    1.5k Posts 478 Posters 4.3m Views 478 Watching
      stoneshawnp
      @tig said:
      I have already told the Driving Dimensions author [Dmitry Ushakov] about the conflicts the tool has with other plugins about a month ago - the faults are on his side because he messes with base class/methods... It seemed OK in v8, but v7 was causing problems with a few tools [similar to SketchyPhysics] - but your problem occurs in v8 ? ...
      πŸ˜’
      Yes. Problem occurs in SU Pro 8 (installed on both Windows XP & Windows 7 machines).
      Thx
      Shawn
        JAI GOEL
        i am using google sketchup 8 i am not able to use this plugin in 8 version. how can i install that??
        thx
          Have you installed it as the instructions, with the supporting files etc, as explained on the download page ?
          If so why can't you 'use it'?
          Do you get Preferences>extension_to_activate/menu_items/view>toolbar>toolbar?
          Do you get error messages when using it?
          Do you get error messages in the Ruby Console when using it?
          Please give more details, to help us help you...
          • P
            Pitoon
            how can i get the icons back up...i closed them by accident? .......been trying for half an hour where to find them?
            thanks!
            • GaieusG
              If that's the plugin toolbar you closed, you can reactivate it from the View > Toolbars menu.
              • G
                greatoe
                I have problem running RoundCorner on my mac with OSX 10.7.2.
                Everything was fine on OSX 10.6.x, but after I "upgrade" to 10.7, RoundCorner hangs on processing. I have to force quit Sketchup.
                The following images are screen shots when RoundCorner hangs.
                RoundCorner v2.2, LibFredo6 v3.6, Sketchup Pro 8, Mac OSX Lion 10.7.2
                RoundCorner v2.3, LibFredo6 v3.7 or v4.2 (both act same), Sketchup Pro 8, Mac OSX Lion 10.7.2
                • fredo6F
                  greatoe
                  I'll have to count on Mac users to tell if they have this problem too (I don't have OSX Lion).
                  Just in case, can you open the Ruby Console before launching RoundCorner, in case you see some messages before Sketchup hangs.
                  • G
                    greatoe
                    greatoe
                    Hi Fredo,
                    Thanks for the reply.
                    Nothing show up in the Ruby Console.
                    greatoe
                      aea
                      hay
                      • massimoM
                        massimo Moderator
                        This is a possible workflow with SU's native tools supposing you already have a cone as a start.
                          aea
                          thanks , Another problem I found here
                          • GaieusG
                            From the picture it seems that those diagonals could be safely deleted. Try to run the plugin after that.
                            • fredo6F
                              @aea said:
                              hay
                              For rounding the tip of a cone, I suggest you use Massimo's method.
                              With RoundCorner, you can do the rounding, but:
                              1. you need to make the edges plain (i.e. non soft, non smooth)
                              2. the edges will be themselves rounded, which won't leave the surface of the cone smooth.
                              RoundCorner_Cone.gif]
                              • GaieusG
                                Also, for the cone, you can truncate the tip and apply round corner only on the top circle. It's a bit of a fiddling around what settings to use but the result will be fine.
                                before
                                after (hidden edges displayed)
                                • W
                                  WRipley
                                  thanks for this great Plugin.
                                  But i have a problem.
                                  I have a structure buil also with holes.
                                  When i round the corners of the whole structure it closes
                                  my holes on the side where i pushed the form thru the material.
                                  I hope you know what i mean.
                                  When i make a hole i start makin a circle on the Material.
                                  Then i push the Circle thru the material that i get a hole.
                                  Wehen i then try to round the corners the hole is on one side closed.
                                  On the other side not.
                                  Maybe it depends on me.
                                  Or do you know that problem.
                                  Thanks in advance
                                  Best
                                  Walter
                                  • fredo6F
                                    Problem of closed holes is known but difficult to handle because it is Sketchup closing the hole automatically.
                                    Just select the face over the hole and erase it. You should see the round corners underneath.
                                    • W
                                      WRipley
                                      Thanks for you fast answer.
                                      But i dont know how to erase it. The Eraser tool dont function.
                                      Im new in SU .... maybe its easy (think so)
                                      What is an easy way to do it ?
                                      atb
                                      Walter
                                      • fredo6F
                                        @wripley said:
                                        But i don`t know how to erase it.
                                        Normally, just select the face closing the hole and press Delete.
                                        • E
                                          eastspringdt
                                          Thanks! it works great!
                                            martosurf
                                            Is great thanks
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 74
                                            • 75
                                            • 23 / 75
