    1.5k Posts 478 Posters 4.3m Views 478 Watching
      @jai goel said:
      i am using google sketchup 8 i am not able to use this plugin in 8 version. how can i install that??
      Have you installed it as the instructions, with the supporting files etc, as explained on the download page ?
      If so why can't you 'use it'?
      Do you get Preferences>extension_to_activate/menu_items/view>toolbar>toolbar?
      Do you get error messages when using it?
      Do you get error messages in the Ruby Console when using it?
      Please give more details, to help us help you...
      • P
        Pitoon
        how can i get the icons back up...i closed them by accident? .......been trying for half an hour where to find them?
        thanks!
        • GaieusG
          If that's the plugin toolbar you closed, you can reactivate it from the View > Toolbars menu.
          • G
            greatoe
            I have problem running RoundCorner on my mac with OSX 10.7.2.
            Everything was fine on OSX 10.6.x, but after I "upgrade" to 10.7, RoundCorner hangs on processing. I have to force quit Sketchup.
            The following images are screen shots when RoundCorner hangs.
            RoundCorner v2.2, LibFredo6 v3.6, Sketchup Pro 8, Mac OSX Lion 10.7.2
            RoundCorner v2.3, LibFredo6 v3.7 or v4.2 (both act same), Sketchup Pro 8, Mac OSX Lion 10.7.2
            • fredo6F
              greatoe
              I'll have to count on Mac users to tell if they have this problem too (I don't have OSX Lion).
              Just in case, can you open the Ruby Console before launching RoundCorner, in case you see some messages before Sketchup hangs.
              • G
                greatoe
                greatoe
                Hi Fredo,
                Thanks for the reply.
                Nothing show up in the Ruby Console.
                greatoe
                  aea
                  hay
                  • massimoM
                    massimo Moderator
                    This is a possible workflow with SU's native tools supposing you already have a cone as a start.
                      aea
                      thanks , Another problem I found here
                      • GaieusG
                        From the picture it seems that those diagonals could be safely deleted. Try to run the plugin after that.
                        • fredo6F
                          @aea said:
                          hay
                          For rounding the tip of a cone, I suggest you use Massimo's method.
                          With RoundCorner, you can do the rounding, but:
                          1. you need to make the edges plain (i.e. non soft, non smooth)
                          2. the edges will be themselves rounded, which won't leave the surface of the cone smooth.
                          RoundCorner_Cone.gif]
                          • GaieusG
                            Also, for the cone, you can truncate the tip and apply round corner only on the top circle. It's a bit of a fiddling around what settings to use but the result will be fine.
                            before
                            after (hidden edges displayed)
                            • W
                              WRipley
                              thanks for this great Plugin.
                              But i have a problem.
                              I have a structure buil also with holes.
                              When i round the corners of the whole structure it closes
                              my holes on the side where i pushed the form thru the material.
                              I hope you know what i mean.
                              When i make a hole i start makin a circle on the Material.
                              Then i push the Circle thru the material that i get a hole.
                              Wehen i then try to round the corners the hole is on one side closed.
                              On the other side not.
                              Maybe it depends on me.
                              Or do you know that problem.
                              Thanks in advance
                              Best
                              Walter
                              • fredo6F
                                Problem of closed holes is known but difficult to handle because it is Sketchup closing the hole automatically.
                                Just select the face over the hole and erase it. You should see the round corners underneath.
                                • W
                                  WRipley
                                  Thanks for you fast answer.
                                  But i dont know how to erase it. The Eraser tool dont function.
                                  Im new in SU .... maybe its easy (think so)
                                  What is an easy way to do it ?
                                  atb
                                  Walter
                                  • fredo6F
                                    @wripley said:
                                    But i don`t know how to erase it.
                                    Normally, just select the face closing the hole and press Delete.
                                    • E
                                      eastspringdt
                                      Thanks! it works great!
                                        martosurf
                                        Is great thanks
                                          arcitek
                                          Someone may want to check into this but I found a conflict with podium 2 plugin and round corners. I had to work through almost 30 plugins to find this. It was on a friend's machine and we noticed he kept getting bugsplats as soon as he would activate round corners. I removed every plugin and started reinstalling every one of them and it crashed when I inserted the Podium 2 folder. Took the folder out, things were fine. Bummer.
                                          • F
                                            flycase
                                            Hi Fredo,
                                            I'm trying to use Round Corner in SU8, but any time I will define a corner to round, for example a corner of a cube of 2000x2000x2000mm, Sketchup crashes and switch off..
                                            is there a solution for this?
                                            Tahnk You very much.
                                            Paolo.
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 74
                                            • 75
                                            • 23 / 75
