    The "Duh!" thread (aka the Doh! thread)
    696 Posts 135 Posters 295.9k Views 135 Watching
    • david_hD Offline
      david_h
      I've been taken to task just now on this one. . . I asked for a plugin to toggle the Construction lines on and off. . .turns out it's in the view menu. . .
      WHICH I NEVER USE BY THE WAY!!!!
      Hide Construction lines
      This is so humiliating. . .. 😳 πŸ’š
      I'm okay now. . .
        Jim
        I just learned that Edit > Delete Guides is context-sensitive - it deletes guides all guides starting from the current editing context and deeper, but not from "higher" level contexts. I had always thought it always deleted all guides, everywhere.
          I had that same realization a couple of weeks ago. πŸ˜„
            @rv1974 said:
            If Thom is already here..
            Only last week I discovered know that double clicking on blue balloons (edge tools-inspect gaps) actually close the gaps.
            Great tool!
            Ah, yea it's not that obvious - I had further plans for the UI. (also for CleanUp), but they've been down-prioritized.
            btw, no need to doubleclick - single click is enough.
              rv1974
              Only last week I discovered that double clicking on blue balloons (edge tools-inspect gaps) actually close the gaps.
              Great tool!
                Doh. 😲
                What???!!! πŸŽ‰
                  Being able to select only a few edges from a face and offset them instead of the whole face.
                  Yes but edges must be selected without discontinuity! 😳 😳 😳
                  • boofredlayB Offline
                    boofredlay
                    Something I just learned a couple days ago while studying the Google Earth Modeling videos.
                    D'oh, never knew that you could make a unique texture from a portion of another!
                    [flash=853,505:84crs2i3]http://www.youtube.com/v/18r2sCMUSBU&fs=1[/flash:84crs2i3]
                    • DanielD Offline
                      Daniel
                      I've always known about hiding geometry by holding the shift key with the eraser, but last week I just noticed the "hidden" check box on the entity info window. 😳
                      My avatar is an anachronism.
                      • Bob JamesB Offline
                        Bob James
                        Never paid any attention to this thread until today 😳
                        @tig said:
                        .....select all faces with the same material as the one highlighted... then RickW pointed out that it is already a standard built-in tool under Select... 😳
                        OMG 😲 I soooo needed this yesterday πŸ‘Š
                        This thread is one of the greatest tutorials ever made!
                        Now to Page 1 and read (and write down) all of the golden nuggets in this thread.
                          Jim
                          Yeah, this thread would make a great mini-pub for SCF. I'd probably even buy a tree-ware version as I can't retain online info as well as I can with a good sit with a book.
                            Seems only from the V7 and + πŸ˜‰
                              Bob James
                              SU Duh.pdfCompilation of DUHs
                              This is an unedited regurgitation of all of the DUH items. Some are repeated.
                                Cool idea! 😎
                                I will translate it when I arrive at this page! πŸ˜„ (in fact a sort of speedy copy / past because ...
                                I am now at the page 7 on French Section ! πŸ’š
                                • dereiD Offline
                                  derei
                                  What the... 😲?
                                  6.I could change the radius of a circle that's been extruded - maybe using Scale Tool πŸ˜•
                                  19. finding that by holding the spacebar down you can control the zoom in so you don't zip past the
                                  object your zooming to
                                  - really ? It doesn't seem to happen anything different when I zoom and keep spacebar pressed.
                                  ...and the list can continue.
                                  Maybe those should be verified, or given more detailed explanations. After all, its purpose is to teach the noobs, not to confuse them more πŸ’š
                                  EDIT:
                                  22. Also, any selection that only contains a single entity (not only a line) cannot be made a
                                  component (or group) this way. If you select a sphere (with a bounding box), there's a single
                                  "surface" selected only and you right click to turn it into a group/component in vain.
                                  - try pressing G or use the Make Component icon ... πŸ˜‰ maybe is not in vain
                                    1. Also, any selection that only contains a single entity (not only a line) cannot be made a
                                      "surface" selected only and you right click to turn it into a group/component in vain. - try pressing G or use the Make Component icon ... maybe is not in vain
                                    That's true - thus the inconsistency. SU should work the same way no matter where we access the same tool.
                                    • H Offline
                                      HFM
                                      Found out last week that you can also color lines in your model 😲
                                      It even works with custom drawing styles πŸ˜„
                                      Colored lines ^^
                                      • jeff hammondJ Offline
                                        What the... 😲?
                                        you can change the radius via the entity info dialog.. the same way you would change the radius of a circle except that it also works if the circle has been extruded
                                        • dereiD Offline
                                          derei
                                          Heh, that's cool πŸ˜„ Inattentional blindness is to blame... I've seen that number of segments is grayed-out, and I didn't seen that the radius is fully editable.
                                            you have a crazzy plug about that! πŸ˜‰
                                            ChrisP_Color_edge By C Plassais 😎
                                            • 34
                                            • 35
                                            • 3 / 35
