    [Plugin] Pen Tool +
    126 Posts 40 Posters 119.2k Views 40 Watching
      Unfortunately no. Guides are deleted even in locked groups. I'd call this a bug but officially it is called a "feature".
      I am not really sure but as if in some earlier versions construction lines hadn't been deleted if they were in a group and you were outside that context. Just like how "unhide all" works now.
      You can always put these guides into a component (along with something else) however then right click and "Save as..." Later when you clean up your guides, right click on this component again and "Reload".
      I know it's a poor workaround but should do it.
      • TIGT Online
        There are several tools knocking around that I and others made ages ago...
        Mine erases only those guide-lines or guide-points or both in the active context or current selection or 'all' if there's no selection - see here http://forums.sketchucation.com/viewtopic.php?p=341048#p341048 [I just modernized it a bit]
          boilingsnow
          Thank you Rich O'Brien!
          But the weld draw doesnt work by me.
          It always start from the origin point so I can't draw the line I want.
          Can you tell how to fix it?
          • irwanwrI Offline
            irwanwr
            ๐Ÿ‘ i am going to use this often
            thank you
            • E Offline
              eyein12
              ๐Ÿ‘Ž all pens draw from origin and thats it. is there something i'm missing
                ๐Ÿ˜’
                It works fine for me. So, you must be missing something.
                  ๐Ÿ˜†
                  • massimoM Offline
                    massimo Moderator
                    ๐Ÿคฃ
                      Ian, I see you have just joined and this was your first post. It's not too late to start over: register another account and ask nicely. No-one will know it's you and you will find these gentlemen very helpful.
                      ๐Ÿ˜‰
                        I was nice ๐Ÿ˜’
                          I know. Me too. I was even happy! (And Massimo even happier) ๐Ÿ˜„
                          • E Offline
                            eyein12
                            ๐Ÿ˜‰
                            Lol I see you guys have a good sense of humor. I'm sorry for the harsh post. I model 3d trains for railworks 2012 train simulator and was interested in this pen tool. But for some reason it draws an edge from the origin everytime instead of a series like the pencil tool. do you guys know what is wrong? I have sketchup 8 pro. the newest patch too. Thanks for the help! ๐Ÿ˜„
                              OK, now we are talking.
                              I cannot even imagine what may be going on there. Which tool are you actually using? (There are a bunch of them in here) Where are you starting the lines? I also have the latest SU build and have no issues at all.
                              • E Offline
                                eyein12
                                well I got this pen tool+ v1.4 found here http://rhin.crai.archi.fr/rld/plugin_details.php?id=854; is this the same as the one in this thread?
                                I start my line just from the origin of SU to practice using this tool. but using the pen tool there are 6 different types of which only the guide pen works correctly. when i draw, it starts from the origin and ends at the endpoint, then it starts again from the origin rather than from the endpoint, unlike the pencil tool.
                                • mitcorbM Offline
                                  mitcorb
                                  Is your Template or Style setting part of the problem? Or is your precision set too high? Or are you modeling some really tiny items? I don't know, just trying to shake some ideas.
                                  • E Offline
                                    eyein12
                                    Just drawing a simple shape to try out the tool. nothing more.
                                    • V Offline
                                      vojo
                                      Still pretty new to sketchup, but
                                      I really dont understand the intent of this tool
                                      • softpen appears to do nothing
                                      • I see what some of the other pens do...I guess there must be a need for their functions
                                      Can you give me specific scenario/sequence on doing something with softpen
                                      (I was hoping that it would "round" line corners and such).
                                        Turn hidden geometry on (View menu) and you will see the soft edges the tool draws. Certainly one could live without it: draw traditional edges and soften them afterwards. Sometimes it is a pain in the butt though if you need to draw a lot. This is best to add edges to (or heal missing faces of) already soft meshes, most of the times curved surfaces.
                                        • jgbJ Offline
                                          jgb
                                          This is something I wanted for a long time, and in fact I d/l'd it last year, put it in my "2B installed" directory (off the "plugin" dir), and then.....
                                          promptly forgot about it. ๐Ÿ˜’ An all to common occurrence with me.
                                          So today, I got this thread notice, d/l'd it and got the XP warning about overwriting a file. ๐Ÿ˜ฎ
                                          So, ๐Ÿ˜ณ I installed it.
                                          Rich, is there any way to set the toolbar in a vertical format? ๐Ÿ’ญ
                                          I have no horizontal space top or bottom screen for more toolbars, but I have space on the left, 2 icons wide.
                                          Can I edit the script (with your instructions) until you hopefully furnish an update?
                                          jgb
                                            Resize it like you would any other toolbar ๐Ÿ˜•
                                            or windows window for that matter. All toolbars can be resized horizontally or vertically
                                            • 5 / 7
