    Show Me Your SketchUp
    114 Posts 74 Posters 56.3k Views 74 Watching
    • jbacusJ Offline
      jbacus
      Hi everybody,
      I'm doing a little informal survey of SketchUp users, and I wonder if you'd be willing to help out. I'd like to see how you've customized SketchUp's UI to suit the particulars of your workflow. In other words, what toolbars you've shown/hidden, what scripts you've added and where you keep your inspectors on the screen. Can you help?
      If so, please post a screenshot of your workspace in this thread. Show me your SketchUp!
      thanks-
      "...exaggerate the essential and leave the obvious unclear." --Vincent Van Gogh
      John Bacus
      jbacus@sketchup.com
          • boofredlayB Offline
            boofredlay
            • soloS Offline
                I've got a 26" monitor and keep the window somewhat reduced in width. The inspectors are out of the drawing space to the right.
                • JpacJ Offline
                  Jpac
                  http://sketchup4sitedesign.wordpress.com/
                  • wind-borneW Offline
                    wind-borne
                    2nd shot, toggle toolbar shortcuts
                    "To read between the lines was easier than to follow the text."OSX 10.11.6
                    %(#BF80BF)[SU 8 pro
                    • jeff hammondJ Offline
                      Wind b
                      What are the FT & IN icons?
                        d12dozr
                        http://goo.gl/f7ooYh
                          wind-borne
                          Wind b
                          It's later than you think or maybe i waste landscape. πŸ˜†
                          Feet
                          Inches
                          %(#BF80BF)[SU 8 pro
                            @wind-borne said:
                            Wind b
                            Feet
                            Inches
                            Lol
                            I gather that much.
                            I meant
                            What do they do?
                            Edit(reason being, I'll often switch units between architectural and fractional inches. Was wondering if theicons work aling those lines?)
                              here's my laptop setup.. i have a couple of more toolbars showing on the other computer.
                              click -> bigger
                                Here is mine. I have set my toolbars NOT to be wider than when I set my SU window workspace to be exactly 1024x768 pixels. I have a small Windows utility, "Sizer" which will remember a set of window sizes (the above is called "4:3" in my system but as you can see, I have other sizes as well).
                                The dialogs are outside of this area and I always keep the Entity info dialog open separately.
                                I also have Jim's Custom toolbar plugin so that I can make a collection of the less frequently used tools (the ones I use more frequently, have shortcuts). IT ALSO Has a couple of buttons otherwise unavailable in SU like show endpoints or use edges by axis etc. This way I can get rid of buttons for which I use shortcuts and buttons (tools) that I never use anyway (like )
                                I made an overlay where I undocked this Custom toolbar so that you can see better which are the buttons. I also attach my toolbars settings file (txt) below.
                                The rest are either toolbars not incorporated into this custom toolbar yet (Google, Sandbox, Sections, Solids) and all the others are plugins.
                                SketchUp.txt
                                  I changed the topic to a global announcement for a while.
                                  John, you (and all the SU Team) can also post "local" and "global" announcements and stickies. Feel free to use this "superpower" any time you want to post something like this...
                                  πŸ˜‰
                                    wind-borne
                                    @wind-borne said:
                                    Wind b
                                    Feet
                                    Inches
                                    Lol
                                    I gather that much.
                                    I meant
                                    What do they do?
                                    Similar, other icons in Toggle Units plugin do what you do
                                    %(#BF80BF)[SU 8 pro
                                      Hoppefully I have a new monitor after some time with a 15" πŸ’š
                                      order of the tool bar is never the same due excentricity of the every start of SU! πŸ˜‰
                                      • TIGT Online
                                        • KrisidiousK Offline
                                          Krisidious
                                          I'm not allowed to post my desktop... the image is too wide for the forums. so here's a link.
                                          (www.aboveallhouseplans.com)
                                          and while we're discussing it, can you do something about the 4th wall above sketchup in monitor layouts? none of the toolbars or windows will go above sketchup into another monitor, only to the sides.
                                          By: Kristoff Rand
                                          • daleD Offline
                                            dale
                                            Mine on this project...
                                            • 1 / 6
