    1.3k Posts 299 Posters 2.7m Views 297 Watching
      The climate is changing it to one intermediate state...
        Norway is turning into the UK ???
        We don't have a Climate/Seasons, we just have Weather...
          Yea - we have a whole year worth of seasons in 30 minutes. Pretty much how I remember England to be like when I lived there. Just a bit colder and a tad more snow.
          • jgbJ Offline
            jgb
            In Canada, except for the left coast, we get winter then a coupla nice days.
            Badum boom πŸ˜†
            In Toronto, if you don't like the weather, just wait a few hours.
            Badum boom πŸ˜†
            Not kidding. 6 weeks ago the furnace was on, then 2 days later the air con was on for 4 days, then a week and a half of torrential rain and thunderstorms. Then the furnace was back on for 2 days, then it became almost nice out.
            Garfield says it best.....
            jgb
            • fredo6F Offline
              Thanks to all for being beta testers between the 26th and 27th.πŸ˜„
              So the release should be OK by now!!
              • jeff hammondJ Offline
                finally had a chance to try the new one out and..
                .. that's awesome how you can do this (obtaining the curves) using loft instead of skinning now.
                i thought you might of just changed the skinning part of curviloft but being able to get the mean curves via loft (without the need for the extra set-up lines) is really sweet.
                thanks for the update!
                  One more thing, Fredo (certainly I could also edit it but that's just a last resort). In the first post, you write Curviloft 1.1a and below you can download 1.1b. This may cause confusion.
                  • fredo6F Offline
                    NEW RELEASE: Curviloft 1.1c - 29 Jun 11
                    Curviloft version 1.1b introduced the generation of mean curves between contours.
                    There was however a bug, signaled by Defisto, when contours are closed loops.
                    Version 1.1c fixes this issue
                    See main post for download
                      And this does be again the case?
                      Curviloft plugin is still released in BETA
                      • fredo6F Offline
                        Pilou,
                        There is no doc yet and there are many missing features (and probably many bugs).
                        So I won't call it an official release!
                        • F Offline
                          fiors
                          Hi. Great plugin!
                          I do have one question/concern. I'm trying to use it for a curved railing. The profile is obviously not a perfect circle so it twists along the bezier. Is there a more effective way or different plugin to prevent the twisting and have the profile maintain some universal orientation?
                          Thank you!
                          S
                            Follow and Keep?
                            • jason_marantoJ Offline
                              jason_maranto
                              Profile Builder also may work for your needs.
                              Best,
                              Jason.
                                Best,
                                Jason.
                                PB performs a follow me operation and will twist.
                                  mac1
                                  FAK keep will not twist but does not keep elevation in 100% of cases. 1001 bit tools will work. It has a free eval period that you my want to check it out...
                                  Clarification: FAK elevation comes into play when you go over a "hill" and for railing this should not be an issue 😳
                                    rjjvirusx
                                    Thank you & I need learn some more~!
                                      tutu7931
                                      good tool man, thanks for sharing!!
                                        lapx
                                        I've tried it as well. Thanks Fredo for such a wonderful tool. Can you get it to maintain a sharp edge? I noticed it round the corners. Would be nice to have this as an option if available.
                                          clmene
                                          only amazing ....
                                            TrisQ
                                            Fredo, this tool is brilliant. Thank you so much. I am using it for 3D Printing, and the one issue I am struggling with are "holes" in the shells, that make the resulting STL files cause trouble in the further printing process. Do you have any advice on how to avoid such tiny holes, or what situations to avoid that are prone to causing them? Thanks, TrisQ
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 65
                                            • 66
                                            • 25 / 66
