    Dramatic entrance and help required
    26 Posts 9 Posters 2.2k Views 9 Watching
      benanderson
      Introduction
      Dramatic as in "I fell down the stairs". πŸ˜†
      Have been using sketchup since version 6 reared its ugly head and have a few odd models floating around.
      I mostly (everything) do 1:1 scale models of random bits and bobs of techno babble.
      Though a hard drive failure in 2008 lost almost all of my models (and subsequently sent the Dell computer I was working on flying out the window for the hyper-billionth, time along with MS Windows).
      So what I managed to save from all this is right here:
      http://sketchup.google.com/3dwarehouse/details?mid=d05e40aeb8081384850db66bac01615f
      http://sketchup.google.com/3dwarehouse/details?mid=d29194968bbf7fa436a6da92dbb88b3a
      http://sketchup.google.com/3dwarehouse/details?mid=32d68bd4315a43b9ab740b857f575c7f
      http://sketchup.google.com/3dwarehouse/details?mid=f1b4c355c2df53e436a6da92dbb88b3a
      The CZ3000 is probably my favourite model out of all the models I've done.
      For ones that I have not uploaded or were lost:
      http://homepage.mac.com/benanderson89/images/PS3.png
      http://homepage.mac.com/benanderson89/images/iMac.png
      http://homepage.mac.com/benanderson89/images/macbookAluminium.png
      http://homepage.mac.com/benanderson89/images/esq-1.png
      So yes, yet more techno rubbish spewing from Sketchup πŸ˜†
      Help
      I have a bit of a problem with a model I am working on. A model of my Advent Modena Laptop (what a surprise) and I cannot seem to get the bevel around the edge to work. I can do a beveled edge with the follow me tool like I have done with the MacBook Aluminium model you see above, giving it a nice rounded corner, but the problem with the Modena I'm modelling is that the size of the bevel is not uniform around the computer.
      This picture explains it better than I do:
      http://homepage.mac.com/benanderson89/images/modena-underside.jpg
      Any ideas how I could achieve this in Sketchup 8?
      Cheers! πŸ˜„
      • MarianM Offline
        Marian
        No idea...I also stumbled on the same problem when I modeled my dell laptop and I settled for a compromise. http://sketchup.google.com/3dwarehouse/details?mid=ed35ed3a7c8824e5996bace9c8deb982&prevstart=0
        I'll watch this thread maybe I'll get a solution for my laptop model too πŸ˜„
        Btw...welcome to SCF. Have a nice stay here ^_^
          Round Corners by Fredo6 can must make that πŸ˜‰
          • MarianM Offline
            Marian
            Are you sure? Did you see the last link
              I'm just thinking and haven't tried it yet but I would make it with either Follow Me or Round Corner with the smaller radius (it may not be a circular curve so Round Over may not be appropriate. Then I would use FredoScale to scale the front curve to make it wider.
              Another option might be one of TIG's Extrusion Tools plugins. Draw the bottom of the arc and the edge to use as rails and an arc profile for the roundover. Do only half, copy and flip the copy to make the opposite side.
                Well, Extrude Edges By Rails almost works.
                Looks good from this angle but...
                Something fell apart. I expect if the right thing was done, it could be made to work.
                  like this? only 2 sides made πŸ˜’
                  • Rich O BrienR Online
                    Here's my suggestion using Artisan (or Sub Divide and Smooth)
                    [flash=800,600:dy6uok5o]http://www.youtube.com/v/ckwgXqKH_uc[/flash:dy6uok5o]
                    • MarianM Offline
                      Marian
                      Nice one Rich.
                        Here's my shot at it.
                        computer bottom.skp
                          @marian said:
                          Nice one Rich.
                          I was surprised at the final result as I was thinking Curviloft and BezierSpline. Then SDS came to mind. It's a plugin that is so powerful that it never fails to impress me.
                          All I need now is talent πŸ˜’
                            Rich, that works quite nicely. Good job.
                              Don't thank me. Thank Dale. It's his b'day today as well so I'm sure he'll appreciate it!
