    [Plugin] Pen Tool +
    126 Posts 40 Posters 119.2k Views 40 Watching
      boilingsnow
      Thank you Rich O'Brien!
      But the weld draw doesnt work by me.
      It always start from the origin point so I can't draw the line I want.
      Can you tell how to fix it?
      • irwanwrI Offline
        irwanwr
        ๐Ÿ‘ i am going to use this often
        thank you
        • E Offline
          eyein12
          ๐Ÿ‘Ž all pens draw from origin and thats it. is there something i'm missing
            ๐Ÿ˜’
            It works fine for me. So, you must be missing something.
              ๐Ÿ˜†
              • massimoM Offline
                massimo Moderator
                ๐Ÿคฃ
                  Ian, I see you have just joined and this was your first post. It's not too late to start over: register another account and ask nicely. No-one will know it's you and you will find these gentlemen very helpful.
                  ๐Ÿ˜‰
                    I was nice ๐Ÿ˜’
                      I know. Me too. I was even happy! (And Massimo even happier) ๐Ÿ˜„
                      • E Offline
                        eyein12
                        ๐Ÿ˜‰
                        Lol I see you guys have a good sense of humor. I'm sorry for the harsh post. I model 3d trains for railworks 2012 train simulator and was interested in this pen tool. But for some reason it draws an edge from the origin everytime instead of a series like the pencil tool. do you guys know what is wrong? I have sketchup 8 pro. the newest patch too. Thanks for the help! ๐Ÿ˜„
                          OK, now we are talking.
                          I cannot even imagine what may be going on there. Which tool are you actually using? (There are a bunch of them in here) Where are you starting the lines? I also have the latest SU build and have no issues at all.
                          • E Offline
                            eyein12
                            well I got this pen tool+ v1.4 found here http://rhin.crai.archi.fr/rld/plugin_details.php?id=854; is this the same as the one in this thread?
                            I start my line just from the origin of SU to practice using this tool. but using the pen tool there are 6 different types of which only the guide pen works correctly. when i draw, it starts from the origin and ends at the endpoint, then it starts again from the origin rather than from the endpoint, unlike the pencil tool.
                            • mitcorbM Offline
                              mitcorb
                              Is your Template or Style setting part of the problem? Or is your precision set too high? Or are you modeling some really tiny items? I don't know, just trying to shake some ideas.
                              • E Offline
                                eyein12
                                Just drawing a simple shape to try out the tool. nothing more.
                                • V Offline
                                  vojo
                                  Still pretty new to sketchup, but
                                  I really dont understand the intent of this tool
                                  • softpen appears to do nothing
                                  • I see what some of the other pens do...I guess there must be a need for their functions
                                  Can you give me specific scenario/sequence on doing something with softpen
                                  (I was hoping that it would "round" line corners and such).
                                    Turn hidden geometry on (View menu) and you will see the soft edges the tool draws. Certainly one could live without it: draw traditional edges and soften them afterwards. Sometimes it is a pain in the butt though if you need to draw a lot. This is best to add edges to (or heal missing faces of) already soft meshes, most of the times curved surfaces.
                                    • jgbJ Offline
                                      jgb
                                      This is something I wanted for a long time, and in fact I d/l'd it last year, put it in my "2B installed" directory (off the "plugin" dir), and then.....
                                      promptly forgot about it. ๐Ÿ˜’ An all to common occurrence with me.
                                      So today, I got this thread notice, d/l'd it and got the XP warning about overwriting a file. ๐Ÿ˜ฎ
                                      So, ๐Ÿ˜ณ I installed it.
                                      Rich, is there any way to set the toolbar in a vertical format? ๐Ÿ’ญ
                                      I have no horizontal space top or bottom screen for more toolbars, but I have space on the left, 2 icons wide.
                                      Can I edit the script (with your instructions) until you hopefully furnish an update?
                                      jgb
                                        Resize it like you would any other toolbar ๐Ÿ˜•
                                        or windows window for that matter. All toolbars can be resized horizontally or vertically
                                        • jgbJ Offline
                                          jgb
                                          Thank you for the excellent guidance... ๐Ÿ˜ณ
                                          For some reason it did not work for me at first.
                                          I reloaded SU and it is resizing as expected.
                                          jgb
                                            Lobster
                                            Just found this, as usual way behind the plug-in bleeding edge.
                                            Its Freaking Great.
                                            Thanks Rich
                                            • 5 / 7
