    [Plugin][$] Tools On Surface - v2.6a - 01 Apr 24
    638 Posts 203 Posters 1.6m Views 202 Watching
    • H Offline
      hebeijianke
      Just in case, this may come from the fact that in your configuration, the Chinese language is defined with CN, not ZH.
      The original file is defined with ZH.
      Could you check what is the local language by typing Sketchup.get_locale in the Ruby console.
      It Is still displayed incorrectly
        There are several common two-part locale code LCID strings [the 'code' and 'LCID string' can vary] - e.g.
        Chinese (simplified) - ZH-CN
        Chinese (traditional) - ZH-TW
        English (UK) - EN-GB
        English (US) - EN-US
        Portuguese (Brazil) - PT-BR
        Portuguese (Portugal) - PT-PT
        Some of them like EN-GB are no longer implemented by Google, as we are now lumped in with America under EN-US...
          Diggsey
          This plugin is exceptionally useful!
          A couple of minor bugs:
          Sometimes, if you draw a circle or ellipse over a hard edge, the curve will be divided into more than two parts. The plugin needs to start and end the curve at one of the intersections with the hard edge to prevent it. Also, the drawing tools seem to make duplicate faces occasionally. Oddly this seems to happen often on flat surfaces.
            dynath
            Ok, i'm not sure if this is possible but I am wondering if it is possible to make a line drawing and paste it onto a 3d surface using these tools. I basicly want to draw a logo in sketchup, paste it onto a curved surface before manipulating the various thicknesses on it to make it 3D.
            any ideas?
            • mitcorbM Offline
              mitcorb
              It seems you would have to import the line drawing as a .dxf, or .obj. Or import as an image and place it on a flat drawn surface and trace over it. Do whatever cleanup or closure is necessary on the flat drawing. Using the Sandbox tools, your curved surface being the TIN(triangulated irregular network?), you then Drape the line drawing onto the curved surface.
                deanlegg
                Can anyone tell my whats happening with the arc tool here
                The corner of the smile is all distorted
                  RizkySyahputra
                  HI i'm a using SU8PRO. why in my pc after i was installed Tools on surface it appear an error loading plugin?? ❓
                    Did you also install the LibFredo Library as is instructed in the first post?
                      d12dozr
                      Its a known bug, see this and the next few posts http://forums.sketchucation.com/viewtopic.php?p=308756#p308756
                      http://goo.gl/f7ooYh
                      • H Offline
                        huckrorick
                        thank you. Thank You. THANK YOU!!
                        I haven't tried all the tools but the Freehand on Surface (without inference) is something I have been praying for, for a long time. Inference was constantly making tracing things or making freehand lines with small movements incredibly slow and frustrating. This is a godsend.
                        I wish I knew a better way to thank you.
                        Huck
                          Huck
                          You could make a generous PayPal donation to Fredo - details are in his submenus 😄
                            slimaczysko
                            THX my friend ! Perfect tool ! I use it to many project ! THX AGAIN 😄
                            Some of my works and photos... http://slimaczysko.digart.pl/digarty/
                              jorge2011
                              I have a small problem with a geometry.
                              The sides of the circle does not coincide.
                              Is this normal? It is possible to fix it?
                              regards
                                jorge2011
                                image correction
                                http://forums.sketchucation.com/download/file.php?mode=view&id=71839
                                • fredo6F Offline
                                  @jorge2011 said:
                                  image correction
                                  Jorge
                                  I don't see the image
                                    jorge2011
                                    see the file
                                    01.skp
                                    • fredo6F Offline
                                      Jorge,
                                      When you draw the circle, try to align the radius on the existing grand arc of the sphere.
                                      But anyway TOS will not consider your sphere in any specific way as it expects to work on any kind of surface.
                                        You're still not seeing the animated screenshot? He is in fact aligning and snapping to the arc of the sphere.
                                        • fredo6F Offline
                                          ToolsOnSurface is only an approximation tool.
                                          In this precise case, the sum of angles at the pole of the sphere is slightly under 360 degrees, whereas TOS generates circles on a base of 360 degree total, as if it was drawing on a plane.
                                          This explains the slight discrepancy for segments generated.
                                          Unfortunately, as mentioned, TOS does not make assumptions on particular situations like this one.
                                            jorge2011
                                            Mr. Fred thanks for the reply.
                                            Just a clarification.
                                            If I make a flat circle and the sphere 3d project, the sides if they match.
                                            The problem with TOS tool is that the edges are not equal.
                                            to fix, I can draw with sketchup tools and project the circle or use the tool offset of TOS.
                                            greetings and thank you very much:
                                            • 31
                                            • 32
                                            • 5 / 32
