    FluidImporter free .obj importer Beta 1.0.5 Updated
    extensions
    168 Posts 46 Posters 97.1k Views 46 Watching
      Search the Plugins-Index [here] for my OBJimporter.rb ...
      That does place the geometry directly at it's original location.
      The alternative, newer compiled version allows you to manually locate the geometry BUT it's easy enough to make that [0,0,0] ...
      • E
        emanshiu
        any idea on the crashing? it's really just a cube from maya.....
          Unless you zip up the OBJ/MTL/Image-files and post them how can I know?
          Have you tried the older importer.rb file ?
          I haven't been directly involved in making the newer one BUT there might be clues in the way each one works...
          Please post the files if we are to progress this issue anywhere...
          • F
            fluid
            Yep, if you post the file that is causing the crash, I'll be happy to test it on FluidImporter as well.
            • E
              Efrado
              HI ,TIG &NICOLA
              WHAT ATEAM YOU ARE DOING πŸ‘ πŸ‘
              JUST A HUMBLE MAC USER WAITING TO TRY YOUR EFFORT IN THIS PLATFORM,PLEASE 😒
              • N
                niks
                hi Fluid and Tig... thank you very much for this importer. tried it for a test and achieve great result πŸ˜„
                • B
                  blockade08
                  @tig said:
                  @whoa said:
                  Hello
                  I just installed your importer and I have no issue importing the .obj file, however I am not getting any textures?
                  Everything is just gray. I received the files from a furniture company, 4 seperate folders with several .obj files + .mtl and some jpgs that I guess are the textures. How do I add these into sketchup onto the objects?
                  Thank you
                  You can read OBJ and MTL files in Notepad or equivalent.
                  The OBJ file defines the MTL file by name mtllib xxx.mtl.
                  The OBJ file usually expects the MTL file to be in the same folder as itself.
                  The MTL file defines materials.
                  They can be simple plain color like this (Kd values as %s =~[170,170,170]=~'mid-gray')
                  newmtl Color_003
                  Ka 0.000000 0.000000 0.000000
                  Kd 0.666667 0.666667 0.666667
                  Ks 0.000000 0.000000 0.000000
                  d 1.000000
                  or with a texture specified by an image-file it is like this
                  newmtl Wood_Floor
                  Kd 0.607843 0.411765 0.239216
                  d 1.000000
                  map_Kd MyModel/Wood_Floor.jpg
                  In this example the MTL file is expecting to find that material's texture's image-file called Wood_Floor.jpg in a subfolder that's in the MTL file's folder, that's named MyModel.
                  Note that many OBJ exporters use an image subfolder, but some do not - in that case the line might read
                  and then the textures' image files should be in the same folder as the MTL file itself...
                  If an OBJ importer can't find the image file it usually skips using it, and just uses the color specified for the material - in the case of 'Wood_Floor' this would be an RGB color based on the Kd values, as percentages of 255 =~[155,105,61]=~'mid-brown'...
                  Note that the 'd' value is the opacity: where 1.000000 is solid and 0.500000 is 50% transparent etc... So you can adjust these prior to import if desired...
                  Thank you so much TIG you just saved me from hours of trying to fix up the textures as normally happens when i try a new importer/exporter πŸ˜„ Thanks a bunch πŸ˜„
                  BTW for anyone who also has this problem, my .OBJ said mtllib C:\......\*wheremyModelIs*\test.mtl
                  I changed it to mtllib test.mtl - took off the directory data and it worked like a charm πŸ˜„
                  • C
                    chocochoc
                    Hi there,
                    I tried to download the fluidimporter, but the website gives back a 500 error.
                    I couldn't find a mirror to download it. Is there someone who would send it to me or give me an available link ?
                    • F
                      fluid
                      It should be fixed now.
                      Nicola
                        Somun
                        hmm... We're having a tab bit of trouble importing a terrain mesh we've made... We keep running out of memory...
                        The file size on the obj file is 374mb.
                        Any solutions?
                        If importer cant be solved for it... any other way to get it into sketchup (perhaps in pieces?)
                        Not sure about the polygon count, but its a large number. Probably somewhere around 2m.
                          All i can say is try poly cruncher or deep exploration beforehand.
                          That's a pretty large .obj which probably increases inside SU also. Best of luck with it πŸ‘
                            Somun
                            poly cruncher is a bit useless since the goal is to have a complex 3D terrain mesh, and deep exploration would not work... (wrong processor)
                            any way to chop up a 3D mesh into smaller segments?
                              Somun
                              hmm... figured out the lack of cooperation... tried to import far too large meshes... worked better when going for a smaller mesh.
                              • W
                                wootwoots
                                Hello, i tried the FluidImporter, and saddly, even for a simple cub i got a google sketchup 8 crach 😞 whatever i'am choosing as import option.
                                Does it because i'am using a 64bit window ?
                                Any help possible ?
                                thanks ^^
                                  What app are you using to make the .obj file?
                                  I find this plugin very robust in most cases.
                                  • W
                                    wootwoots
                                    I made thoses obj in the Cryengine 3.
                                    I tried the Trial of the simlab soft Obj importer, and that work correctly except for the scale. and i only have problem with thoses ones.
                                      You get to choose the units for the OBJ file as you import it, so there is no 'scale issue', just PEBCAC! πŸ˜‰
                                        Trying to figure out what the first 'C' is?
                                        I hope it's not what I'm thinking!
                                          Problem Exists Between Computer And Chair
                                          πŸ˜‰
                                          • W
                                            wootwoots
                                            Well yes, but the problem is that the simlab importer tool have a 30 import limit πŸ˜• and well, for just a personal and occasional use.. thats not so nice having to pay it.
                                            After the other free Obj Importer didnt work at all with thoses object. Your didnt import anything, and the fluidImporter crash all the time 😒 ( at least with .obj coming from the CryEngine3, didnt try .obj coming from other soft. )
                                            • 4 / 9
