    How to make screw threads?
    30 Posts 20 Posters 61.5k Views 20 Watching
      RootlessAgrarian
      I gave Screw 2.3 a try but so far am puzzled by it. This version does not offer an entry box for the offset, just a step count and number of turns. I am always getting zero offset -- it just "smears" the shape around into a torus.
      I had a look at the source code and though I don't speak Ruby, I got the impression that it was somehow inferring the offset from the geometry of the shape to be smeared -- some kind of slope derived from an edge orthogonal to the axis of the lathing operation. Can anyone confirm?
      Nothing is 'mere'. -- Richard Feynman
      • N
        NewOne
        @driven said:
        I'll put up a tutorial if anyone wants..
        YES, please! πŸ˜„
          driven
          haven't sorted screen casting out yet, but I found screw1.5.rb is the most stable on my mac.
          it appears to be the same as described in the PDF tutorial for screw2 (http://www.crai.archi.fr/RubyLibraryDepot/Ruby/screw2_1_tutorial.pdf)
          Offset is determined by the distance your profile is drawn from the blue axis so construct at origin, in free space.
          Use a new page/layer/or hide/move whatever is there already and make it a group or component for further use.
          • W
            watkins
            You might find these thread textures useful.
            http://forums.sketchucation.com/viewtopic.php?f=40&t=11378&hilit=+threads
            They are not perfect, but do the job and are low poly. The attached drawing used the textures.
            Regards,
            Bob
              ALWX65
              This is something I really want to learn. Is there a video anywhere showing exactly how to do it? All I want to do is show the threaded portion of a bolt sticking out the back of a nut.
              ALW
                archiasdomesticus
                From what I can tell the scripts on that are referenced in this thread (screw, k_tools) are no longer available on at http://www.crai.archi.fr. Have they been moved?
                What plugins are still available to help with drawing screw threads?
                Thanks,
                Jim
                  The Ruby Depot moved here
                  http://rhin.crai.archi.fr/RubyLibraryDepot/Ruby/RUBY_Library_Depot.htm
                  It's in transition... You can still find the files but the Search function is broken... as it's looking at the old links...
                  e.g. k_tools http://rhin.crai.archi.fr/RubyLibraryDepot/Ruby/EM/k_tools_50.rb
                    aea
                    no manage ?
                    screw.skp
                      Here's how to use this plugin....
                      Step 1
                      As your bolt has a diameter of 225cm you need to place your thread profile 112.5cm from origin...
                      Step 2
                      Now double click your thread profile and select Plugins>Screw, at this stage you need to choose a start point and an end point. I chose the bottom of the profile as the start point and the top as the end point...
                      Step 3
                      Your bolt was a circle made of 24 segments therefore your thread needs to mimic this for optimum fit so insert 24 into the Step box and choose a whole number for the turns to allow you to align threads afterwards...
                      Step 4
                      Click OK and wait.........
                      Now you can select your thread and align it to your bolt. This is a basic method of achieving what you need. But you could also align your bolt at the origin at the beginning and then apply the steps.
                      The only thing that may change is the dimensions of your threads/lead/pitch which depends on whether it's UNC or UNF
                      Anyway, here's my version to look at...
                      screw.skp
                      • liquid98L
                        liquid98
                        Look here:
                        http://sketchup.google.com/3dwarehouse/details?mid=76063a259e3aec4abf52def0e259b9b0&prevstart=0
                        Things that flourish fall into decay. This is not-Tao, And what is not-Tao soon ends ~ Lao tse
                          Roger
                          Reminds me of the building I passed on the way home this morning. It was the "Pilgrim Screw Company". It seems like a straight line looking for a joke.
                          http://www.azcreative.com
                          • gillesG
                            gilles
                            Here they are.
                            EDIT: screw1_5 is in fact screw3.0, screw_2.1 is an earlier version.
                            screw1_5.rb
                            screw_21.rb
                            • brookefoxB
                              brookefox
                              Thread title should perhaps refer to bolt thread, which I am happy to learn about, but I am looking for screw thread.
                              ~ Brooke
                                Roger
                                • K
                                  KE6CVH
                                  Hi Gilles, I just downloaded both attachments from your post April 17 2010 and laast edited Mar8 2010. I have them showing up in my plugins when opening sketchup 8 but can't see them in the file folder, kind of strange. One shows up as "screw" and the other as "screw 21". What I need is a tutorial as I don't have the slightest clue how to use them. When I click on the tutorial link on this discussion it brings me to the ruby depot library homepage and if I look under A-Z I can only see the download that doesn't work and no tutorial. Best regards, Mike
                                  • gillesG
                                    gilles
                                    Screw1_5.rb is the one you need (screw in plugins window)
                                    Have a look at Rich's tutorial:
                                    http://sketchucation.com/forums/viewtopic.php?p=245701#p245701
                                    • wimveW
                                      wimve
                                      @rich o brien said:
                                      Hello,
                                      Was looking for this today. Works like a charm ! Thanks.
                                      Best regards,
                                      Wim
                                      Holland
                                      http://www.petromax.nl/DeBeer.html
                                      • O
                                        Oliveros
                                        I'm the last guy to the party. I'm trying to figure this out for 3d printing. Is the plugin used in the example the "Screw_21.RB" and "Screw 1_5.rb" links that were posted?
                                          The v1.5 RB file is the newest one [unfortunately it was misnamed by its author ! as explained in an earlier post...]
                                          Download it, and manually put that .RB file into your [hidden] Plugins folder, alternatively you can ZIP it and then add .RBZ to the end of the ZIP file, to change its file-type.
                                          Then you can install that RBZ, using the native Install Extension processes...
                                          The tutorial referenced in this thread covers how to use it...
                                          This post might also be of interest...
                                          http://sketchucation.com/forums/viewtopic.php?p=654151#p654151
                                          • HumpmetwiceH
                                            Humpmetwice
                                            Draw Whorl??
                                            SketchUp Extension Warehouse
                                            Your library of custom third-party extensions created to optimize your SketchUp workflow.
                                            (extensions.sketchup.com)
