    Dramatic entrance and help required
    26 Posts 9 Posters 2.2k Views 9 Watching
    • MarianM Offline
      Marian
      Nice one Rich.
        Here's my shot at it.
        computer bottom.skp
          @marian said:
          Nice one Rich.
          I was surprised at the final result as I was thinking Curviloft and BezierSpline. Then SDS came to mind. It's a plugin that is so powerful that it never fails to impress me.
          All I need now is talent πŸ˜’
            Rich, that works quite nicely. Good job.
              Don't thank me. Thank Dale. It's his b'day today as well so I'm sure he'll appreciate it!
              • jeff hammondJ Offline
                yet another suggestion here.. πŸ˜„
                using the loft tool in curviloft set to 'bezier method2 respect tangency' along with the uniform B-splines from bezierSpline.rb..
                results from the video
                [flash=700,555:ek1lph60]http://www.youtube.com/v/Xt_MffSkCEI?version=3&hl=en_US&rel=0[/flash:ek1lph60]
                  Jeff, that's very good. I agree the corners probably aren't circular curves. I just used them for speed but would have used a Bezier curve instead. I did use a Bezier curve for the profiles, though. I used TIG's Extrude Edges by Rails and it went pretty quickly. I did three sides since all three have different widths.
                  re: the back face color. Makes you want to correct reversed faces, doesn't it? πŸ˜„
                    KarinaGM
                    Mmmhhh I'm a bit late but here's how I've solved this in the past
                    bevels.skp
                    Ohh nice one Dave! faster than mine πŸ˜„
                    Jeff, I liked the result but I can't watch youtoube from work 😞
                    Nor whatever Rich is using.... flash maybe?
                    I have to miss half of the stuff posted in the forum due to restrictions in my pc 😑
                    hate that
                    **"Aquel que sacrifica un poco de libertad por seguridad, no se merece ninguna y terminarΓ‘ perdiendo ambas"
                    -BenjamΓ­n Franklin.**
                      benanderson
                      D'OH! Forgot to hit "notfy me of a reply".
                      So many replies and so little time :B
                      @marian said:
                      No idea...I also stumbled on the same problem when I modeled my dell laptop and I settled for a compromise. http://sketchup.google.com/3dwarehouse/details?mid=ed35ed3a7c8824e5996bace9c8deb982&prevstart=0
                      I'll watch this thread maybe I'll get a solution for my laptop model too πŸ˜„
                      Btw...welcome to SCF. Have a nice stay here ^_^
                      Sweet model! And thanks πŸ˜„
                      like this? only 2 sides made πŸ˜’
                      [attachment=0:1ew1d1ur]<!-- ia0 -->23.jpg<!-- ia0 -->[/attachment:1ew1d1ur]
                      I tried that at first but then I ran into problems trying to get the rounded off corners. I could probably make 8-segmants and then join them all together in a very hack and slash way to get the result if all else fails.
                      http://homepage.mac.com/benanderson89/images/segments.jpg
                      And then their is always the option of going bananas with the move tool! πŸ˜†
                      Here's my suggestion using Artisan (or Sub Divide and Smooth)
                      [flash=600,480:1ew1d1ur]http://www.youtube.com/v/ckwgXqKH_uc[/flash:1ew1d1ur]
                      That looks like it would work, where can I download this plugin? I'll have a play about with it tonight when I get home.
                      [attachment=0:1ew1d1ur]<!-- ia0 -->computerBottomjh.skp<!-- ia0 -->[/attachment:1ew1d1ur]
                      [flash=700,555:1ew1d1ur]http://www.youtube.com/v/Xt_MffSkCEI?version=3&amp;hl=en_US&amp;rel=0[/flash:1ew1d1ur]
                      http://youtu.be/Xt_MffSkCEI?hd=1
                      Beizer Curves would be a good way to get the weird angle the bevel of the laptop sits at. Its very steep, almost straight.
                      http://homepage.mac.com/benanderson89/images/fr_272.jpg
                      Actually, on closer inspection, it has a radius of about 0.5cm on the bottom. You can see it when light hits of the bottom of the computer.
                        (www.artisan4sketchup.com)
                        Ther's a 15day trial but I recommend you buy it πŸ‘
                          benanderson
                          http://www.artisan4sketchup.com
                          I'll give it a shot, I'm not that heavy a Sketchup user. Though given the exchange rate from $ to Β£ it might be worth it even if its just going to sit there best part of the year! haha πŸ˜„
                          [attachment=1:299w5w9d]<!-- ia1 -->bevels.skp<!-- ia1 -->[/attachment:299w5w9d]
                          [attachment=0:299w5w9d]<!-- ia0 -->bevel.jpg<!-- ia0 -->[/attachment:299w5w9d]
                          hate that
                          May I ask what tools you have used to do this? πŸ˜„
                            KarinaGM
                            It is explained in the file I attached, but for the curves I used bezier spline, restricted to 8 segments per curve (the default is 20).
                            Push pull for the profiles and curviloft to join the resultants edges (the image attached to the message).
                              benanderson
                              Oh! I didn't realise it was in the file. My bad πŸ˜›
                              • gillesG Offline
                                gilles
                                an over way to do it with Scale Tool
                                bevel.skp
                                  benanderson
                                  I was actually experimenting with that and getting some decent results, but it looks like ya beat me to the punch πŸ˜„
                                  • gillesG Offline
                                    gilles
                                    I'm always trying to do it with native tools, instead of round corner follow me tool would do it but a little much time.
                                      benanderson
                                      I always try to use the native tools that come with software packages as well. I have no 3rd party plugins for my music software packages and use only the default toolset, with good results just to give an example. πŸ˜„
                                      • soloS Offline
                                        I believe that SU native tools should be used initially by noobs in order to see the scope of the product, plugins are there to expand the app further and they certainly do, but I maintain that one should only venture to plugins once they are fluent with the capabilities of the base product.
