    SketchUp 8 M2 is out!
    157 Posts 49 Posters 53.4k Views 49 Watching
      @voljanko said:
      I have noticed some differences with the in the
      Sketchup.active_model.options[3]
      that I use to extract the setted units information.Any plugins that are using this function can have problems with the SketchUp8 M2 version.
      Is there a list of that kind of differences?
      See my notes at the bottom of the OptionsProvider page, a snippet to list out the different options:
      Sketchup.active_model.options.keys.each {|key| p key; Sketchup.active_model.options[key].each {|k,v| puts "> #{k} - #{v}"} }
      • McGyverM
        McGyver
        It is great that now when you export a model from SU in COLLADA format it retains the texture name... unfortunately that does not apply to colors or renamed colors,apparently.
        Why would that not be included? Is it some freaky mojo of the COLLADA format that makes that impossible?
        Kinda sucks to still have to rename all the materials that are not jpegs... I know it sounds like a whiney complaint, but if you have like 10 or more different materials that you intend to render as metallics... somehow ID3,ID55,ID278 etc, does not exactly make it easy to figure out which is which.
        Well, I still appreciate that I don't have to rename the image based texture anymore.
        Visit My ShareCG Freebie Gallery
        • voljankoV
          voljanko
          Thanks for this.I still cannot see any notes at the bottom of the RUBY API pages.It is some old language problem.
          You should use the named optioned "UnitsOptions" rather than a numeric index to access the Options.
          Yes,but it was easy to check the units with numeric index because under 2 in was the american style and over 1 it was the metric style.Now I have to switch-case all the units 😞
          SuSolid.com - solid check - solid repair- solid intersection check - weight plugin
            You mean the result of Sketchup.active_model.options["UnitsOptions"]["LengthUnit"] ?
            That you can still do.
            http://forums.sketchucation.com/viewtopic.php?f=180&t=35923&p=316407#p316407
            The various data types for model.options["UnitsOptions"]
            LengthFormat: 0 = Decimal, 1 = Arcitectural, 2 = Engineering
            LengthUnit: 0 = Inches, 1 = Feet, 2 = Millimeters 3 = centimeters, 4 = Meters
              Aerilius
              There are no comments on the international pages (code.google.com/intl/...). The standard page used to redirect non-english users to the international page so nobody could see the comments, but I asked them to turn the redirect off and it seems to work now on this link:
              http://code.google.com/apis/sketchup/docs/index.html πŸ˜‰
                Yea, the Google pages are really annoying me with the redirects. I had to change my language preferences in my browser to be able to access the comments.
                • G
                  grim
                  ok this is going to be viewed as a dumb question
                  how do you know if you have downloaded and installed SU8-M2
                  there is nothing on the website saying this is M2 and there is nothing in the version record to say M2
                  Is version 8.0.11752 what you are all raving on about, so far i cannot see anything new or different
                  have i got the right one?
                  • GaieusG
                    If you have this, you have the latest M2.
                    • Bob JamesB
                      Bob James
                      I started to have trouble with M2 not working: SU started crashing every time I tried to open it. Before that I was getting instant grey right-click menu items.
                      So I uninstalled SU completely and reinstalled M2. I also limited the number of active plugins (they are still in the Plugins folder, but not checked as active).
                      So far, so good πŸ˜„
                      Update:
                      I spoke too soon: even with a minimum of toolbars active the dreaded "grey-out" has returned. I assume from this that just deactivating plugins does not help. The only thing left is to remove them from the plugins folder. What a mess 🀒
                        Bob
                        It's not the number of 'active' extensions or tools, but it's the number of 'loaded plugins' that have made 'commands' - which are then used in menus, context-menus and toolbars - even if these toolbars are not visible ['active'] they still have a command made for them.
                        There were some 'rogue' scripts that did add multiple commands - which brought the whole issue to light - but these have long been updated [ensure you have all of the latest versions of any of Fredo's tools, which were the main culprits].
                        Note that many scripts are NOT packaged as 'extensions' - so they will always auto-load from their .rb/.rbs file in the Plugins folder. Extensions work slightly differently from a 'plain' script, as their .rb/.rbs 'loader' file in the Plugins folder auto-runs, but then if that extension is set to be inactive then it does not load the tool's main code [from files inside the tool's subfolder] - so having an extension deactivated means that its 'commands' do not auto-load, until it's activated - when they do.
                        To have this 'gray-out' you need to have over 1000 commands loading, which is a lot [but it would be good if it could be more!]. I have many scripts loading, but I do 'manage them' to avoid the dreaded gray-out.
