    [Plugin] FollowMe and keep (v0.04 update 20090210)
    223 Posts 79 Posters 224.0k Views 79 Watching
    • B
      Blomman
      The hidden geometry was indeed off, now it works perfectly. Thanks! ๐Ÿ˜„
        Sir
        this plugin has just saved me hours. i love you.
        image attached. each side of the stairs is a different curve... pain in the ass.Spatial.jpg
        • marvins_dadM
          marvins_dad
          Just wanted to say Thanks again!
          I had lost the ruby and someone helped me find this one again...it is amazing for stairs! ๐Ÿ‘
          My Gallery
            dmonahan96
            So I installed the followme and keep plugin and it worked great on the first railing that I used it for but now it keeps crashing my SU every time i try it with this other section. Any suggestions?
              shoeb_cars
              google should really learn some good stuff like this...thanks man ๐Ÿ‘
                So what am I missing? I've read through as much of this thread as I could. I can get FAK to work on simple arcs but not on this longer path. Even though it's not supposed to require it, I added a C-point to the start end of the path. Surely I've done something that isn't right. Can anyone tell me what it is?
                FAK Problem.skp
                • mitcorbM
                  mitcorb
                  Weld- Don't Weld? Group- Don't Group? This is a test, right?
                  Plugin "deprecation" due to Sketchup version?
                  I mean, when you're stumped, we're in hell.
                    Tim,
                    I'm flattered by your comments. It wasn't a test. Well, it was a test for me.
                    I finally figured it out. The path needs to be basically horizontal. I didn't see anything in the thread that indicates this, though every example I saw was thus. Even so, it doesn't really do what I need anyway so I'm off on the hunt for another approach.
                    • mitcorbM
                      mitcorb
                      Well, Dave:
                      When you say basically horizontal do you mean mostly horizontal or dead flat path, or profile horizontal? I vaguely remember the demos and I may be getting it confused with Chris Fullmer's perpendicular faces tool.
                        Sorry for being vague. I turned the helix on its side so its axis was along the green axis. This turned the square profile up on edge as well. I initially use Chris Fullmer's Perpendicular Face Tools to put the square on the end of the helix while the helix was standing up. that worked just fine.
                          Sir.Swaffel
                          I like this tool, but it is lacking a basic feature that 1001bit's version does have: a reference point.
                          FollowMeAndKeep automatically uses the center of the face that it wants to extrude as the reference point for the path. When using a more complex face that needs to be extruded along a path relative to let's say the bottom left corner, you're out of luck ๐Ÿ˜•
                            It's good to have the option of using 1001bit, isn't it?
                              Sir.Swaffel
                              haha, yes, unfortunately 1001bit lacks a feature that FollowMeAndKeep does have, it doesn't lock the z orientation. So basically both of them lacks an essential feature of the other... and I don't know a way to combine them ๐Ÿ˜„.
                              comparison
                                I suppose for FaK you could add some temporary geometry to get the bottom left corner to be the center. Not idea but it could work.
                                • W
                                  wikii
                                  Reference point?
                                  select a cpoint ,curve and face,then run fak.
                                  the cpoint will be treat as reference poing.
                                  try it.
                                  wikii
                                    Sir.Swaffel
                                    ah thanks, it never worked when I tried it, so I thought it was broken. But apparently my SU has some trouble making correct faces with FAK and complex curves and precise helixes. Got it working now though, so thx ๐Ÿ˜„.
                                    • dereiD
                                      derei
                                      I'm trying to run FAK on a face + path but it doesn't o anything.
                                      Can anyone point me where I'm wrong? I tried with a simpler shape (arc + rectangle) and it worked. Is it something wrong with this particular model?
                                      Model attached. Thank you.
                                      no_FAK.skp
                                      DESIGNER AND ARTIST DEREI.UK
                                        The extrude edges familly by Tig must make the trick ๐Ÿ˜‰
                                        • gillesG
                                          gilles
                                          @ dereei, rotate the whole model so the face isn't horizontal and it works.
                                          I suggest to separate your path in two parts to avoid strange results.
                                            destroyer1095
                                            ITS NOT WORKING FOR SKETCH UP 8!!!!! ๐Ÿ˜ก ๐Ÿ‘Ž
                                            • 11
                                            • 12
                                            • 7 / 12
