    [Plugin][$] Tools On Surface - v2.6a - 01 Apr 24
    638 Posts 203 Posters 1.8m Views 202 Watching
    • H Offline
      hebeijianke
      @hebeijianke said:
      I'm using version 1.8a
      The text displayed is not Chinese
      There are several situations can not be displayed properly
      I do not known the reason
      The Translation is Correct
      • fredo6F Offline
        Just in case, this may come from the fact that in your configuration, the Chinese language is defined with CN, not ZH.
        The original file is defined with ZH.
        Could you check what is the local language by typing Sketchup.get_locale in the Ruby console.
          g863210
          THANK YOU! IT IS POWERFUL! 😍
          • H Offline
            hebeijianke
            It Is still displayed incorrectly
              There are several common two-part locale code LCID strings [the 'code' and 'LCID string' can vary] - e.g.
              Chinese (simplified) - ZH-CN
              Chinese (traditional) - ZH-TW
              English (UK) - EN-GB
              English (US) - EN-US
              Portuguese (Brazil) - PT-BR
              Portuguese (Portugal) - PT-PT
              Some of them like EN-GB are no longer implemented by Google, as we are now lumped in with America under EN-US...
                Diggsey
                This plugin is exceptionally useful!
                A couple of minor bugs:
                Sometimes, if you draw a circle or ellipse over a hard edge, the curve will be divided into more than two parts. The plugin needs to start and end the curve at one of the intersections with the hard edge to prevent it. Also, the drawing tools seem to make duplicate faces occasionally. Oddly this seems to happen often on flat surfaces.
                  dynath
                  Ok, i'm not sure if this is possible but I am wondering if it is possible to make a line drawing and paste it onto a 3d surface using these tools. I basicly want to draw a logo in sketchup, paste it onto a curved surface before manipulating the various thicknesses on it to make it 3D.
                  any ideas?
                  • mitcorbM Offline
                    mitcorb
                    It seems you would have to import the line drawing as a .dxf, or .obj. Or import as an image and place it on a flat drawn surface and trace over it. Do whatever cleanup or closure is necessary on the flat drawing. Using the Sandbox tools, your curved surface being the TIN(triangulated irregular network?), you then Drape the line drawing onto the curved surface.
                      deanlegg
                      Can anyone tell my whats happening with the arc tool here
                      The corner of the smile is all distorted
                        RizkySyahputra
                        HI i'm a using SU8PRO. why in my pc after i was installed Tools on surface it appear an error loading plugin?? ❓
                          Did you also install the LibFredo Library as is instructed in the first post?
                            d12dozr
                            Its a known bug, see this and the next few posts http://forums.sketchucation.com/viewtopic.php?p=308756#p308756
                            http://goo.gl/f7ooYh
                            • H Offline
                              huckrorick
                              thank you. Thank You. THANK YOU!!
                              I haven't tried all the tools but the Freehand on Surface (without inference) is something I have been praying for, for a long time. Inference was constantly making tracing things or making freehand lines with small movements incredibly slow and frustrating. This is a godsend.
                              I wish I knew a better way to thank you.
                              Huck
                                Huck
                                You could make a generous PayPal donation to Fredo - details are in his submenus 😄
                                  slimaczysko
                                  THX my friend ! Perfect tool ! I use it to many project ! THX AGAIN 😄
                                  Some of my works and photos... http://slimaczysko.digart.pl/digarty/
                                    jorge2011
                                    I have a small problem with a geometry.
                                    The sides of the circle does not coincide.
                                    Is this normal? It is possible to fix it?
                                    regards
                                      jorge2011
                                      image correction
                                      http://forums.sketchucation.com/download/file.php?mode=view&id=71839
                                      • fredo6F Offline
                                        @jorge2011 said:
                                        image correction
                                        Jorge
                                        I don't see the image
                                          jorge2011
                                          see the file
                                          01.skp
                                          • fredo6F Offline
                                            Jorge,
                                            When you draw the circle, try to align the radius on the existing grand arc of the sphere.
                                            But anyway TOS will not consider your sphere in any specific way as it expects to work on any kind of surface.
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 31
                                            • 32
                                            • 19 / 32
