    The "Duh!" thread (aka the Doh! thread)
    696 Posts 135 Posters 652.0k Views 135 Watching
    • spenceS
      spence
      One of my many many "Duh" moments came when I found out that while using the Paint Bucket Tool you could hold down Shift to paint all that match or hold Ctrl to paint all connected. I use this often.
      Boy I have learned a lot of new stuff from this thread πŸ˜„
      Spence
      • ToboboT
        Tobobo
        Using the Entity Ifon box you can increase the length of a line
        In what side? Good or false? πŸ˜„
        The changes its length in the same direction it has been drawn. it has to be unattached at one end, and that is the end the lengthens or shortens.
        Toby
        Philippians 4:13
          Jim
          Has any one here also thought of compiling/organizing this thread into a more readable format? Wiki? Print?
          • pyrolunaP
            pyroluna
            well... there's a sketchup-wiki in Dutch... so... yay! for Dutch people
              Jim
              Today I learned you can use the arrow keys to precisely move the selection in Paint.NET. (Holding Ctrl moves it by 10 pixels.)
              • GaieusG
                I just realised it the other day myself, too. πŸ˜„
                • david_hD
                  david_h
                  I've been taken to task just now on this one. . . I asked for a plugin to toggle the Construction lines on and off. . .turns out it's in the view menu. . .
                  WHICH I NEVER USE BY THE WAY!!!!
                  Hide Construction lines
                  This is so humiliating. . .. 😳 πŸ’š
                  I'm okay now. . .
                    Jim
                    I just learned that Edit > Delete Guides is context-sensitive - it deletes guides all guides starting from the current editing context and deeper, but not from "higher" level contexts. I had always thought it always deleted all guides, everywhere.
                      I had that same realization a couple of weeks ago. πŸ˜„
                        @rv1974 said:
                        If Thom is already here..
                        Only last week I discovered know that double clicking on blue balloons (edge tools-inspect gaps) actually close the gaps.
                        Great tool!
                        Ah, yea it's not that obvious - I had further plans for the UI. (also for CleanUp), but they've been down-prioritized.
                        btw, no need to doubleclick - single click is enough.
                          rv1974
                          Only last week I discovered that double clicking on blue balloons (edge tools-inspect gaps) actually close the gaps.
                          Great tool!
                          • GaieusG
                            Doh. 😲
                            What???!!! πŸŽ‰
                              Being able to select only a few edges from a face and offset them instead of the whole face.
                              Yes but edges must be selected without discontinuity! 😳 😳 😳
                              • boofredlayB
                                boofredlay
                                Something I just learned a couple days ago while studying the Google Earth Modeling videos.
                                D'oh, never knew that you could make a unique texture from a portion of another!
                                [flash=853,505:84crs2i3]http://www.youtube.com/v/18r2sCMUSBU&fs=1[/flash:84crs2i3]
                                • DanielD
                                  Daniel
                                  I've always known about hiding geometry by holding the shift key with the eraser, but last week I just noticed the "hidden" check box on the entity info window. 😳
                                  My avatar is an anachronism.
                                  • Bob JamesB
                                    Bob James
                                    Never paid any attention to this thread until today 😳
                                    @tig said:
                                    .....select all faces with the same material as the one highlighted... then RickW pointed out that it is already a standard built-in tool under Select... 😳
                                    OMG 😲 I soooo needed this yesterday πŸ‘Š
                                    This thread is one of the greatest tutorials ever made!
                                    Now to Page 1 and read (and write down) all of the golden nuggets in this thread.
                                      Jim
                                      Yeah, this thread would make a great mini-pub for SCF. I'd probably even buy a tree-ware version as I can't retain online info as well as I can with a good sit with a book.
                                        Seems only from the V7 and + πŸ˜‰
                                        • Bob JamesB
                                          Bob James
                                          SU Duh.pdfCompilation of DUHs
                                          This is an unedited regurgitation of all of the DUH items. Some are repeated.
                                            Cool idea! 😎
                                            I will translate it when I arrive at this page! πŸ˜„ (in fact a sort of speedy copy / past because ...
                                            I am now at the page 7 on French Section ! πŸ’š
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 34
                                            • 35
                                            • 14 / 35
