    The "Duh!" thread (aka the Doh! thread)
    696 Posts 135 Posters 622.4k Views 135 Watching
      Being able to select only a few edges from a face and offset them instead of the whole face.
      Yes but edges must be selected without discontinuity! ๐Ÿ˜ณ ๐Ÿ˜ณ ๐Ÿ˜ณ
      • boofredlayB
        boofredlay
        Something I just learned a couple days ago while studying the Google Earth Modeling videos.
        D'oh, never knew that you could make a unique texture from a portion of another!
        [flash=853,505:84crs2i3]http://www.youtube.com/v/18r2sCMUSBU&fs=1[/flash:84crs2i3]
        • DanielD
          Daniel
          I've always known about hiding geometry by holding the shift key with the eraser, but last week I just noticed the "hidden" check box on the entity info window. ๐Ÿ˜ณ
          My avatar is an anachronism.
          • Bob JamesB
            Bob James
            Never paid any attention to this thread until today ๐Ÿ˜ณ
            @tig said:
            .....select all faces with the same material as the one highlighted... then RickW pointed out that it is already a standard built-in tool under Select... ๐Ÿ˜ณ
            OMG ๐Ÿ˜ฒ I soooo needed this yesterday ๐Ÿ‘Š
            This thread is one of the greatest tutorials ever made!
            Now to Page 1 and read (and write down) all of the golden nuggets in this thread.
              Jim
              Yeah, this thread would make a great mini-pub for SCF. I'd probably even buy a tree-ware version as I can't retain online info as well as I can with a good sit with a book.
                Seems only from the V7 and + ๐Ÿ˜‰
                • Bob JamesB
                  Bob James
                  SU Duh.pdfCompilation of DUHs
                  This is an unedited regurgitation of all of the DUH items. Some are repeated.
                    Cool idea! ๐Ÿ˜Ž
                    I will translate it when I arrive at this page! ๐Ÿ˜„ (in fact a sort of speedy copy / past because ...
                    I am now at the page 7 on French Section ! ๐Ÿ’š
                    • dereiD
                      derei
                      What the... ๐Ÿ˜ฒ?
                      6.I could change the radius of a circle that's been extruded - maybe using Scale Tool ๐Ÿ˜•
                      19. finding that by holding the spacebar down you can control the zoom in so you don't zip past the
                      object your zooming to
                      - really ? It doesn't seem to happen anything different when I zoom and keep spacebar pressed.
                      ...and the list can continue.
                      Maybe those should be verified, or given more detailed explanations. After all, its purpose is to teach the noobs, not to confuse them more ๐Ÿ’š
                      EDIT:
                      22. Also, any selection that only contains a single entity (not only a line) cannot be made a
                      component (or group) this way. If you select a sphere (with a bounding box), there's a single
                      "surface" selected only and you right click to turn it into a group/component in vain.
                      - try pressing G or use the Make Component icon ... ๐Ÿ˜‰ maybe is not in vain
                      DESIGNER AND ARTIST DEREI.UK
                      • GaieusG
                        1. Also, any selection that only contains a single entity (not only a line) cannot be made a
                          "surface" selected only and you right click to turn it into a group/component in vain. - try pressing G or use the Make Component icon ... maybe is not in vain
                        That's true - thus the inconsistency. SU should work the same way no matter where we access the same tool.
                        • H
                          HFM
                          Found out last week that you can also color lines in your model ๐Ÿ˜ฒ
                          It even works with custom drawing styles ๐Ÿ˜„
                          Colored lines ^^
                          • jeff hammondJ
                            What the... ๐Ÿ˜ฒ?
                            you can change the radius via the entity info dialog.. the same way you would change the radius of a circle except that it also works if the circle has been extruded
                            • dereiD
                              derei
                              Heh, that's cool ๐Ÿ˜„ Inattentional blindness is to blame... I've seen that number of segments is grayed-out, and I didn't seen that the radius is fully editable.
                                you have a crazzy plug about that! ๐Ÿ˜‰
                                ChrisP_Color_edge By C Plassais ๐Ÿ˜Ž
                                  d12dozr
                                  What the... ๐Ÿ˜ฒ?
                                  You can use the Move tool on the cardinal points to change the radius of an extruded circle as well
                                  Nifty!
                                  http://goo.gl/f7ooYh
                                  • gillesG
                                    gilles
                                    Did you know this one?
                                    • dereiD
                                      derei
                                      AWESOME !!! ๐Ÿ˜ฒ This is something I never would guess. Thank you! ๐Ÿ˜‰
                                      • gillesG
                                        gilles
                                        works also with polygones.
                                        Rereading the user manuel is fully instructive.
                                        • B
                                          brandy20
                                          ๐Ÿ˜ฎ another one to add yo the list of my uncountables duh! in the last two years...
                                          Another big duh! for me, to realize just yesterday evening of this very instructing topic. Must surf more carefully through this forum. ๐Ÿ˜ณ
                                          • jeff hammondJ
                                            ๐Ÿ˜ฒ
                                            no.. i didn't.
                                            that's pretty sweet.. now, i'm left wondering if i have a use for it ๐Ÿ˜„
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 34
                                            • 35
                                            • 15 / 35
