    Villa PM maxwell render and process
    19 Posts 13 Posters 2.3k Views 13 Watching
    • jamalitoJ Offline
      jamalito
      😲 _ 😲
      okey okey I want to believe that is render not real photo
      breath . breath . breath
      wow great work really I thought you are speaking to really pic not render go head man I wish you more successful
      I wish to find like this tutorial because I have problem in make final render
      Albert Einstein:
      ((I am enough of an artist to draw freely upon my imagination. Imagination is more important than knowledge. Knowledge is limited. Imagination encircles the world.))
        cadmunkey
        David, can you tell me where you got the background from? Is it purchased?
          davidh
          I have attached the 2 dirt maps i used in photoshop.I will upload a more detailed tutorial later but basically what I do is copy the dirtmap image into the rendered image in photoshop and use the distort tool (EDIT -TRANSFORM -DISTORT in the pull down menu)to align it over the area I want to grunge up.I then use the overlay blend and set this to about 40 -60% and thats it.If you do this with multiple textures in the same area you can really start to build up interesting textures.
          Regarding the background,it was a free download, a very hi res jpg .(sky 0008)
          the website http://vknt.be/free/skies/
          • HieruH Offline
            Hieru
            Thanks for the explanation. I didn't think it would be that simple - I assumed it would involve creating grunge brushes and using a technique to over paint in perspective.
            www.davidhier.co.uk
              cadmunkey
              Thanks for sharing the resource David.
              • marked001M Offline
                marked001
                very impressive post processing here, david... really impressed!
                http://www.revision21vis.com
                instagram: revi21on
                  davidh
                  Heres one with some additional foreground elements and a very dead tree!
                  • RichardR Offline
                    Richard
                    Stunning work AGAIN mate!
                    Just wondering though why you don't add the dirt as a layer to the materials prior to rendering? I pretty much add a dirt layer to every material.
                    Also not so sure about the car in this one, they seem out of place in a ruins shot!
                    BUILTBRAND.COM.AU
                      davidh
                      Hi Rich,
                      The main reason I didnt add dirt maps in maxwell is because I was originally just playing about with the HDRI lighting and when I had the photoshop file open I decided to play around with the textures as well.The car does look a bit out of place but its really there to catch reflections on the bodywork and glass,just to help to accentuate the contrasts with the materials.I have attached 2 more images here.As I said before its a great model to test render with but its all about the lighting for me at the moment.
                      • jarynzlesaJ Offline
                        jarynzlesa
                        super method πŸ‘ thx for sharing πŸ‘ . im looking forward to your next work.
                        http://www.vizualizaceschodiste.mypage.cz/
                        • RichardR Offline
                          Richard
                          Well ten points for that - the lighting is superbe!!!
                          BUILTBRAND.COM.AU
                          • omiKronO Offline
                            omiKron
                            Whoa, Maxwell rocks ! Looks so real πŸ‘ And the post work in Ps makes it more real πŸŽ‰
                            • Bryan KB Offline
                              whoa
                              The second one of the last series is superb.
                              • X Offline
                                xaideoe
                                Do you have any tutorials or reference to add dirt to the maxwell material? Cause I am trying to achieve a nice and realistic look with materials layer layers but I can't..
                                • DanielD Offline
                                  Daniel
                                  beautiful images, David
                                  My avatar is an anachronism.
                                  • FrederikF Offline
                                    Frederik
                                    πŸ˜†
                                    Not that it really matter, but take a look at the dates...
                                    This thread is back from June 2011... πŸ˜„
                                    Cheers
                                    Kim Frederik
