    Dramatic entrance and help required
    26 Posts 9 Posters 2.3k Views 9 Watching
    • MarianM
      Marian
      No idea...I also stumbled on the same problem when I modeled my dell laptop and I settled for a compromise. http://sketchup.google.com/3dwarehouse/details?mid=ed35ed3a7c8824e5996bace9c8deb982&prevstart=0
      I'll watch this thread maybe I'll get a solution for my laptop model too πŸ˜„
      Btw...welcome to SCF. Have a nice stay here ^_^
        Round Corners by Fredo6 can must make that πŸ˜‰
        • MarianM
          Marian
          Are you sure? Did you see the last link
          http://homepage.mac.com/benanderson89/images/modena-underside.jpg
            I'm just thinking and haven't tried it yet but I would make it with either Follow Me or Round Corner with the smaller radius (it may not be a circular curve so Round Over may not be appropriate. Then I would use FredoScale to scale the front curve to make it wider.
            Another option might be one of TIG's Extrusion Tools plugins. Draw the bottom of the arc and the edge to use as rails and an arc profile for the roundover. Do only half, copy and flip the copy to make the opposite side.
              Well, Extrude Edges By Rails almost works.
              Looks good from this angle but...
              Something fell apart. I expect if the right thing was done, it could be made to work.
                like this? only 2 sides made πŸ˜’
                  Here's my suggestion using Artisan (or Sub Divide and Smooth)
                  [flash=800,600:dy6uok5o]http://www.youtube.com/v/ckwgXqKH_uc[/flash:dy6uok5o]
                  • MarianM
                    Marian
                    Nice one Rich.
                      Here's my shot at it.
                      computer bottom.skp
                        @marian said:
                        Nice one Rich.
                        I was surprised at the final result as I was thinking Curviloft and BezierSpline. Then SDS came to mind. It's a plugin that is so powerful that it never fails to impress me.
                        All I need now is talent πŸ˜’
                          Rich, that works quite nicely. Good job.
                            Don't thank me. Thank Dale. It's his b'day today as well so I'm sure he'll appreciate it!
                            • jeff hammondJ
                              yet another suggestion here.. πŸ˜„
                              using the loft tool in curviloft set to 'bezier method2 respect tangency' along with the uniform B-splines from bezierSpline.rb..
                              results from the video
                              [flash=700,555:ek1lph60]http://www.youtube.com/v/Xt_MffSkCEI?version=3&hl=en_US&rel=0[/flash:ek1lph60]
                                Jeff, that's very good. I agree the corners probably aren't circular curves. I just used them for speed but would have used a Bezier curve instead. I did use a Bezier curve for the profiles, though. I used TIG's Extrude Edges by Rails and it went pretty quickly. I did three sides since all three have different widths.
                                re: the back face color. Makes you want to correct reversed faces, doesn't it? πŸ˜„
                                • K
                                  KarinaGM
                                  Mmmhhh I'm a bit late but here's how I've solved this in the past
                                  bevels.skp
                                  Ohh nice one Dave! faster than mine πŸ˜„
                                  Jeff, I liked the result but I can't watch youtoube from work 😞
                                  Nor whatever Rich is using.... flash maybe?
                                  I have to miss half of the stuff posted in the forum due to restrictions in my pc 😑
                                  hate that
                                  **"Aquel que sacrifica un poco de libertad por seguridad, no se merece ninguna y terminarΓ‘ perdiendo ambas"
                                  -BenjamΓ­n Franklin.**
                                  • B
                                    benanderson
                                    D'OH! Forgot to hit "notfy me of a reply".
                                    So many replies and so little time :B
                                    Sweet model! And thanks πŸ˜„
                                    [attachment=0:1ew1d1ur]<!-- ia0 -->23.jpg<!-- ia0 -->[/attachment:1ew1d1ur]
                                    I tried that at first but then I ran into problems trying to get the rounded off corners. I could probably make 8-segmants and then join them all together in a very hack and slash way to get the result if all else fails.
                                    http://homepage.mac.com/benanderson89/images/segments.jpg
                                    And then their is always the option of going bananas with the move tool! πŸ˜†
                                    [flash=600,480:1ew1d1ur]http://www.youtube.com/v/ckwgXqKH_uc[/flash:1ew1d1ur]
                                    That looks like it would work, where can I download this plugin? I'll have a play about with it tonight when I get home.
                                    [attachment=0:1ew1d1ur]<!-- ia0 -->computerBottomjh.skp<!-- ia0 -->[/attachment:1ew1d1ur]
                                    [flash=700,555:1ew1d1ur]http://www.youtube.com/v/Xt_MffSkCEI?version=3&amp;hl=en_US&amp;rel=0[/flash:1ew1d1ur]
                                    http://youtu.be/Xt_MffSkCEI?hd=1
                                    Beizer Curves would be a good way to get the weird angle the bevel of the laptop sits at. Its very steep, almost straight.
                                    http://homepage.mac.com/benanderson89/images/fr_272.jpg
                                    Actually, on closer inspection, it has a radius of about 0.5cm on the bottom. You can see it when light hits of the bottom of the computer.
                                      (www.artisan4sketchup.com)
                                      Ther's a 15day trial but I recommend you buy it πŸ‘
                                      • B
                                        benanderson
                                        http://www.artisan4sketchup.com
                                        I'll give it a shot, I'm not that heavy a Sketchup user. Though given the exchange rate from $ to Β£ it might be worth it even if its just going to sit there best part of the year! haha πŸ˜„
                                        [attachment=1:299w5w9d]<!-- ia1 -->bevels.skp<!-- ia1 -->[/attachment:299w5w9d]
                                        [attachment=0:299w5w9d]<!-- ia0 -->bevel.jpg<!-- ia0 -->[/attachment:299w5w9d]
                                        hate that
                                        May I ask what tools you have used to do this? πŸ˜„
                                        • K
                                          KarinaGM
                                          It is explained in the file I attached, but for the curves I used bezier spline, restricted to 8 segments per curve (the default is 20).
                                          Push pull for the profiles and curviloft to join the resultants edges (the image attached to the message).
                                          • B
                                            benanderson
                                            Oh! I didn't realise it was in the file. My bad πŸ˜›
