or is your precision set too high? Or are you modeling some really tiny items? I don't know, just trying to shake some ideas.
                        • E
                          eyein12
                          Just drawing a simple shape to try out the tool. nothing more.
                          • V
                            vojo
                            Still pretty new to sketchup, but
                            I really dont understand the intent of this tool
                            • softpen appears to do nothing
                            • I see what some of the other pens do...I guess there must be a need for their functions
                            Can you give me specific scenario/sequence on doing something with softpen
                            (I was hoping that it would "round" line corners and such).
                            • GaieusG
                              Turn hidden geometry on (View menu) and you will see the soft edges the tool draws. Certainly one could live without it: draw traditional edges and soften them afterwards. Sometimes it is a pain in the butt though if you need to draw a lot. This is best to add edges to (or heal missing faces of) already soft meshes, most of the times curved surfaces.
                              • jgbJ
                                jgb
                                This is something I wanted for a long time, and in fact I d/l'd it last year, put it in my "2B installed" directory (off the "plugin" dir), and then.....
                                promptly forgot about it. ๐Ÿ˜’ An all to common occurrence with me.
                                So today, I got this thread notice, d/l'd it and got the XP warning about overwriting a file. ๐Ÿ˜ฎ
                                So, ๐Ÿ˜ณ I installed it.
                                Rich, is there any way to set the toolbar in a vertical format? ๐Ÿ’ญ
                                I have no horizontal space top or bottom screen for more toolbars, but I have space on the left, 2 icons wide.
                                Can I edit the script (with your instructions) until you hopefully furnish an update?
                                jgb
                                  Resize it like you would any other toolbar ๐Ÿ˜•
                                  or windows window for that matter. All toolbars can be resized horizontally or vertically
                                  • jgbJ
                                    jgb
                                    Thank you for the excellent guidance... ๐Ÿ˜ณ
                                    For some reason it did not work for me at first.
                                    I reloaded SU and it is resizing as expected.
                                    jgb
                                    • L
                                      Lobster
                                      Just found this, as usual way behind the plug-in bleeding edge.
                                      Its Freaking Great.
                                      Thanks Rich
                                      • simon le bonS
                                        simon le bon
                                        Hi Rich,
                                        Your Pen set is very nice and I'm glad to use it as a basic SU tools.
                                        I would like to bring your attention on the fact that Pen tools invalidates Jim's Construction Line Tool (opening your Construction Points Pen in place of)
                                        Jim's Construction Line Tool have the very useful option to let the choice to put or not construction points at the construction line extremities.
                                        Do you think it would be possible to add this option to your pen tool ( and may be to fix interference with Jim's tool ?)
                                        Cheers,
                                        Simon
                                          Simon
                                          Edit the PenTool's .rb file with Notepad or Notepad++.
                                          Use Find+Replace [respecting the 'case'] for the 4 occurrences of CLineTool and replace with C**P**LineTool, there's also a lowercase 'def clinetool' - make that 'def cplinetool' too; then it won't clash with Jim's 'CLineTool' at all... ๐Ÿ˜„
                                            Can you try the latest version I uploaded?
                                            404 Not Found
                                            (forums.sketchucation.com)
                                            I added TIG's suggestions.
                                            • 5 / 7
