    [Plugin] FollowMe and keep (v0.04 update 20090210)
    223 Posts 79 Posters 224.0k Views 79 Watching
      Tim,
      I'm flattered by your comments. It wasn't a test. Well, it was a test for me.
      I finally figured it out. The path needs to be basically horizontal. I didn't see anything in the thread that indicates this, though every example I saw was thus. Even so, it doesn't really do what I need anyway so I'm off on the hunt for another approach.
      • mitcorbM
        mitcorb
        Well, Dave:
        When you say basically horizontal do you mean mostly horizontal or dead flat path, or profile horizontal? I vaguely remember the demos and I may be getting it confused with Chris Fullmer's perpendicular faces tool.
          Sorry for being vague. I turned the helix on its side so its axis was along the green axis. This turned the square profile up on edge as well. I initially use Chris Fullmer's Perpendicular Face Tools to put the square on the end of the helix while the helix was standing up. that worked just fine.
            Sir.Swaffel
            I like this tool, but it is lacking a basic feature that 1001bit's version does have: a reference point.
            FollowMeAndKeep automatically uses the center of the face that it wants to extrude as the reference point for the path. When using a more complex face that needs to be extruded along a path relative to let's say the bottom left corner, you're out of luck πŸ˜•
              It's good to have the option of using 1001bit, isn't it?
                Sir.Swaffel
                haha, yes, unfortunately 1001bit lacks a feature that FollowMeAndKeep does have, it doesn't lock the z orientation. So basically both of them lacks an essential feature of the other... and I don't know a way to combine them πŸ˜„.
                comparison
                  I suppose for FaK you could add some temporary geometry to get the bottom left corner to be the center. Not idea but it could work.
                  • W
                    wikii
                    Reference point?
                    select a cpoint ,curve and face,then run fak.
                    the cpoint will be treat as reference poing.
                    try it.
                    wikii
                      Sir.Swaffel
                      ah thanks, it never worked when I tried it, so I thought it was broken. But apparently my SU has some trouble making correct faces with FAK and complex curves and precise helixes. Got it working now though, so thx πŸ˜„.
                      • dereiD
                        derei
                        I'm trying to run FAK on a face + path but it doesn't o anything.
                        Can anyone point me where I'm wrong? I tried with a simpler shape (arc + rectangle) and it worked. Is it something wrong with this particular model?
                        Model attached. Thank you.
                        no_FAK.skp
                        DESIGNER AND ARTIST DEREI.UK
                          The extrude edges familly by Tig must make the trick πŸ˜‰
                          • gillesG
                            gilles
                            @ dereei, rotate the whole model so the face isn't horizontal and it works.
                            I suggest to separate your path in two parts to avoid strange results.
                              destroyer1095
                              ITS NOT WORKING FOR SKETCH UP 8!!!!! 😑 πŸ‘Ž
                              • GaieusG
                                Yes it is - and please, do not use ALL CAPS on the forums.
                                A "not working" remark will never help trouble shooting what you are doing wrong. First of all, did you install it correctly?
                                • dereiD
                                  derei
                                  is working ! read the previous post! I'm sure you used a path that was vertically aligned.
                                    How ironic is his nickname...? πŸ˜’
                                      Nice entrance to the forum. πŸ˜’
                                        MartinK
                                        ASS
                                          JMdesigns
                                          cant get this to work sor SU8 ?...any updates
                                            Works fine on SU8 for me.
                                            If you want help, why not help us help you and give us some information about what's happening? Post an example SKP or something. πŸ˜’
                                            • 11
                                            • 12
                                            • 8 / 12
