    Show Me Your SketchUp
    114 Posts 74 Posters 69.3k Views 74 Watching
    • soloS
        I've got a 26" monitor and keep the window somewhat reduced in width. The inspectors are out of the drawing space to the right.
        • JpacJ
          Jpac
          http://sketchup4sitedesign.wordpress.com/
          • wind-borneW
            wind-borne
            2nd shot, toggle toolbar shortcuts
            "To read between the lines was easier than to follow the text."OSX 10.11.6
            %(#BF80BF)[SU 8 pro
            • jeff hammondJ
              Wind b
              What are the FT & IN icons?
                d12dozr
                http://goo.gl/f7ooYh
                • wind-borneW
                  wind-borne
                  Wind b
                  It's later than you think or maybe i waste landscape. πŸ˜†
                  Feet
                  Inches
                  %(#BF80BF)[SU 8 pro
                  • jeff hammondJ
                    @wind-borne said:
                    Wind b
                    Feet
                    Inches
                    Lol
                    I gather that much.
                    I meant
                    What do they do?
                    Edit(reason being, I'll often switch units between architectural and fractional inches. Was wondering if theicons work aling those lines?)
                    • jeff hammondJ
                      here's my laptop setup.. i have a couple of more toolbars showing on the other computer.
                      click -> bigger
                      • GaieusG
                        Here is mine. I have set my toolbars NOT to be wider than when I set my SU window workspace to be exactly 1024x768 pixels. I have a small Windows utility, "Sizer" which will remember a set of window sizes (the above is called "4:3" in my system but as you can see, I have other sizes as well).
                        The dialogs are outside of this area and I always keep the Entity info dialog open separately.
                        I also have Jim's Custom toolbar plugin so that I can make a collection of the less frequently used tools (the ones I use more frequently, have shortcuts). IT ALSO Has a couple of buttons otherwise unavailable in SU like show endpoints or use edges by axis etc. This way I can get rid of buttons for which I use shortcuts and buttons (tools) that I never use anyway (like )
                        I made an overlay where I undocked this Custom toolbar so that you can see better which are the buttons. I also attach my toolbars settings file (txt) below.
                        The rest are either toolbars not incorporated into this custom toolbar yet (Google, Sandbox, Sections, Solids) and all the others are plugins.
                        SketchUp.txt
                        • GaieusG
                          I changed the topic to a global announcement for a while.
                          John, you (and all the SU Team) can also post "local" and "global" announcements and stickies. Feel free to use this "superpower" any time you want to post something like this...
                          πŸ˜‰
                          • wind-borneW
                            wind-borne
                            @wind-borne said:
                            Wind b
                            Feet
                            Inches
                            Lol
                            I gather that much.
                            I meant
                            What do they do?
                            Similar, other icons in Toggle Units plugin do what you do
                            %(#BF80BF)[SU 8 pro
                              Hoppefully I have a new monitor after some time with a 15" πŸ’š
                              order of the tool bar is never the same due excentricity of the every start of SU! πŸ˜‰
                                • KrisidiousK
                                  Krisidious
                                  I'm not allowed to post my desktop... the image is too wide for the forums. so here's a link.
                                  http://www.aboveallhouseplans.com/Capture.JPG
                                  http://www.aboveallhouseplans.com/Capture2.JPG
                                  and while we're discussing it, can you do something about the 4th wall above sketchup in monitor layouts? none of the toolbars or windows will go above sketchup into another monitor, only to the sides.
                                  By: Kristoff Rand
                                  • daleD
                                    dale
                                    Mine on this project...
                                    • B
                                      Builder Boy
                                      All my plugins
                                      • soloS
                                        Michael, you have many toolbars I have never seen before. 😲
                                          Slimdog
                                          Its interesting to see how many people have the standard large tool set docked in the same place. I am kinda shocked to see the layers pallet closed on most peoples. I have entity info and layers open all the time.
                                          • EarthMoverE
                                            EarthMover
                                            Here's mine. I try to organize toolbars by groupings. Drawing plugins together, mesh manipulation plugins together, render plugins together, etc. Since they tend to get scrambled so often, it's easier to remember the layout.
                                            Content Creator at Skapeup
                                            • 1 / 6
