    The "Duh!" thread (aka the Doh! thread)
    696 Posts 135 Posters 622.4k Views 135 Watching
    • gillesG
      gilles
      Did you know this one?
      • dereiD
        derei
        AWESOME !!! ๐Ÿ˜ฒ This is something I never would guess. Thank you! ๐Ÿ˜‰
        DESIGNER AND ARTIST DEREI.UK
        • gillesG
          gilles
          works also with polygones.
          Rereading the user manuel is fully instructive.
          • B
            brandy20
            ๐Ÿ˜ฎ another one to add yo the list of my uncountables duh! in the last two years...
            Another big duh! for me, to realize just yesterday evening of this very instructing topic. Must surf more carefully through this forum. ๐Ÿ˜ณ
            • jeff hammondJ
              ๐Ÿ˜ฒ
              no.. i didn't.
              that's pretty sweet.. now, i'm left wondering if i have a use for it ๐Ÿ˜„
              • daleD
                dale
                This one was new to me (Doh)
                I was doing a lot of similar push pulls on a model (without joint pushpull), and inadvertently double clicked on the second one, and SketchUp duplicated the depth of the first pushpull.
                So i just went along double clicking, and the action repeated itself exactly.
                Boy could I ever have used this alot.
                  Works the same for Offset too - double-click repeats the last used value...
                    Now double click the middle mouse button ๐Ÿ˜‰
                    • GaieusG
                      But double click on something.
                      • cottyC
                        cotty
                        I've learned a lot from this thread and here is my little "Duh!"...
                        Textures of different (coplanar) faces can be combined (context menu - combine textures (?, don't know the english translation of the menu)) if they are preselected.
                        Because the inner lines can be deleted, this reduces the file size (e.g. for google earth models).
                        "Make unique texture" reduces file size too (textures are trimmed).
                        my SketchUp gallery
                        • GaieusG
                          Yes, especially this second one is extremely important for GE modelling. I think it was introduced in version 7 and was very welcome (although the AA algorithm could be better as the resulting textures are rather bad quality)
                          • Wo3DanW
                            Wo3Dan
                            Yes, I knew it worked on arc surfaces.
                            But I didn't realize that it also works on cilinders (on a cardinal midpoint to resize it) until now.
                            It even works on a truncated cone's cardinal midpoints "Doh!"
                            b.t.w. The "arc surface midpoint moving" feature also works with two different arcs, top arc unequals bottom arc. I guess this is similar to being able to resize the truncated cone in "one go".
                              A vicious one! ๐Ÿ˜ฎ By the complicity of John H. Aughey & Wiiki โ˜€
                              Solution ! ๐Ÿ’š
                              Used first Erase Inner faces ! ๐Ÿ˜’
                              • P
                                pingo
                                Thank you, Thank you, Thank you!!
                                It's taken me a few days to read through this thread and practise all the many things I didn't know before. So many helpful tips will surely make my future modelling so much easier!
                                • onzkiO
                                  onzki
                                  One for me was when Gaieus was from Gaieus' talk at the Basecamp (I saw the video) and using the rotate tool.
                                  When you click the rotate tool and click the rotation point, don't let go of the mouse button... drag it out to either red or green (or any other snap point you set up) then click to start. This relieves any need for a vertical plane to get your rotation set up.
                                  See image for example.
                                  [attachment=0:1opsd1fn]<!-- ia0 -->ClickHold.jpg<!-- ia0 -->[/attachment:1opsd1fn]
                                  I have been using SU since V2 and never knew that until last year.
                                  This is one of my biggest Duh as well ๐Ÿ˜„ It's almost a year before I discovered it- by Accident! ๐Ÿ˜„ Before, I first do new axis, then rotate.. I've read the thread above, it's so funny and informative especially when I read things that I encountered, reminding me that I'm not alone:)
                                  [/hr]Dell Alienware Area-51. SKU 2021 Pro. AutoCAD 2023. Landscape design firm
                                  • onzkiO
                                    onzki
                                    @d12dozr said:
                                    You can use the Move tool on the cardinal points to change the radius of an extruded circle as well
                                    This is amazing! It's like working in 3DSmax edit poly mode haha
                                    • onzkiO
                                      onzki
                                      Okay my latest Duh might be not very helpful to everyone as compared with above mentioned Duh's.. but for those who forgot it- "turning on/off Hidden geometry" from view menu helps you edit a smoothened surface. Imagine I even posted a thread on wishlist requesting for un-smoothen or anti-smooth plugin lol ๐Ÿ˜„.
                                      • C
                                        cordless101
                                        My Duh! When you have started a new model from scratch, autosavewill work only after you have saved and named the file yourself first.
                                        • C
                                          cordless101
                                          I just noticed that when orbiting with the wheel, if you hold down the left button it turns to pan. I really like that, don't have to use the keyboard to pan.
                                          • plot-parisP
                                            plot-paris
                                            Wow, I really have to try that!
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 34
                                            • 35
                                            • 15 / 35
