    1.3k Posts 299 Posters 2.9m Views 297 Watching
    • jeff hammondJ Offline
      @hygicell said:
      my other plugins work fine
      WindowTools.rb
      ZLoader__OnSurface.rb
      zone.rb
      according to that list, all your other plugins aren't working fine..
      you're missing the ZLoader files that come with many of fredo's plugins.. the only one you have is tools on surface but i suspect your round corner, curviloft, and fredoscale aren't working either (amongst others?)
        First:
        Only the the files inside the subfolders that have equivalents wrongly installed in the Plugins folder are to be removed... from the Plugins folder...
        What you did is correct.
        Second:
        You do seem to have several Zloader .rb files missing from that Plugins folder - like Zloader_Curviloft.rb - this might be the root cause of your problem - do you perhaps have them in another folder that might also be on your $LOAD_PATH ?
        And then they can't load other files are the paths gets tangled up...
        Did you get the $LOAD_PATH in the Ruby Console ?
        Mine says ["C:/Program Files/Google/Google SketchUp 8/Plugins", "C:/Program Files/Google/Google SketchUp 8/Tools"] yours should also include the H: path ?
        ..\Plugins\LIBFREDO6_Dir_37\Lib6Core_37.rb; line#225; txt = "T6 = Traductor::T6Mod.new(#{hmod}, '#{path}', '#{rootname}') "
        line#226; hmod.module_eval txt
        This is the code that sets the constant T6 to have a certain value and typing in the Ruby Console
        Curviloft::T6
        should show this, which is a Traductor::T6Mod object used to translate between languages; it is complex looking list of code, elements, hashes etc...
        It seems that ..\Plugins\LIBFREDO6_Dir_37\Lib6Core_37.rb is not being run properly...
        Does the file exist ?
        If so are it's properties set so 'you' can see it and read it etc...?
        Trying typing load LIBFREDO6_Dir_37\Lib6Core_37.rb + <enter> into the Ruby Console and see if it returns true and if CurviLoft then works... it'll only be a temporary fix but at least we then step on one pace...
        If you type this in the Ruby Console +<enter> what is returned ?
        Sketchup.find_support_file("Plugins")
        I get
        You must include the H: path to your Plugins... otherwise Fredo's LibFredo6.rb will fail at lines#26/27
        require 'LibTraductor.rb' if Sketchup.find_support_file( 'LibTraductor.rb', "Plugins" )#Compatibility require 'TOS_Dir_13/LibTraductor_20.rb' if Sketchup.find_support_file( 'TOS_Dir_13/LibTraductor_20.rb', "Plugins" )#Compatibility
        Otherwise when it doesn't find these files they are not loaded and so the T6 constant never gets defined...
        You could rewrite those two lines using a plain-test editor like Notepad[++].exe - as
        require 'LibTraductor.rb' if File.exist?(File.join(File.dirname(__FILE__), 'LibTraductor.rb'))#Compatibility require 'TOS_Dir_13/LibTraductor_20.rb' if File.exist?(File.join(File.dirname(__FILE__), TOS_Dir_13, LibTraductor_20.rb)#Compatibility
        I think the second one is not important as the first one gets loaded anyway...
        Now it will always load the files found relative to it even on some obscure drive, rather than the default C:...
        • H Offline
          hygicell
          WindowTools.rb
          zone.rb
          [attachment=0:ia8g6goq]<!-- ia0 -->screen 2011-06-25 at 10.54.52 AM.jpg<!-- ia0 -->[/attachment:ia8g6goq]
          I had those and the Fredo plugins did't work then
          as a test I removed them as I thought they were redundant
          I will have to reinstall
          have you seen any files I have to remove?
          Frank
            Do you have another folder Sketchup with some stuff in it, say on the C:drive for example...
            Is Curviloft somehow trying to load even when its Zloader is removed ??
            Have you read through my last diatribe... ❓
            • jgbJ Offline
              jgb
              i can skin that thing with zero problems.
              i think you might be using the wrong tool.. i think you're trying to use curviloft's Skinning when you should be using regular Loft (the first of the 3 icons in the toolbar)
              just select the two rings then click on the Loft icon.
              And Right you are! 😳
              I guess I was so used to skinning my constructs I just forgot about the other 2 functions.
              Thanks. πŸ‘
              jgb
              • fredo6F Offline
                NEW RELEASE: Curviloft 1.1b - 27 Jun 11
                This is a small upgrade to handle the problem of mean curves between contours.
                Previous versions were only able to generate the junction curves. This one adds the intermediate curves. And you get the mesh by selecting both options.
                Thanks to Jeff Hammond for the suggestion to use Curviloft for generate mean curves between contours
                See also discussion at this post on the question of mean curves.
                See main post for download
                  Thanks Fredo. πŸ‘ πŸ‘ πŸ‘
                  It seems to be such an important release however that it travelled faster than light and arrived the previous day... πŸ˜†
                  (You are in the same time zone as me if I am not mistaken)
                    Thomthom also lost [gained?] a day earlier today!
                    Perhaps there's a time-warp out and about πŸ˜’
                      Yeh see?! It's just you lot still stuck behind in yesterday! Keep with the time!
                        Maybe Earth's axis are moving during the night! β˜€
                        • jgbJ Offline
                          jgb
                          There is a simple explanation for the time warp. Fredo, whom I believe resides in France, simply sent the update Eastward to us and when it crossed the Pacific Date line, voila, it is tomorrow. 🀣
                          Besides, Curviloft can save you far more than a day's work, so the time warp is justified. 😍
                          jgb
                            And of course in Norway they only have two days Summer and Winter...
                              The climate is changing it to one intermediate state...
                                Norway is turning into the UK ???
                                We don't have a Climate/Seasons, we just have Weather...
                                  Yea - we have a whole year worth of seasons in 30 minutes. Pretty much how I remember England to be like when I lived there. Just a bit colder and a tad more snow.
                                  • jgbJ Offline
                                    jgb
                                    In Canada, except for the left coast, we get winter then a coupla nice days.
                                    Badum boom πŸ˜†
                                    In Toronto, if you don't like the weather, just wait a few hours.
                                    Badum boom πŸ˜†
                                    Not kidding. 6 weeks ago the furnace was on, then 2 days later the air con was on for 4 days, then a week and a half of torrential rain and thunderstorms. Then the furnace was back on for 2 days, then it became almost nice out.
                                    Garfield says it best.....
                                    jgb
                                    • fredo6F Offline
                                      Thanks to all for being beta testers between the 26th and 27th.πŸ˜„
                                      So the release should be OK by now!!
                                        finally had a chance to try the new one out and..
                                        .. that's awesome how you can do this (obtaining the curves) using loft instead of skinning now.
                                        i thought you might of just changed the skinning part of curviloft but being able to get the mean curves via loft (without the need for the extra set-up lines) is really sweet.
                                        thanks for the update!
                                          One more thing, Fredo (certainly I could also edit it but that's just a last resort). In the first post, you write Curviloft 1.1a and below you can download 1.1b. This may cause confusion.
                                          • fredo6F Offline
                                            NEW RELEASE: Curviloft 1.1c - 29 Jun 11
                                            Curviloft version 1.1b introduced the generation of mean curves between contours.
                                            There was however a bug, signaled by Defisto, when contours are closed loops.
                                            Version 1.1c fixes this issue
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 65
                                            • 66
                                            • 25 / 66
