    [Plugin] QuadFaceTools
    680 Posts 116 Posters 644.5k Views 116 Watching
    • fredo6F Offline
      Tom,
      All my support for your initiative, which is, I believe a big undertaking.
      As a contribution, I'll include an option to generate quads (under your definition) in Curviloft (the preview display is based on quads, precisely).
        πŸ‘ πŸ‘
        That's great Fredo! The more tools we get that generate geometry like this the better topology we can create in SketchUp with better tools.
        • PixeroP Offline
          Pixero
          This will be most useful. Thanks!
            Booman
            Awesome plugin... will definitely try out for some organic modeling
            Brian McCracken
            In The Red Website Design
            • EarthMoverE Offline
              EarthMover
              Been playing with it and it's really great. Thanks again. Been playing with Artisan meshes with some mixed results, but after a few Make Quad operations, I can get the whole mesh to quadrify.
              Any plans on adding a Ring Connect option as a way to add additional loops?
              Content Creator at Skapeup
                I meant to make a whole video tutorial for that. It's best not to make the starting point at the edge of a mesh. That might yield some odd results. And holes in the mesh might also produce unexpected results. And I suspects meshes where the quads are not uniformly laid out, but need star connections could throw some odd results as well.
                If you find that the quadification of a mesh yields odd results it might help if you manually quadify some of mesh first. A couple of quads around holes and star connections.
                Got any sample models to share by the way. I did not have any organic models with regular mesh to test on.
                What is a Ring Connect?
                  Perhaps an idea to request Dale to add an option to generate the mesh as quads? That'd be pretty sweet.
                    What's the icon at the end of Vertex Tools? I don't have it in mine?
                      Cursed your keen eyes! Now I have to kill you!
                        @gaieus said:
                        Holy crap, TT. I saw you post in the (other) forum to Pete and was wondering. Good news is that I seem to have some spare space in my toolbars...
                        By the way Gaieus, with meshes build from quads, making UV tools becomes easier.
                        It was in fact one of the biggest challenges I had/have with UV Toolkit, being able to sort the geometry into predictable chunks. Now I can build upon the requirement that the mesh is quads, which makes the traversing of the mesh and mapping much easier. πŸ˜‰
                          Mwah ha hah hah hah haaaaaaa πŸ‘Ώ
                            Just for the sake for retaliation and mute your excitement, it's simply a Collapse function. So there! Hah! No magic!
                              In reality it's a function to call upon all my killer robots to home in on Rich - as you can see from the iconic representation. Yes, that is right, I'm giving everyone who buts Vertex Tools this mighty power! muhahahah!
                                I'll use my Chuck Norris plugin πŸ‘Š
                                Too extreme to release on this forum it's only for double hard bastards πŸ‘
                                  EarthMover
                                  It's fundamental for creating support edges for hard subdivision surfaces and to model organic surfaces while still maintaining quads. In Max, the Edit Poly Connect, gives you options to also slide and spread the loops along the width of the edge ring in order to "weight" the edges, define creases, etc. In Sketchup, you could always move a copy of a loop, but on an organic surface it doesn't always line up right. Even a simple option to connect edge rings at the midpoints would be helpful.
                                    Ah - Edge Connect - gotcha!
                                    Yea, that would be a nice function.
                                    • boofredlayB Offline
                                      boofredlay
                                      Thanks for this Thomas.
                                        Daniel S
                                        Thank you Thomas!!!
                                        A question: Is there a way to force the vertices of the quad to be coplanar?
                                        If a quad consist of two triangles rotate this two triangles until they lay on the same plane and then delete the shared edge. Is that possible?
                                        Daniel S
                                          Yes, though, it'd also distort the connected faces.
                                          (Vertex Tools let you do that - Make Planar)
                                          • mitcorbM Offline
                                            mitcorb
                                            Elementary question:
                                            What is the difference between a ring and a loop? I couldn't seem to figure out the images, or why one is called a ring and one is called a loop.
                                            • 33
                                            • 34
                                            • 1 / 34
