    FluidImporter free .obj importer Beta 1.0.5 Updated
    extensions
    168 Posts 46 Posters 78.4k Views 46 Watching
      It's not a Plugin, it's a compiled 'Importer'.
      It adds an additional Importer type 'Wavefront/OBJ' under the File > Import file-browser...
      The same as other compiled importers/exporters - it's the Ruby based tools that are in other menus like Plugins...
        bizmen
        Which folder do I have to extract the fluidimporter file? I cannot see it under the plugins menu after extracting on its default folder.
        Btw. I'm using Google sketch up v8 (free version) ,and should I install the fluid ray demo version before fluidimporter for sketchup appears?
        If yes, which installer should I download? I'm using windows vista ultimate 64 bit, 4gb ram
        FluidRay for SketchUp Win32 Demo (Version 1.1.2)
        FluidRay for SketchUp Win32 SSE2 Demo (Version 1.1.2)
        FluidRay for SketchUp Win64 SSE2 Demo (Version 1.1.2)
        FluidRay for SketchUp Win64 SSE41 Demo (Version 1.1.2)
          bizmen
          Thanks TIG, you're the MAN!
          • W Offline
            whoa
            Hello
            I just installed your importer and I have no issue importing the .obj file, however I am not getting any textures?
            Everything is just gray. I received the files from a furniture company, 4 seperate folders with several .obj files + .mtl and some jpgs that I guess are the textures. How do I add these into sketchup onto the objects?
            Thank you
              @whoa said:
              Hello
              Thank you
              You can read OBJ and MTL files in Notepad or equivalent.
              The OBJ file defines the MTL file by name mtllib xxx.mtl.
              The OBJ file usually expects the MTL file to be in the same folder as itself.
              The MTL file defines materials.
              They can be simple plain color like this (Kd values as %s =~[170,170,170]=~'mid-gray')
              newmtl Color_003
              Ka 0.000000 0.000000 0.000000
              Kd 0.666667 0.666667 0.666667
              Ks 0.000000 0.000000 0.000000
              d 1.000000
              or with a texture specified by an image-file it is like this
              newmtl Wood_Floor
              Kd 0.607843 0.411765 0.239216
              d 1.000000
              map_Kd MyModel/Wood_Floor.jpg
              In this example the MTL file is expecting to find that material's texture's image-file called Wood_Floor.jpg in a subfolder that's in the MTL file's folder, that's named MyModel.
              Note that many OBJ exporters use an image subfolder, but some do not - in that case the line might read
              and then the textures' image files should be in the same folder as the MTL file itself...
              If an OBJ importer can't find the image file it usually skips using it, and just uses the color specified for the material - in the case of 'Wood_Floor' this would be an RGB color based on the Kd values, as percentages of 255 =~[155,105,61]=~'mid-brown'...
              Note that the 'd' value is the opacity: where 1.000000 is solid and 0.500000 is 50% transparent etc... So you can adjust these prior to import if desired...
              • E Offline
                emanshiu
                Thank you for writing this tool. But everyttime i try to load in an OBJ, the sketchup just crashes. It crashes on a very simple text file. I'm a bit confused at what I can do. Am I doing something wrong? These files are all exported from Maya. Thanks!
                  What are the error messages in the Ruby Console etc ?
                  Have you tried it with my [TIG] older/slower OBJimporter.rb ?
                  Any error messages there ?
                  CAN you zip the OBJ & MTL files... and image files [in a folder if specified in the MTL etc] and post them so we can test it...
                  • E Offline
                    emanshiu
                    There are no error messages as it just crashes.
                    I'm sorry i was not aware theres an older one. I just tried to find it but can't where is it?
                    Also is there any way to import an obj and have it place at 0,0,0?
                    thanks so much for the help!
                      Search the Plugins-Index [here] for my OBJimporter.rb ...
                      That does place the geometry directly at it's original location.
                      The alternative, newer compiled version allows you to manually locate the geometry BUT it's easy enough to make that [0,0,0] ...
                      • E Offline
                        emanshiu
                        any idea on the crashing? it's really just a cube from maya.....
                          Unless you zip up the OBJ/MTL/Image-files and post them how can I know?
                          Have you tried the older importer.rb file ?
                          I haven't been directly involved in making the newer one BUT there might be clues in the way each one works...
                          Please post the files if we are to progress this issue anywhere...
                          • F Offline
                            fluid
                            Yep, if you post the file that is causing the crash, I'll be happy to test it on FluidImporter as well.
                            • E Offline
                              Efrado
                              HI ,TIG &NICOLA
                              WHAT ATEAM YOU ARE DOING πŸ‘ πŸ‘
                              JUST A HUMBLE MAC USER WAITING TO TRY YOUR EFFORT IN THIS PLATFORM,PLEASE 😒
                              • N Offline
                                niks
                                hi Fluid and Tig... thank you very much for this importer. tried it for a test and achieve great result πŸ˜„
                                  blockade08
                                  @tig said:
                                  @whoa said:
                                  Hello
                                  Thank you
                                  newmtl Color_003
                                  d 1.000000
                                  newmtl Wood_Floor
                                  d 1.000000
                                  Thank you so much TIG you just saved me from hours of trying to fix up the textures as normally happens when i try a new importer/exporter πŸ˜„ Thanks a bunch πŸ˜„
                                  BTW for anyone who also has this problem, my .OBJ said mtllib C:\......\*wheremyModelIs*\test.mtl
                                  I changed it to mtllib test.mtl - took off the directory data and it worked like a charm πŸ˜„
                                    chocochoc
                                    Hi there,
                                    I tried to download the fluidimporter, but the website gives back a 500 error.
                                    I couldn't find a mirror to download it. Is there someone who would send it to me or give me an available link ?
                                    • F Offline
                                      fluid
                                      It should be fixed now.
                                      Nicola
                                        Somun
                                        hmm... We're having a tab bit of trouble importing a terrain mesh we've made... We keep running out of memory...
                                        The file size on the obj file is 374mb.
                                        Any solutions?
                                        If importer cant be solved for it... any other way to get it into sketchup (perhaps in pieces?)
                                        Not sure about the polygon count, but its a large number. Probably somewhere around 2m.
                                          All i can say is try poly cruncher or deep exploration beforehand.
                                          That's a pretty large .obj which probably increases inside SU also. Best of luck with it πŸ‘
                                            Somun
                                            poly cruncher is a bit useless since the goal is to have a complex 3D terrain mesh, and deep exploration would not work... (wrong processor)
                                            any way to chop up a 3D mesh into smaller segments?
                                            • 3 / 9