                              • jeff hammondJ Offline
                                yet another suggestion here.. πŸ˜„
                                using the loft tool in curviloft set to 'bezier method2 respect tangency' along with the uniform B-splines from bezierSpline.rb..
                                results from the video
                                [flash=700,555:ek1lph60]http://www.youtube.com/v/Xt_MffSkCEI?version=3&hl=en_US&rel=0[/flash:ek1lph60]
                                  Jeff, that's very good. I agree the corners probably aren't circular curves. I just used them for speed but would have used a Bezier curve instead. I did use a Bezier curve for the profiles, though. I used TIG's Extrude Edges by Rails and it went pretty quickly. I did three sides since all three have different widths.
                                  re: the back face color. Makes you want to correct reversed faces, doesn't it? πŸ˜„
                                    KarinaGM
                                    Mmmhhh I'm a bit late but here's how I've solved this in the past
                                    bevels.skp
                                    Ohh nice one Dave! faster than mine πŸ˜„
                                    Jeff, I liked the result but I can't watch youtoube from work 😞
                                    Nor whatever Rich is using.... flash maybe?
                                    I have to miss half of the stuff posted in the forum due to restrictions in my pc 😑
                                    hate that
                                    **"Aquel que sacrifica un poco de libertad por seguridad, no se merece ninguna y terminarΓ‘ perdiendo ambas"
                                    -BenjamΓ­n Franklin.**
                                      benanderson
                                      D'OH! Forgot to hit "notfy me of a reply".
                                      So many replies and so little time :B
                                      Sweet model! And thanks πŸ˜„
                                      [attachment=0:1ew1d1ur]<!-- ia0 -->23.jpg<!-- ia0 -->[/attachment:1ew1d1ur]
                                      I tried that at first but then I ran into problems trying to get the rounded off corners. I could probably make 8-segmants and then join them all together in a very hack and slash way to get the result if all else fails.
                                      http://homepage.mac.com/benanderson89/images/segments.jpg
                                      And then their is always the option of going bananas with the move tool! πŸ˜†
                                      [flash=600,480:1ew1d1ur]http://www.youtube.com/v/ckwgXqKH_uc[/flash:1ew1d1ur]
                                      That looks like it would work, where can I download this plugin? I'll have a play about with it tonight when I get home.
                                      [attachment=0:1ew1d1ur]<!-- ia0 -->computerBottomjh.skp<!-- ia0 -->[/attachment:1ew1d1ur]
                                      [flash=700,555:1ew1d1ur]http://www.youtube.com/v/Xt_MffSkCEI?version=3&amp;hl=en_US&amp;rel=0[/flash:1ew1d1ur]
                                      http://youtu.be/Xt_MffSkCEI?hd=1
                                      Beizer Curves would be a good way to get the weird angle the bevel of the laptop sits at. Its very steep, almost straight.
                                      http://homepage.mac.com/benanderson89/images/fr_272.jpg
                                      Actually, on closer inspection, it has a radius of about 0.5cm on the bottom. You can see it when light hits of the bottom of the computer.
                                        (www.artisan4sketchup.com)
                                        Ther's a 15day trial but I recommend you buy it πŸ‘
                                          benanderson
                                          http://www.artisan4sketchup.com
                                          I'll give it a shot, I'm not that heavy a Sketchup user. Though given the exchange rate from $ to Β£ it might be worth it even if its just going to sit there best part of the year! haha πŸ˜„
                                          [attachment=1:299w5w9d]<!-- ia1 -->bevels.skp<!-- ia1 -->[/attachment:299w5w9d]
                                          [attachment=0:299w5w9d]<!-- ia0 -->bevel.jpg<!-- ia0 -->[/attachment:299w5w9d]
                                          hate that
                                          May I ask what tools you have used to do this? πŸ˜„
                                            KarinaGM
                                            It is explained in the file I attached, but for the curves I used bezier spline, restricted to 8 segments per curve (the default is 20).
                                            Push pull for the profiles and curviloft to join the resultants edges (the image attached to the message).
