    [Plugin][$] Tools On Surface - v2.6a - 01 Apr 24
    638 Posts 203 Posters 1.9m Views 202 Watching
    • H
      hebeijianke
      I am a Chinese user
      When I use this plug-in
      The Chinese in the display area is not displayed correctly
      Can You check what is the reason
      • fredo6F
        @hebeijianke said:
        I am a Chinese user
        I don't know. Apparently the translation in the lang file appears to be correct for "length" and "angle" at least on my version 1.8. Can you please check in ToolsOnSurface > Language Translation....
        Does the 'wrong' text means something in Chinese, and if so, what does it means?
        Is this the only occurence of translation problems?
        Also, do you use TOS version 1.8 or an earlier version?
        • H
          hebeijianke
          @hebeijianke said:
          I'm using version 1.8a
          The text displayed is not Chinese
          There are several situations can not be displayed properly
          I do not known the reason
          The Translation is Correct
          • fredo6F
            Just in case, this may come from the fact that in your configuration, the Chinese language is defined with CN, not ZH.
            The original file is defined with ZH.
            Could you check what is the local language by typing Sketchup.get_locale in the Ruby console.
            • G
              g863210
              THANK YOU! IT IS POWERFUL! 😍
              • H
                hebeijianke
                It Is still displayed incorrectly
                  There are several common two-part locale code LCID strings [the 'code' and 'LCID string' can vary] - e.g.
                  Chinese (simplified) - ZH-CN
                  Chinese (traditional) - ZH-TW
                  English (UK) - EN-GB
                  English (US) - EN-US
                  Portuguese (Brazil) - PT-BR
                  Portuguese (Portugal) - PT-PT
                  Some of them like EN-GB are no longer implemented by Google, as we are now lumped in with America under EN-US...
                    Diggsey
                    This plugin is exceptionally useful!
                    A couple of minor bugs:
                    Sometimes, if you draw a circle or ellipse over a hard edge, the curve will be divided into more than two parts. The plugin needs to start and end the curve at one of the intersections with the hard edge to prevent it. Also, the drawing tools seem to make duplicate faces occasionally. Oddly this seems to happen often on flat surfaces.
                      dynath
                      Ok, i'm not sure if this is possible but I am wondering if it is possible to make a line drawing and paste it onto a 3d surface using these tools. I basicly want to draw a logo in sketchup, paste it onto a curved surface before manipulating the various thicknesses on it to make it 3D.
                      any ideas?
                      • mitcorbM
                        mitcorb
                        It seems you would have to import the line drawing as a .dxf, or .obj. Or import as an image and place it on a flat drawn surface and trace over it. Do whatever cleanup or closure is necessary on the flat drawing. Using the Sandbox tools, your curved surface being the TIN(triangulated irregular network?), you then Drape the line drawing onto the curved surface.
                          deanlegg
                          Can anyone tell my whats happening with the arc tool here
                          The corner of the smile is all distorted
                            RizkySyahputra
                            HI i'm a using SU8PRO. why in my pc after i was installed Tools on surface it appear an error loading plugin?? ❓
                            • GaieusG
                              Did you also install the LibFredo Library as is instructed in the first post?
                                d12dozr
                                Its a known bug, see this and the next few posts http://forums.sketchucation.com/viewtopic.php?p=308756#p308756
                                http://goo.gl/f7ooYh
                                • H
                                  huckrorick
                                  thank you. Thank You. THANK YOU!!
                                  I haven't tried all the tools but the Freehand on Surface (without inference) is something I have been praying for, for a long time. Inference was constantly making tracing things or making freehand lines with small movements incredibly slow and frustrating. This is a godsend.
                                  I wish I knew a better way to thank you.
                                  Huck
                                    Huck
                                    You could make a generous PayPal donation to Fredo - details are in his submenus 😄
                                      slimaczysko
                                      THX my friend ! Perfect tool ! I use it to many project ! THX AGAIN 😄
                                      Some of my works and photos... http://slimaczysko.digart.pl/digarty/
                                        jorge2011
                                        I have a small problem with a geometry.
                                        The sides of the circle does not coincide.
                                        Is this normal? It is possible to fix it?
                                        regards
                                          jorge2011
                                          image correction
                                          http://forums.sketchucation.com/download/file.php?mode=view&id=71839
                                          • fredo6F
                                            @jorge2011 said:
                                            image correction
                                            Jorge
                                            I don't see the image
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 31
                                            • 32
                                            • 19 / 32
