    [Plugin] TextureTools
    106 Posts 34 Posters 108.6k Views 34 Watching
      @massimo said:
      Well TIG in SU it's always comma or semicolon (for example when drawing a rectangle) for me, even the plugins, while in CAD, for example, it's always dot...
      Anyway here is what i get in the ruby console:
      1.23.class
      > Float
      I'd like the whole list please ?
      I know in EU etc in the SKP's UI the '.' swaps with the ',' and then the ',' with the ';' BUT in the Ruby API I must always use a '.' as the decimal-separator, ',' as the list-separator and ';' as a line-break...
      However I'd have expected that the SUp UI would seamlessly swap float '.' for ',' when displayed inputed in a UI.inputbox() to suit the locale, as it seems to take ',' in strings to convert to 'lengths' ??
      • massimoM Offline
        massimo Moderator
        I've copied and pasted ALL the text you posted, sorry... 😳 πŸ˜’
        Here you have the results of every single line
        1.23.class
        Float
        1,23.class
        Error; #<SyntaxError; (eval);894; compile error
        (eval);894; syntax error
        1,23.class
        (eval);894
        1.23.to_l
        1.23
        1,23.to_l
        1,23.to_l
        (eval);894
        '1.23'.to_l
        Error; #<ArgumentError; (eval);894;in `to_l'; Cannot convert "1.23" to Length>
        (eval);894
        '1,23'.to_l
        0.484251968503937
        • O Offline
          Oxer
          Hi TIG,
          I had probe to type the text in Ruby Console and this the result:
          I'm in Spain (EU) and i use metric units.
            So, as I suspected...
            I'll reissue a trapped version that will take '.' or ',' as the decimal-separator in the inputbox for every tool, BUT it will if it's a string value it'll convert it to ',' to suit your locale and make a length from it if it has to... entering a number with a ',' it WILL work without failing [IF the locale supports] BUT it'll convert it back into a '.' when you OK the dialog...
            Watch for an update...
              jgb
              Ah yes, A period is as important to a programmer as it is to his girlfriend. 🀣
              jgb
              • N Offline
                notareal
                @tig said:
                Massimo
                I hadn't anticipated you weird Eurpoeans using a ',' as a decimal point rather than a sensible '.' πŸ˜’
                I can easily trap that in the code... I'll release an update later today - it should also have new tools added - TextureScale and TextureTweak... πŸ˜„
                😲 ...waiting for the fix.
                Welcome to try [Thea Render](http://www.thearender.com/), Thea support | [kerkythea.net](http://www.kerkythea.net/) -team member
                  Here's v1.5 http://forums.sketchucation.com/viewtopic.php?p=329765#p329765
                  Irrespective of their locale, users may now type a '.' OR a ',' as a decimal-separator, depending on their preference, for any of the tools' dialogs - issues with conversion of strings to lengths from potential locale-wrong input is addressed in the code, 'behind the scenes'.
                  Feedback please...
                    broomstick
                    Irrespective of their locale, users may now type a '.' OR a ',' as a decimal-separator, depending on their preference, for any of the tools' dialogs - issues with conversion of strings to lengths from potential locale-wrong input is addressed in the code behind the scenes.
                    Feedback please...
                    Just tried it, win7 64 bit skp 8... works fine and I must say this is one of the best plugins ever made!!!
                      driven
                      Hi TIG,
                      all functionality working very well on the Mac, except toolbar tooltips.
                      They work if I put the icons in the custom toolbar but not on the standard, floating toolbar.
                      not a big issue here, just thought I'd mention it.
                      • massimoM Offline
                        massimo Moderator
                        Here's v1.5 viewtopic.php?p=329765#p329765...
                        Perfect! πŸ˜„
                        • O Offline
                          Oxer
                          @driven said:
                          Hi TIG,
                          The same, it works perfect on Mac. πŸ‘
                          • O Offline
                            Oxer
                            I have translated the plugin to spanish, here is:
                            Texture Tools 1.5 Spanish version
                            Thanks TIG!!
                            • massimoM Offline
                              massimo Moderator
                              TIG, i have tried this:
                              -painted a surface with a material;
                              -used one texture tool on the texture;
                              -picked the texture with the sample tool and painted other surfaces with different orientations.
                              Only with the "tweak" tool i get a strange behaviour following that workflow on connected faces. The texture looks a lot different on each plane... But if the planes are not connected it works just fine... πŸ˜•
                                I think the built-in UV-mapping of connected-faces assumes a certain 'flow' of the material across their shared edges...
                                If you have separate faces then their textures are arranged logically on a per-surface basis.
                                Hence the different behavior of textures on separate and connected faces... πŸ˜•
                                • massimoM Offline
                                  massimo Moderator
                                  Hmmm...That happens also with the "texture scale" tool if you input different values for U and V. But that doesn't happen if you use the native "edit" and input different values for length and width. (picture below)
                                    Hmmm... this is v1... perhaps there's more to do... πŸ˜•
                                    • massimoM Offline
                                      massimo Moderator
                                      No worries it's already a wonderful set of tools. πŸ˜„
                                      • E Offline
                                        EarthMover
                                        Thanks TIG! Most helpful plugin of the year!
                                        Content Creator at Skapeup
                                          dfswyf
                                          Thank you so much for this, it is very helpful!
                                            rv1974
                                            Looks like another must-have,
                                            Hats off to TIG πŸ‘
                                            • 2 / 6
