    [Plugin] QuadFaceTools
    680 Posts 116 Posters 744.9k Views 116 Watching
      πŸ‘
      I want to play too 😞
      Where'd you get that UV Map?
        Made it myself. I use it in my template where I have replaced the Googlers with a 1x1x1m standard metric UV mapped cube. πŸ˜„
        UV Mapping Test Tile
        • EarthMoverE
          EarthMover
          Nice work with the UV idea. Just so I understand, once you are able to establish the orientation via the quad distribution, you can then use a larger map over the entire surface and have it distribute evenly? It's not going to just scale the texture per the quad boundaries, correct? If it's doing what I think, it's bloody brilliant! πŸ‘
          Content Creator at Skapeup
          • StinkieS
            Stinkie
            Wait, wait ... just woke up, so let me see if I got this right ... no more distorted textures?
              That is correct. But there are limitations to the topology though. It must be free of poles. ( http://blenderartists.org/forum/showthread.php?93651-Poles-and-Loops&p=849794&viewfull=1#post849794 )
              Not necessarily, mapping a planar quad with edges not parallel to each other will result in a distorted texture. One the other hand, if you triangulate it, then the mapping of the two triangles in the quad be skewed instead of distorted. And that will lead to less problems with render engines.
                Version 0.4.0
                Important!
                This version redefines what a QuadFace is. In order to use quad face meshes used by older versions you must update them.
                Tools > QuadFace Tools > Convert > Sandbox Quads to QuadFace Quads
                Download
                Changelog 0.4.0
                UV Mapping
                [flash=560,315:23wd2kgt]http://www.youtube.com/v/HdX517AryWs?version=3&hl=en_US[/flash:23wd2kgt]
                UV Transferring
                [flash=560,315:23wd2kgt]http://www.youtube.com/v/qQHsabwvErg?version=3&hl=en_US[/flash:23wd2kgt]
                UV Unwrap
                [flash=560,315:23wd2kgt]http://www.youtube.com/v/hnW_yjkM_SY?version=3&hl=en_US[/flash:23wd2kgt]
                  That is immense.
                  I commend your hard work and perseverance πŸ‘
                  • dereiD
                    derei
                    As I recall, you have (at least) two more plugins that do some related stuff. Does it replace any of them? I'm asking to know if I should remove something from what I already have.
                    Thank you for this one.
                    DESIGNER AND ARTIST DEREI.UK
                      Is a portion of the UV Toolkit 2 tools now redundant?
                        Thanks thomthom πŸ˜„
                        I've also updated and posted my 'EEbyRails' and 'EEbyLoft' tools today so that their new 'Quad Face' options follow the latest standards, where diagonals are soft+smooth+hidden...
                          Yea, parts of the features in UV Toolkit is now in QuadFace. And the mapping tool I promised for UV Toolkit is now implemented in QuadFace Tools, because I found that mapping required a predictable topology.
                          UV Toolkit is not 100% obsolete yet, but it might slowly become so. I don't expect I'll add more to UV Toolkit, instead QuadFace Tools will get the new features.
                          However, I now plan to take a break from QuadFace Tools ( final last words... ) while I return focus on Vertex Tools and Bezier Surface. (Both which will benefit from many of the features in QuadFace Tools.)
                            Wow! That was fast! πŸ‘ πŸ‘
                            • GaieusG
                              Sensational, TT. Now I can make my Arch texturing tutorial #3! 😍
                                Looking forward to it!
                                  jorge2011
                                  thank you very much for this excellent update. is excellent.
                                  unfortunately I have a problem:). sketchup generates the following error:
                                  Error al cargar archivo C:/Archivos de programa/Google/Google SketchUp 8/Plugins/TT_QuadFaceTools/core.rb
                                  undefined method to_l' for nil:NilClassError al cargar archivo tt_quadface.rb undefined method to_l' for nil:NilClass
                                  how I can fix this?
                                    how I can fix this?
                                    When do you get this error?
                                      jorge2011
                                      when I start sketchup
                                        What version of TT_Lib2 do you have?
                                          jorge2011
                                          the last version
                                            jorge2011
                                            is odd. install this plugin yesterday and worked well.
                                            Today I went back to start and generated that error sketchup
                                            • 33
                                            • 34
                                            • 3 / 34
