    1.5k Posts 471 Posters 3.4m Views 470 Watching
      aea
      hay
      • massimoM Offline
        massimo Moderator
        This is a possible workflow with SU's native tools supposing you already have a cone as a start.
          aea
          thanks , Another problem I found here
            From the picture it seems that those diagonals could be safely deleted. Try to run the plugin after that.
            • fredo6F Offline
              @aea said:
              hay
              For rounding the tip of a cone, I suggest you use Massimo's method.
              With RoundCorner, you can do the rounding, but:
              1. you need to make the edges plain (i.e. non soft, non smooth)
              2. the edges will be themselves rounded, which won't leave the surface of the cone smooth.
              RoundCorner_Cone.gif]
                Also, for the cone, you can truncate the tip and apply round corner only on the top circle. It's a bit of a fiddling around what settings to use but the result will be fine.
                before
                after (hidden edges displayed)
                • W Offline
                  WRipley
                  thanks for this great Plugin.
                  But i have a problem.
                  I have a structure buil also with holes.
                  When i round the corners of the whole structure it closes
                  my holes on the side where i pushed the form thru the material.
                  I hope you know what i mean.
                  When i make a hole i start makin a circle on the Material.
                  Then i push the Circle thru the material that i get a hole.
                  Wehen i then try to round the corners the hole is on one side closed.
                  On the other side not.
                  Maybe it depends on me.
                  Or do you know that problem.
                  Thanks in advance
                  Best
                  Walter
                  • fredo6F Offline
                    Problem of closed holes is known but difficult to handle because it is Sketchup closing the hole automatically.
                    Just select the face over the hole and erase it. You should see the round corners underneath.
                    • W Offline
                      WRipley
                      Thanks for you fast answer.
                      But i dont know how to erase it. The Eraser tool dont function.
                      Im new in SU .... maybe its easy (think so)
                      What is an easy way to do it ?
                      atb
                      Walter
                      • fredo6F Offline
                        @wripley said:
                        But i don`t know how to erase it.
                        Normally, just select the face closing the hole and press Delete.
                        • E Offline
                          eastspringdt
                          Thanks! it works great!
                            martosurf
                            Is great thanks
                              arcitek
                              Someone may want to check into this but I found a conflict with podium 2 plugin and round corners. I had to work through almost 30 plugins to find this. It was on a friend's machine and we noticed he kept getting bugsplats as soon as he would activate round corners. I removed every plugin and started reinstalling every one of them and it crashed when I inserted the Podium 2 folder. Took the folder out, things were fine. Bummer.
                              • F Offline
                                flycase
                                Hi Fredo,
                                I'm trying to use Round Corner in SU8, but any time I will define a corner to round, for example a corner of a cube of 2000x2000x2000mm, Sketchup crashes and switch off..
                                is there a solution for this?
                                Tahnk You very much.
                                Paolo.
                                  A cube that size [2m] should be OK... BUT if you then specify a very small radius or excessively large numbers of segments Sketchup/OpenGL can't cope with the tiny faces [<~1mm/0.01sq"] and it fails - sometimes catastrophically. It occurs with many tools - even FollowMe...
                                  This tininess is exacerbated when already small rounded edges meet at corners and some 'quarter-hemispheres' are made to join them together, because they will probably have very small triangular facets at their apexes, which might then be 'too tiny' to be created !
                                  So I'm guessing that this could be the issue...
                                  Try it with a bigger radius and/or fewer segments and see if that works.
                                  If so, and you really must have such a tiny radius and/or many segments, you can get around it thus:
                                  Scale up the whole cube x10.
                                  Apply the edge-rounding [x10 bigger] to it, so this time the tiny face issue is avoided.
                                  When you are done you just Scale the cube with it's rounded edges down x0.1.
                                  Tiny edges can exist quite happily: it is just the creation of them that causes these issues...
                                  πŸ€“
                                  • F Offline
                                    flycase
                                    I tried to reduce corners, and tried do use an offset of 40mm on that cube, but no combination of parameters seems to work.. everytime I will try round corner to work sketcup closes down.
                                    Fredo scale works poerfectly.. but I'm starting to think that something is not installed in the right way.. is there a way to remove everything and to re-install?
                                      Works fine for me with 2m cube and 40mm radius, 6 segments.
                                      If you have many more segments it takes forever to process and eventually the facets will get too tiny at the apexes and won't be made, even 'splat'...Capture.PNGCapturex.PNGCapture1.PNG
                                      • F Offline
                                        flycase
                                        I installed Round edges by Bezier and it works.. I don't know if the calculation engine it's the same..
                                        Before this I experinced, one time only, that the tool (round Edge) run!! I started SU and built a cube, than applied the rounding to one edge without changing nothing (30mm offset..) and it worked it out.. after this everything workrd perfectly and no errors occurs during all the trials I made!!
                                        closed and reopened SU and again the tool crashed... I've neve been able to let the tool running...
                                        Paolo.
                                          How many segments does the rounding have ?
                                          • fredo6F Offline
                                            I would be careful to use this plugin which is quite old and which I don't really maintain (nice to see that it works).
                                            • RoundCorner includes all features of RoundEdges and is more stable.
                                            • The algorithms are also different: RoundCorner uses real arcs of circle (as well as Bezier curves), whereas RoundEdges is based on Bezier curve only.
                                            • RoundCorner does real rounding and treat concave corners. RoundEdge has only the 'sharp corner' method.
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 73
                                            • 74
                                            • 24 / 74