                        The way I do it is you rename the scripts that you don't want to auto-load from the Plugins folder as .rb! or .rbs!. Then only the .rb/.rbs ones auto-load. If you find you've disabled something that another tool needs then simply rename it back! [an example might be that 'progressbar.rb' is needed by several other scripts so it should always be left as its .rb format]. Now... if later on you discover that you do want a tool that is not being auto-loaded then you can type a simple command at the Ruby Console to load it temporarily for that session
                        load "the_desired_script.rb!"
                        [or whatever its real name is!]
                        Changing a file's suffix from .rb to .rb! doesn't affect that file's contents, so its code loads OK [making menus/toolbars etc as normal], irrespective of the file's suffix - it's just that .rb/.rbs files in the Plugins folder 'auto-load'. If you find yourself manually loading a script often then you can rename it back to .rb so that it then auto-loads thereafter...
                        You'll be surprised how a spring-clean helps, you probably have dozens of scripts loading that are not used one month to the next - this way you can always manually load one for just that session as you need it...
                        Also please ensure that you don't have rogue copies of files that should be in the Tools folder in your Plugins folder - the SUp install puts the right ones into Tools but older versions and some ill-advised script 'collections' put old files into Plugins and break things subtly - typical files that should NOT be in Plugins are 'extensions.rb' and 'sketchup.rb' - so open both folders and check the relatively few Tools scripts against the Plugins scripts - remove any Plugins 'duplicates'...
                        • jgbJ
                          jgb
                          Well I don't!!!!! 😲
                          I still have my old version 8.0.3117 (help - about)
                          When I do a check for updates, it says update available and gets the same WEN file.
                          The version I d/l'd was 37mb, while the older M1 version was 41mb. That does not seem right. ❓ ❓
                          jgb
                          • jgbJ
                            jgb
                            @jgb said:
                            Well I don't!!!!! 😲
                            Well is my face red. 😳
                            I was always starting from my old HD (drive D:) that crashed a few months ago.
                            But I had reinstalled SU8 M1 on C:. Never noticed that although I set the various SU defaults to the πŸ˜„ version, the desktop icon was starting in D:.
                            When I cleared my desktop of opened windows after installing M2 on πŸ˜„ I saw the new SU icon in the upper left corner. It seems to run OK now, so I will deep-6 the drive D; SU directory.
                            jgb
                            • Bob JamesB
                              Bob James
                              Thank you, TIG, for taking the time for such a fine response.
                              I'm still hoping the great folks at Google will get the message soon and fix the situation properly.
                                jorge2011
                                a question.
                                When I select the layer0, change the camera mode (of perspective to parallel).
                                Is this normal?
                                  @jorge2011 said:
                                  a question.
                                  Is this normal?
                                  No and it doesn't happen to me or anyone else I know... Can you be specific about the exact steps you are taking to do this ... πŸ˜•
                                    jorge2011
                                    TIG hello.
                                    I found the problem.
                                    The problem is caused by this plugin.
                                    http://forums.sketchucation.com/viewtopic.php?f=323&t=41840
                                    Thanks for your reply
                                      Dave Wood
                                      Please give me more information about how to download the latest update for 8 Pro. Help, Find Latest Update sends me to the download option. But, I'm not sure what version is the latest and I couldn't find a designation for it. I've got an exe file on my desktop, but it appears to be old. I've got a version 8.0.4811 as the file currently running my program. Please help. Thanks, Dave Wood
                                        Here's the download page...
                                        Error 404 (Not Found)!!1
                                        (sketchup.google.com)
                                        Not sure if your Pro or Free since your profile reads Version 6
                                        • halroachH
                                          halroach
                                          Another Sketchup 8 M2 annoyance...
                                          Or maybe it's something else that's causing this? I doubt it.
                                          Every time I create a component, the components window changes it's location to to "in model".
                                          That is very annoying for three reasons:
                                          1. I didn't ask it to. 😳
                                          2. I usually like having one of my own people/cars/trees/materials... whatever libraries open. Just because I decided to add some steps somewhere it doesn't mean I don't want to keep putting in more of those components I cherish so much. (very similar to point number 1)
                                          3. With large models, I tend to never ever ever ever have the "in model" components library open, because it slows things down to load all those components everytime... I'm talking hundreds of components here...
                                          Is there any chance for a quick fix of this? or should I just revert to the old M1? It would be nice to have some quick fixes every now and then, without the need to wait for the super releases...
                                          FlexTools - Super Quick Windows, Doors, Slats...
                                          • irwanwrI
                                            irwanwr
                                            excuse me if i am late and missed something.
                                            i'd like to know why is the setup file size so different?
                                            and the new one has smaller(?) setup file size.
                                            the new M2 setup file size is (only) 36.9 MB.
                                            the one i have here, has the size of 40.1 MB.
                                            • 8 / 8
