    [Plugin] TextureTools
    106 Posts 34 Posters 110.0k Views 34 Watching
    • OxerO Offline
      Oxer
      Hi TIG,
      I had probe to type the text in Ruby Console and this the result:
      I'm in Spain (EU) and i use metric units.
        So, as I suspected...
        I'll reissue a trapped version that will take '.' or ',' as the decimal-separator in the inputbox for every tool, BUT it will if it's a string value it'll convert it to ',' to suit your locale and make a length from it if it has to... entering a number with a ',' it WILL work without failing [IF the locale supports] BUT it'll convert it back into a '.' when you OK the dialog...
        Watch for an update...
        • jgbJ Offline
          jgb
          Ah yes, A period is as important to a programmer as it is to his girlfriend. 🀣
          jgb
          • N Offline
            notareal
            @tig said:
            Massimo
            I hadn't anticipated you weird Eurpoeans using a ',' as a decimal point rather than a sensible '.' πŸ˜’
            I can easily trap that in the code... I'll release an update later today - it should also have new tools added - TextureScale and TextureTweak... πŸ˜„
            😲 ...waiting for the fix.
            Welcome to try [Thea Render](http://www.thearender.com/), Thea support | [kerkythea.net](http://www.kerkythea.net/) -team member
              Here's v1.5 http://forums.sketchucation.com/viewtopic.php?p=329765#p329765
              Irrespective of their locale, users may now type a '.' OR a ',' as a decimal-separator, depending on their preference, for any of the tools' dialogs - issues with conversion of strings to lengths from potential locale-wrong input is addressed in the code, 'behind the scenes'.
              Feedback please...
              • broomstickB Offline
                broomstick
                Irrespective of their locale, users may now type a '.' OR a ',' as a decimal-separator, depending on their preference, for any of the tools' dialogs - issues with conversion of strings to lengths from potential locale-wrong input is addressed in the code behind the scenes.
                Feedback please...
                Just tried it, win7 64 bit skp 8... works fine and I must say this is one of the best plugins ever made!!!
                  driven
                  Hi TIG,
                  all functionality working very well on the Mac, except toolbar tooltips.
                  They work if I put the icons in the custom toolbar but not on the standard, floating toolbar.
                  not a big issue here, just thought I'd mention it.
                  • massimoM Offline
                    massimo Moderator
                    Here's v1.5 viewtopic.php?p=329765#p329765...
                    Perfect! πŸ˜„
                    • OxerO Offline
                      Oxer
                      @driven said:
                      Hi TIG,
                      The same, it works perfect on Mac. πŸ‘
                      • OxerO Offline
                        Oxer
                        I have translated the plugin to spanish, here is:
                        Texture Tools 1.5 Spanish version
                        Thanks TIG!!
                        • massimoM Offline
                          massimo Moderator
                          TIG, i have tried this:
                          -painted a surface with a material;
                          -used one texture tool on the texture;
                          -picked the texture with the sample tool and painted other surfaces with different orientations.
                          Only with the "tweak" tool i get a strange behaviour following that workflow on connected faces. The texture looks a lot different on each plane... But if the planes are not connected it works just fine... πŸ˜•
                            I think the built-in UV-mapping of connected-faces assumes a certain 'flow' of the material across their shared edges...
                            If you have separate faces then their textures are arranged logically on a per-surface basis.
                            Hence the different behavior of textures on separate and connected faces... πŸ˜•
                            • massimoM Offline
                              massimo Moderator
                              Hmmm...That happens also with the "texture scale" tool if you input different values for U and V. But that doesn't happen if you use the native "edit" and input different values for length and width. (picture below)
                                Hmmm... this is v1... perhaps there's more to do... πŸ˜•
                                • massimoM Offline
                                  massimo Moderator
                                  No worries it's already a wonderful set of tools. πŸ˜„
                                  • EarthMoverE Offline
                                    EarthMover
                                    Thanks TIG! Most helpful plugin of the year!
                                    Content Creator at Skapeup
                                    • dfswyfD Offline
                                      dfswyf
                                      Thank you so much for this, it is very helpful!
                                        rv1974
                                        Looks like another must-have,
                                        Hats off to TIG πŸ‘
                                        • sumasterS Offline
                                          sumaster
                                          Hello sir,
                                          Thank you very much .......
                                          Its very useful .............
                                          Good luck ........
                                          Thanks again .......
                                          Thank you,
                                          SUmaster
                                            rv1974
                                            Dear ruby makers!
                                            Please, If you put arrow keys (or any other ones) into the game make a temporary shortcut override!!!
                                            There are some really usefull scripts with vulgar occupation of keys that make the life much harder.
                                            Meanwhile only Thomthom implemented this feature.
                                            • 3 / 6
