    [Plugin] Pen Tool +
    126 Posts 40 Posters 119.2k Views 40 Watching
    • H Offline
      hungnguyenpham
      Thank you!
        Panga
        Thanks a lot for this usefull plugins !! πŸ‘
        • jgbJ Offline
          jgb
          @dave r said:
          Comes of drinking American beer at high elevations for a week when you're not used to either. πŸ˜„
          Canadian beer will do that at sea level in less than a day. 🀣
          jgb
          • mitcorbM Offline
            mitcorb
            Hi:
            Just trying out Pen Tool last night, I noticed that occasionally for one click I got 2 Cpoints. Also, one or two of the other pen settings doubled the endpoints which were placed short distances apart in a series of quick clicks randomly in the model space. Hard to explain. I did not save the file. This was in Sketchup 7. This mouse has shown no other misbehavior in other applications.
            Has anyone else seen this?
            • TIGT Online
              Mitcorb I think this is down to you keeping the mouse-button pressed and dragging.
              Most of this kind of line tools allow for you to press+hold+drag+release to make the line, as well as more usual click+click to provide two ends.
              There's a short timer delay built-in to spot a real button-hold as that - obviously you're on the top limit time-wise and it's assuming a drag is wanted...
              Is your mouse-button sticky?
              For the cpoint tool if you don't do a clean click. but do more of a press. then it assume a drag and places a second cpoint at the release point - which might be only a short distance away if the mouse moves slightly.
              So to avoid this ensure a clean click with no holding down of the mouse button with a drag unless you want two points...
              πŸ˜•
              • mitcorbM Offline
                mitcorb
                Yes, thanks, TIG:
                It is obvious from only one test that I wasn't tuned in to the appropriate procedure. I am not usually what you would call a fast clicker, partly because of my system response, and partly because of my own internal wiring. πŸ’š
                A salute to you and Rich for this excellent concept.
                • N Offline
                  nanfar
                  thank you for you plugin.
                    austin457
                    Awesome. I joined this site specifically to get this plug-in. It's been a bane in my rear end that Sketchup couldn't simply draw dashed (or construction lines) that didn't go into infinity. Couldn't make a clean diagram that way. (And I know SU is more for 3D than CAD- but it makes sense to model something and then CAD it out in the same app. I also know Layout can draw them, but that gets messy too).
                    I literally just used the plug-in, but something I noticed right off I want to ask about:
                    I see that drawing the Construction lines flags to SU they are indeed construction lines. When I "Delete Guides" they are deleted as well. I tried grouping them and locking, but they still get deleted if I use the command. Is there a way to makes these lines unique to SU so they won't get deleted when cleaning up my drawings with the Delete Guides command?
                    Thanks again. This will cut down on a lot of cursing 'round here! πŸ˜‰
                    Win XP, SU 7
                      Unfortunately no. Guides are deleted even in locked groups. I'd call this a bug but officially it is called a "feature".
                      I am not really sure but as if in some earlier versions construction lines hadn't been deleted if they were in a group and you were outside that context. Just like how "unhide all" works now.
                      You can always put these guides into a component (along with something else) however then right click and "Save as..." Later when you clean up your guides, right click on this component again and "Reload".
                      I know it's a poor workaround but should do it.
                      • TIGT Online
                        There are several tools knocking around that I and others made ages ago...
                        Mine erases only those guide-lines or guide-points or both in the active context or current selection or 'all' if there's no selection - see here http://forums.sketchucation.com/viewtopic.php?p=341048#p341048 [I just modernized it a bit]
                          boilingsnow
                          Thank you Rich O'Brien!
                          But the weld draw doesnt work by me.
                          It always start from the origin point so I can't draw the line I want.
                          Can you tell how to fix it?
                          • irwanwrI Offline
                            irwanwr
                            πŸ‘ i am going to use this often
                            thank you
                            • E Offline
                              eyein12
                              πŸ‘Ž all pens draw from origin and thats it. is there something i'm missing
                                πŸ˜’
                                It works fine for me. So, you must be missing something.
                                  πŸ˜†
                                  • massimoM Offline
                                    massimo Moderator
                                      Ian, I see you have just joined and this was your first post. It's not too late to start over: register another account and ask nicely. No-one will know it's you and you will find these gentlemen very helpful.
                                      πŸ˜‰
                                        I was nice πŸ˜’
                                          I know. Me too. I was even happy! (And Massimo even happier) πŸ˜„
                                          • E Offline
                                            eyein12
                                            πŸ˜‰
                                            Lol I see you guys have a good sense of humor. I'm sorry for the harsh post. I model 3d trains for railworks 2012 train simulator and was interested in this pen tool. But for some reason it draws an edge from the origin everytime instead of a series like the pencil tool. do you guys know what is wrong? I have sketchup 8 pro. the newest patch too. Thanks for the help! πŸ˜„
                                            • 4 / 7
