    [Plugin] Sketchup Ivy
    732 Posts 172 Posters 265.8k Views 172 Watching
      robert111
      i need help with ivy
      why my ivy ( picture 01) is not same as this good ivy ( picture 02)
      • N Offline
        nomeradona
        thanks srx. good point. iam actually using su7
        • romboutR Offline
          rombout
          @srx said:
          When I start SU it begins with this:
          Error Loading File LiveIvy.rb
          Can't insert empty component.
          This is solved with replacing version 8 leaf components with version 7 in Textures folder...
          but still not working:
          Error: #<NoMethodError: undefined method -' for nil:NilClass> C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/LiveIvy/LiveIvy_tool.rb:241:in birth_stem'
          C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/LiveIvy/LiveIvy_tool.rb:234:in each' C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/LiveIvy/LiveIvy_tool.rb:234:in birth_stem'
          C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/LiveIvy/LiveIvy_tool.rb:223:in birth' C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/LiveIvy/LiveIvy_tool.rb:99:in onLButtonDown'
          me to only version 5.04 worked a bit untill the shift click part
          i got this in SU 6
          Error; #<ArgumentError; wrong number of arguments (2 for 1)>
          /Library/Application Support/Google SketchUp 6/SketchUp/Plugins/LiveIvy/LiveIvy_tool.rb;233;in `start_operation'
          /Library/Application Support/Google SketchUp 6/SketchUp/Plugins/LiveIvy/LiveIvy_tool.rb;233;in `birth_stem'
          /Library/Application Support/Google SketchUp 6/SketchUp/Plugins/LiveIvy/LiveIvy_tool.rb;223;in `birth'
          /Library/Application Support/Google SketchUp 6/SketchUp/Plugins/LiveIvy/LiveIvy_tool.rb;98;in `onLButtonDown'
            rabba89
            I try to install the last two version but i still have the same problem.
            This message appears when i open sketchup: Error Loading File LiveIvy.rb Can't insert empty component.
            Than i'm able to use correctly the plug-in untill the last step.
            If i hold click+shift nothing happens. It the same when i only click (generate ivy)
            Can you help me?
            thanks a lot. Very good work, great idea πŸ˜‰
            • sadyoS Offline
              sadyo
              Shift+Click still not work on My SketchupIvy.0.6.3.beta 😒
              is there something i should do beside waiting for the next release?
              • N Offline
                nomeradona
                Can you help me?
                rabba the components inside the texture pluggin two of them were done in sketchup 8. download the su8 free and resaved the file to su7 or su 6 depends on what version you are using,
                • majidM Offline
                  majid
                  just to say a thousand thanx to you Pierre πŸ‘ πŸ‘ πŸ‘ πŸ‘ πŸ‘ πŸ‘ πŸ‘ πŸ‘
                  • jamalitoJ Offline
                    jamalito
                    hi guyz
                    how is it do this plugin ?
                    I downloaded it but can not use it πŸ˜•
                    Albert Einstein:
                    ((I am enough of an artist to draw freely upon my imagination. Imagination is more important than knowledge. Knowledge is limited. Imagination encircles the world.))
                      tomot
                      There are a number of hiccups in each new Ruby that need to be sorted out. I'm sure that will happen. With many thanks to Pierreden for taking on this task. πŸŽ‰
                      I have only 2 plugins currently installed, Vray demo, and Ivy under SU8. I also resaved the 3 ivyleaf_x.skp file to my SU8 version.
                      v.0.5.4 : only produces one statement in the Ruby Console after it installs the Ivy leaves.
                      quietly_force_sync_mats_cb just called
                      but otherwise works flawlessly.
                      v.0.6.2.beta : after 2 clicks, the following is noted in the Ruby Console.
