    The "Duh!" thread (aka the Doh! thread)
    696 Posts 135 Posters 579.8k Views 135 Watching
    • pyrolunaP
      pyroluna
      well... there's a sketchup-wiki in Dutch... so... yay! for Dutch people
        Jim
        Today I learned you can use the arrow keys to precisely move the selection in Paint.NET. (Holding Ctrl moves it by 10 pixels.)
        • GaieusG
          I just realised it the other day myself, too. πŸ˜„
          • david_hD
            david_h
            I've been taken to task just now on this one. . . I asked for a plugin to toggle the Construction lines on and off. . .turns out it's in the view menu. . .
            WHICH I NEVER USE BY THE WAY!!!!
            Hide Construction lines
            This is so humiliating. . .. 😳 πŸ’š
            I'm okay now. . .
              Jim
              I just learned that Edit > Delete Guides is context-sensitive - it deletes guides all guides starting from the current editing context and deeper, but not from "higher" level contexts. I had always thought it always deleted all guides, everywhere.
                I had that same realization a couple of weeks ago. πŸ˜„
                  @rv1974 said:
                  If Thom is already here..
                  Only last week I discovered know that double clicking on blue balloons (edge tools-inspect gaps) actually close the gaps.
                  Great tool!
                  Ah, yea it's not that obvious - I had further plans for the UI. (also for CleanUp), but they've been down-prioritized.
                  btw, no need to doubleclick - single click is enough.
                    rv1974
                    Only last week I discovered that double clicking on blue balloons (edge tools-inspect gaps) actually close the gaps.
                    Great tool!
                    • GaieusG
                      Doh. 😲
                      What???!!! πŸŽ‰
                        Being able to select only a few edges from a face and offset them instead of the whole face.
                        Yes but edges must be selected without discontinuity! 😳 😳 😳
                        • boofredlayB
                          boofredlay
                          Something I just learned a couple days ago while studying the Google Earth Modeling videos.
                          D'oh, never knew that you could make a unique texture from a portion of another!
                          [flash=853,505:84crs2i3]http://www.youtube.com/v/18r2sCMUSBU&fs=1[/flash:84crs2i3]
                          • DanielD
                            Daniel
                            I've always known about hiding geometry by holding the shift key with the eraser, but last week I just noticed the "hidden" check box on the entity info window. 😳
                            My avatar is an anachronism.
                            • Bob JamesB
                              Bob James
                              Never paid any attention to this thread until today 😳
                              @tig said:
                              .....select all faces with the same material as the one highlighted... then RickW pointed out that it is already a standard built-in tool under Select... 😳
                              OMG 😲 I soooo needed this yesterday πŸ‘Š
                              This thread is one of the greatest tutorials ever made!
                              Now to Page 1 and read (and write down) all of the golden nuggets in this thread.
                                Jim
                                Yeah, this thread would make a great mini-pub for SCF. I'd probably even buy a tree-ware version as I can't retain online info as well as I can with a good sit with a book.
                                  Seems only from the V7 and + πŸ˜‰
                                  • Bob JamesB
                                    Bob James
                                    SU Duh.pdfCompilation of DUHs
                                    This is an unedited regurgitation of all of the DUH items. Some are repeated.
                                      Cool idea! 😎
                                      I will translate it when I arrive at this page! πŸ˜„ (in fact a sort of speedy copy / past because ...
                                      I am now at the page 7 on French Section ! πŸ’š
                                      • dereiD
                                        derei
                                        What the... 😲?
                                        6.I could change the radius of a circle that's been extruded - maybe using Scale Tool πŸ˜•
                                        19. finding that by holding the spacebar down you can control the zoom in so you don't zip past the
                                        object your zooming to
                                        - really ? It doesn't seem to happen anything different when I zoom and keep spacebar pressed.
                                        ...and the list can continue.
                                        Maybe those should be verified, or given more detailed explanations. After all, its purpose is to teach the noobs, not to confuse them more πŸ’š
                                        EDIT:
                                        22. Also, any selection that only contains a single entity (not only a line) cannot be made a
                                        component (or group) this way. If you select a sphere (with a bounding box), there's a single
                                        "surface" selected only and you right click to turn it into a group/component in vain.
                                        - try pressing G or use the Make Component icon ... πŸ˜‰ maybe is not in vain
                                        DESIGNER AND ARTIST DEREI.UK
                                        • GaieusG
                                          1. Also, any selection that only contains a single entity (not only a line) cannot be made a
                                            "surface" selected only and you right click to turn it into a group/component in vain. - try pressing G or use the Make Component icon ... maybe is not in vain
                                          That's true - thus the inconsistency. SU should work the same way no matter where we access the same tool.
                                          • H
                                            HFM
                                            Found out last week that you can also color lines in your model 😲
                                            It even works with custom drawing styles πŸ˜„
                                            Colored lines ^^
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 34
                                            • 35
                                            • 14 / 35
