    How to make screw threads?
    30 Posts 20 Posters 61.5k Views 20 Watching
      driven
      My pleasure,
      I've only been teaching myself SU for the last 3-4 weeks (have dabbled in the past) so as to make animated model of a device I'm designing.
      It involves lots of moving springs and threads so I been trying all sorts of rubies out to try and get a good look with as low a poly count as I can,
      heres a thead I did with arc tool, skin.rb and xformcllone.rb
      and there's one using simpleloft.rb at that subject
      away working for a few days, will have a tidy of my screen cast when I get back, my lack of speed and basic skills makes me cringe when I watch, but the workflows are pretty good.
      this is low'ish poly count
      10 sec. render
        Roger
        Just a thought regarding your goals. How important is the screw thread in your render? If the screw or bolt is the subject of your render, then all the foregoing suggestion by other members of the forum are valid. However, the purpose of the render is to show a device that is far more important than the screw sub components, I have found that a bit map of horizontal lines (like corrugated metal roofing reduced in scale)can be applied to machine screws, bolts or threaded holes can produce a very convincing render and still remain low poly.
        It is all a matter of perception. If the screws are you product or will be seen in extreme close up, then model them. If the roles of the screws is a secondary item to a far more important product, then I say fake them.
        http://www.azcreative.com
          RootlessAgrarian
          I gave Screw 2.3 a try but so far am puzzled by it. This version does not offer an entry box for the offset, just a step count and number of turns. I am always getting zero offset -- it just "smears" the shape around into a torus.
          I had a look at the source code and though I don't speak Ruby, I got the impression that it was somehow inferring the offset from the geometry of the shape to be smeared -- some kind of slope derived from an edge orthogonal to the axis of the lathing operation. Can anyone confirm?
          Nothing is 'mere'. -- Richard Feynman
          • N
            NewOne
            @driven said:
            I'll put up a tutorial if anyone wants..
            YES, please! πŸ˜„
              driven
              haven't sorted screen casting out yet, but I found screw1.5.rb is the most stable on my mac.
              it appears to be the same as described in the PDF tutorial for screw2 (http://www.crai.archi.fr/RubyLibraryDepot/Ruby/screw2_1_tutorial.pdf)
              Offset is determined by the distance your profile is drawn from the blue axis so construct at origin, in free space.
              Use a new page/layer/or hide/move whatever is there already and make it a group or component for further use.
              • W
                watkins
                You might find these thread textures useful.
                http://forums.sketchucation.com/viewtopic.php?f=40&t=11378&hilit=+threads
                They are not perfect, but do the job and are low poly. The attached drawing used the textures.
                Regards,
                Bob
                  ALWX65
                  This is something I really want to learn. Is there a video anywhere showing exactly how to do it? All I want to do is show the threaded portion of a bolt sticking out the back of a nut.
                  ALW
                    archiasdomesticus
                    From what I can tell the scripts on that are referenced in this thread (screw, k_tools) are no longer available on at http://www.crai.archi.fr. Have they been moved?
                    What plugins are still available to help with drawing screw threads?
                    Thanks,
                    Jim
                      The Ruby Depot moved here
                      http://rhin.crai.archi.fr/RubyLibraryDepot/Ruby/RUBY_Library_Depot.htm
                      It's in transition... You can still find the files but the Search function is broken... as it's looking at the old links...
                      e.g. k_tools http://rhin.crai.archi.fr/RubyLibraryDepot/Ruby/EM/k_tools_50.rb
                        aea
                        no manage ?
                        screw.skp
                          Here's how to use this plugin....
                          Step 1
                          As your bolt has a diameter of 225cm you need to place your thread profile 112.5cm from origin...
                          Step 2
                          Now double click your thread profile and select Plugins>Screw, at this stage you need to choose a start point and an end point. I chose the bottom of the profile as the start point and the top as the end point...
                          Step 3
                          Your bolt was a circle made of 24 segments therefore your thread needs to mimic this for optimum fit so insert 24 into the Step box and choose a whole number for the turns to allow you to align threads afterwards...
                          Step 4
                          Click OK and wait.........
                          Now you can select your thread and align it to your bolt. This is a basic method of achieving what you need. But you could also align your bolt at the origin at the beginning and then apply the steps.
                          The only thing that may change is the dimensions of your threads/lead/pitch which depends on whether it's UNC or UNF
                          Anyway, here's my version to look at...
                          screw.skp
                          • liquid98L
                            liquid98
                            Look here:
                            http://sketchup.google.com/3dwarehouse/details?mid=76063a259e3aec4abf52def0e259b9b0&prevstart=0
                            Things that flourish fall into decay. This is not-Tao, And what is not-Tao soon ends ~ Lao tse
                              Roger
                              Reminds me of the building I passed on the way home this morning. It was the "Pilgrim Screw Company". It seems like a straight line looking for a joke.
                              • gillesG
                                gilles
                                Here they are.
                                EDIT: screw1_5 is in fact screw3.0, screw_2.1 is an earlier version.
                                screw1_5.rb
                                screw_21.rb
                                • brookefoxB
                                  brookefox
                                  Thread title should perhaps refer to bolt thread, which I am happy to learn about, but I am looking for screw thread.
                                  ~ Brooke
                                    Roger
                                    • K
                                      KE6CVH
                                      Hi Gilles, I just downloaded both attachments from your post April 17 2010 and laast edited Mar8 2010. I have them showing up in my plugins when opening sketchup 8 but can't see them in the file folder, kind of strange. One shows up as "screw" and the other as "screw 21". What I need is a tutorial as I don't have the slightest clue how to use them. When I click on the tutorial link on this discussion it brings me to the ruby depot library homepage and if I look under A-Z I can only see the download that doesn't work and no tutorial. Best regards, Mike
                                      • gillesG
                                        gilles
                                        Screw1_5.rb is the one you need (screw in plugins window)
                                        Have a look at Rich's tutorial:
                                        http://sketchucation.com/forums/viewtopic.php?p=245701#p245701
                                        • wimveW
                                          wimve
                                          @rich o brien said:
                                          Hello,
                                          Was looking for this today. Works like a charm ! Thanks.
                                          Best regards,
                                          Wim
                                          Holland
                                          http://www.petromax.nl/DeBeer.html
                                          • O
                                            Oliveros
                                            I'm the last guy to the party. I'm trying to figure this out for 3d printing. Is the plugin used in the example the "Screw_21.RB" and "Screw 1_5.rb" links that were posted?
