    [Plugin] TextureTools
    106 Posts 34 Posters 114.6k Views 34 Watching
      Jean-Luc Clauss
      Nice tool for geomodeling.
      Thank you so much Tig !
      Auteur de guides et de mรฉmos sur SketchUp aux รฉditions ENI
      http://archi-com21.blogspot.fr/
        Massimo
        I hadn't anticipated you weird Eurpoeans using a ',' as a decimal point rather than a sensible '.' ๐Ÿ˜’
        I can easily trap that in the code... I'll release an update later today - it should also have new tools added - TextureScale and TextureTweak... ๐Ÿ˜„
        • V
          vidy
          Wooow.. like this TIG, thank you..
          my wish, hopefully it could do also on the complex shape surface like sphere or cylinder.. ๐ŸŽ‰
          regards,
          still so much to learn..
            Here's v1.4 http://forums.sketchucation.com/viewtopic.php?p=329765#p329765
            New tools have been added - TextureScale & TextureTweak [Scale by Arrows], and TextureAdjust [Rotate by Arrows]. Some button png files have been adjusted.
            'Locale' use of a ',' instead of a '.' as a decimal-point now works in all dialogs.
            Please read the usage note for each tool...
            Feedback please...
            • massimoM
              massimo Moderator
              Wonderful. ๐Ÿ˜ฎ ๐Ÿ‘
              A little issue is that now i have to do something like this when input values:
              rotate-->dot
              adjust-->dot
              shunt-->comma
              nudge-->comma
              scale-->dot
              tweak-->dot
              While in SU i use always comma.
              • OxerO
                Oxer
                Thanks TIG, it works fine on Mac, only one thing the dot and comma don't works on all tools.
                  rotate-->dot
                  adjust-->dot
                  shunt-->comma
                  nudge-->comma
                  scale-->dot
                  tweak-->dot
                  Massimo [& Oxer]
                  What's your 'locale' ?
                  How do you normally input 'decimal-points' ?
                  In the UK/US it's 1.234 and I know in EU etc its [perversely] 1,234
                  The rotate/scale tools take 'float' numbers because angles and scaling are always in that format - the 'decimal-point' is determined by the system setup/locale not by me... 'I think 'floats' always use a '.' ??
                  The shunt/nudge tool takes a 'string' as its input since the user might type '10mm' or '1"' irrespective of their current units, and if they type '1' and their current units are 'cm' it is taken as '1cm', using the API's .to_l method. When the user enters a decimal-point it should be in the format that is determined by the system setup/locale not by me... So '1.234' or '1,234' - however I'm amazed that the two types of input are handled different.
                  Can you do a test in the Ruby Console for me... type these [exactly as they appear here] and report the result:
                  1.23.class 1,23.class 1.23.to_l 1,23.to_l '1.23'.to_l '1,23'.to_l
                  Depending on your feedback I COULD try trap it to change the input for the 'string' type so if you entered '1.23' and it couldn't be made into a length in length='1.23'.to_l then it'd try length='1.23'.tr('.',',').to_l - that way all of these tools would expect you always to use a '.' BUT it would substitute a ',' if your system needed it...
                  The code to swap is
                    u=u.to_l
                    v=v.to_l
                  which becomes
                    begin
                      u=u.to_l
                    rescue
                      u=u.tr('.', ',').to_l
                    begin
                      v=v.to_l
                    rescue
                      v=v.tr('.', ',').to_l
                  AND then
                    @d=@@nudge.to_l
                  which becomes
                    begin
                      @d=@@nudge.to_l
                    rescue
                      @d=@@nudge.tr('.', ',').to_l
                  ๐Ÿ’ญ
                  • massimoM
                    massimo Moderator
                    Well TIG in SU it's always comma or semicolon (for example when drawing a rectangle) for me, even the plugins, while in CAD, for example, it's always dot...
                    Anyway here is what i get in the ruby console:
                    1.23.class
                    Float
                      1.23.class
                      > Float
                      I'd like the whole list please ?
                      I know in EU etc in the SKP's UI the '.' swaps with the ',' and then the ',' with the ';' BUT in the Ruby API I must always use a '.' as the decimal-separator, ',' as the list-separator and ';' as a line-break...
                      However I'd have expected that the SUp UI would seamlessly swap float '.' for ',' when displayed inputed in a UI.inputbox() to suit the locale, as it seems to take ',' in strings to convert to 'lengths' ??
                      • massimoM
                        massimo Moderator
                        I've copied and pasted ALL the text you posted, sorry... ๐Ÿ˜ณ ๐Ÿ˜’
                        Here you have the results of every single line
                        1.23.class
                        Float
                        1,23.class
                        Error; #<SyntaxError; (eval);894; compile error
                        (eval);894; syntax error
                        1,23.class
                        (eval);894
                        1.23.to_l
                        1.23
                        1,23.to_l
                        1,23.to_l
                        (eval);894
                        '1.23'.to_l
                        Error; #<ArgumentError; (eval);894;in `to_l'; Cannot convert "1.23" to Length>
                        (eval);894
                        '1,23'.to_l
                        0.484251968503937
                        • OxerO
                          Oxer
                          Hi TIG,
                          I had probe to type the text in Ruby Console and this the result:
                          I'm in Spain (EU) and i use metric units.
                            So, as I suspected...
                            I'll reissue a trapped version that will take '.' or ',' as the decimal-separator in the inputbox for every tool, BUT it will if it's a string value it'll convert it to ',' to suit your locale and make a length from it if it has to... entering a number with a ',' it WILL work without failing [IF the locale supports] BUT it'll convert it back into a '.' when you OK the dialog...
                            Watch for an update...
                            • jgbJ
                              jgb
                              Ah yes, A period is as important to a programmer as it is to his girlfriend. ๐Ÿคฃ
                              jgb
                              • N
                                notareal
                                @tig said:
                                Massimo
                                ๐Ÿ˜ฒ ...waiting for the fix.
                                  Here's v1.5 http://forums.sketchucation.com/viewtopic.php?p=329765#p329765
                                  Irrespective of their locale, users may now type a '.' OR a ',' as a decimal-separator, depending on their preference, for any of the tools' dialogs - issues with conversion of strings to lengths from potential locale-wrong input is addressed in the code, 'behind the scenes'.
                                  Feedback please...
                                  • broomstickB
                                    broomstick
                                    Irrespective of their locale, users may now type a '.' OR a ',' as a decimal-separator, depending on their preference, for any of the tools' dialogs - issues with conversion of strings to lengths from potential locale-wrong input is addressed in the code behind the scenes.
                                    Feedback please...
                                    Just tried it, win7 64 bit skp 8... works fine and I must say this is one of the best plugins ever made!!!
                                      driven
                                      Hi TIG,
                                      all functionality working very well on the Mac, except toolbar tooltips.
                                      They work if I put the icons in the custom toolbar but not on the standard, floating toolbar.
                                      not a big issue here, just thought I'd mention it.
                                      • massimoM
                                        massimo Moderator
                                        Here's v1.5 viewtopic.php?p=329765#p329765...
                                        Perfect! ๐Ÿ˜„
                                        • OxerO
                                          Oxer
                                          @driven said:
                                          Hi TIG,
                                          The same, it works perfect on Mac. ๐Ÿ‘
                                          • OxerO
                                            Oxer
                                            I have translated the plugin to spanish, here is:
                                            Texture Tools 1.5 Spanish version
                                            Thanks TIG!!
                                            • 2 / 6
