    Show Me Your SketchUp
    114 Posts 74 Posters 55.7k Views 74 Watching
    • PixeroP Offline
      Pixero
      @pixero said:
      I recently started to use a three icons wide toolbar at the right side
      Looks to me it's on the left side. 😒
      not if Im standing on my head. 😛
      • jbacusJ Offline
        jbacus
        Just realized that I haven't shown you MY SketchUp yet. You'll probably all think this is kind of funny, but it is the honest truth. This is really how I use SketchUp– and I do use it pretty frequently, too. I have keyboard shortcuts memorized for the small number of tools I use, and use a keyboard shortcut (q, for no particular reason) to toggle my panels on and off.
        jbacus-sketchup-screenshot
        "...exaggerate the essential and leave the obvious unclear." --Vincent Van Gogh
        John Bacus
        jbacus@sketchup.com
          Well, you Mac users... 😒
          I cannot believe that you do not get some share from Apple because the Mac version is much easier to customize!
          • soloS Offline
            downside is you stuck with ATI cards. 👎
              Phil Rader AIA
              @jbacus said:
              Now that's keeping it simple.
              http://www.philrader.com
              • PixeroP Offline
                Pixero
                Here's mine. I recently started to use a three icons wide toolbar at the left side both for getting all plugins in view and for not having a too wide and low workscreen. (I also use VRay and Twilight that is temporarily removed here.)
                My plugins:
                • H Offline
                  HFM
                  Very empty with, on occasion, an extra plugin toolbar on the left.
                  Sketchup Interface
                  • halroachH Offline
                    halroach
                    How do you toggle all the panels on and off with one key press? Is that on the mac only?
                    Since the start of my using sketchup (since version 5) I've been wishing to have a sort of KIOSK mode, that would hide all the toolbars and windows with a key press.
                    1. It would be great for presenting a project (remove all the clutter)
                    2. It would go well in conjunction with the sizer plugin which I've never used, because I don't wish to mess up my toolbars every time. (restore positions doesn't always work)
                    3. Just like there is "restore toolbars positions" there could be several toolbar setups. 'presenting mode', 'render mode' 'editing mode' or any custom mode...
                    On the other hand, I believe that when a program is too customizable (UI and shortcuts) it can cause the program to be less appealing and messy in appearance and operation, for experienced users, and especially for new ones who have no idea what toolbar might be hiding where).
                    Take Adobe Photoshop for instance. In it's early stages, it was very tough to customize (shortcuts couldn't be changed). But once you've learned the shortcuts and the basic structure of the program, you were free to use it in your "native speed" on any computer it was installed on.
                    Right now I have 4 or 5 people sketchupping at work on different computers, and each has a different toolbar setup and it drives all of us up the wall finding things. Luckily I was quick to recognize the problem of over customization, and made sure that all computers had at least the same keyboard shortcuts setup (similar to photoshop shortcuts BTW). Half a problem solved...
                    Anyway, my point is, that over customization can be a hindrance if not tackled correctly!
                    FlexTools - Super Quick Windows, Doors, Slats...
                    • jeff hammondJ Offline
                      Yeah, on macs, you can assign app specific shortcuts via system prefs.
                      Anything that is toggleable via the menus (such as the entity info panel etc) can also be done with a keystroke.
                      Edit- fwiw, JohnB also has a collapsed toolbar on his screen that he can hide/show via that little button at topright. (and you can drop single icons from multi icon plugins up there if you want)
                      That said, at present, you can only have a single row of icons in the custom toolbar but it'd be nice if apple opened it up to two or more rows.
                        Lobster
                        Not as nihilistic as John, but i do minimise the toolbar frequently.
                        I suppose i would get a little more flamboyant if it were not a laptop 1680 x 1050.
                        • EdsonE Offline
                          Edson
                          http://www.mahfuz.arq.br
                          • utilerU Offline
                            utiler
                            Here's mine...
                            Just Curious...
                              This is my setup at my work computer. My home computer has similar setup.
                              Dual Monitor Screenshot
                              I try to keep installed plugins to a minimum. As well as any UI elements, which is why I use shortcut for frequent functions, toolbars for medium frequency and menus for low frequency. I roll up most ToolWindows when I'm not using them. (Though the Material window keep rolling down... nudge nudge*)
                              Installed Plugins - Multiple Source Locations
                              Since I use version control software for the plugins I develop I have isolated them into external folders - with a proxy loader.
                              • Mike LuceyM Offline
                                Mike Lucey
                                John,
                                I like to keep it as pure as it was originally intended and still remains if one wants it be. I also use a useful little app called DOODIM which allows me to turn my cluttered BumpTop desktop to black! This helps me to focus on the app I am working with. I don't like filling the screen with any application window particularly on the MBP.
                                Mike
                                • andybotA Offline
                                  andybot
                                  Hey, this is a great thread! It's helpful to see how other people have their workflow. I agree about not having the buttons too deep, I've pared down my visible ones as much as possible. Gaieus, good suggestion about the customizing plugin, there are some long toolbars where I only use one or two features so they end up in the menu only.
                                  -Andy
                                  • V Offline
                                    Vicspa
                                    This is what works for me at this time.
                                    • Bryan KB Offline
                                        Panga
                                        And here is my SU workspace :
                                        And my plugin folder :
                                        These screenshots was made after a recent reinstall, so all the plugin i'm using are not present, only the most used.
                                        Regards.
                                        • leedeeteeL Offline
                                          leedeetee
                                          Here's mine. Nothing too fancy...
                                            And where is that screenshot, Gavin?
                                            • 3 / 6