                      (eval);1; warning; Float 0.05 out of range
                      Error; #<TypeError; nil can't be coerced into Fixnum>
                      C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_branch.rb;20;in `-'
                      C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_branch.rb;20;in `initialize'
                      C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_branch.rb;49;in `new'
                      C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_branch.rb;49;in `grow_stem'
                      C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_branch.rb;38;in `each'
                      C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_branch.rb;38;in `grow_stem'
                      C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb;203;in `grow_stem'
                      C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb;202;in `each'
                      C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb;202;in `grow_stem'
                      C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb;201;in `times'
                      C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb;201;in `grow_stem'
                      C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb;96;in `onLButtonDown'
                      crashed!
                      v.0.6.3.beta : after 2 clicks, the following is noted in the Ruby Console.
                      C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb;204;in `grow_stem'
                      C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb;203;in `each'
                      C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb;202;in `times'
                      C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb;90;in `onLButtonUp'
                      crashed!
                      cheers
                      [my plugins](http://thingsvirtual.blogspot.ca/)
                      tomot
                      • rodrigonotorR Offline
                        rodrigonotor
                        Same problem and the Ivy not grow. I use the same parameters of the 0.5.4 version and not achive the same results.
                        SU ver. 8.0.3117
                        β€’ [Sketchando.net](http://foro.sketchando.net/portal.php) β€’ www.arqcad.net β€’
                          The 'LiveIvy' error is because a reference that is set to 'nil' and NOT a 'float' [number] so it can't use '-' on it... See line #20...
                            driven
                            hi TIG,
                            if it actually has that error, why would it work on some setups and not others? just curious...
                            I can get it to run on the mac if I leave the startup ruby in the folder and load after startup, but only one of the leaves are transparent and in some image format that un-editable on my mac...
                              tomot
                              looks like just a simple typing mistake. I found out quickly its best to leave to Ruby console open then run your script to see what errors occur.
                              driven: Its very difficult to have one ruby satisfy the quirks of 2 OS's. If I had bothered to make my simple rubies work for 2 OS's I would not be enjoying my retirement now. πŸ˜‰
                              tomot
                                That is generated by V-Ray for SketchUp.
                                • jamalitoJ Offline
                                  jamalito
                                  @jamalito said:
                                  hi guyz
                                  is anyone tell me how is this work ?
                                  Albert Einstein:
                                  • F Offline
                                    function
                                    extract the rar file (http://www.win-rar.com/) into your Sketchup Plugin folder, located in the Google program files: Both LiveIvy.rb and the directory LiveIvy should be directly in the Plugin folder. Restart sketchup, select the faces you wish the ivy to grow on and access the plugin the the dropdown menu "Plugins" The GUI should appear, click the tab Usage for a full explanation of ...usage.
                                    btw: Pierreden - this is my favorite GUI of any sketchup plugin, bravo πŸ‘
                                      tomot
                                      I thought I would be able to add a 4th leaf to the LiveIvy.tool.rb script.
                                      Having made a new ivyleaf_4.skp file and adding the following code paragraph
                                      unless ;;Pdn;;LiveIvy;;Definitions.present?("ivyleaf_4")
                                              #path = File.join(pathname, 'Textures/ivyleaf_4.skp')
                                              pathname = Sketchup.find_support_file "ivyleaf_4.skp", "Plugins/LiveIvy/Textures/"
                                              definitions.load pathname
                                      I thought would have worked ......it did not! 😞 any ideas what else needs to be changed to accept a 4th leaf? I also made the leaves into actual cutouts, the procedure is similar to making "face me components". I will post the new revised leaves soon.
                                      tomot
                                      • soloS Offline
                                        Oh yes,I agree the leaves need to be .png's with alpha channel, especially for render purposes, I'd like to have something similar to fur plugin that I can choose what to use as leaves if possible.
                                        Face me would be awesome.
                                          tomot
                                          have a look at the attached Texture folder, it contains the Ivy shown above.
                                          let me know how it works!
                                          (if you only have winzip just rename texture.rar to texture.zip and open it with winzip)
                                          Textures.rar
                                          tomot
                                            mukul.ar
                                            0.6.3 is the version I'm using now... The ivy is not closing on shift + click. Was playing with 0.5.4 earlier and it worked perfectly. I've playing trying it out on sketchup 8. (yes i deleted the previous version) Just reporting... No complaints..πŸ˜„ great work on the plugin mate..!
                                            My Works
                                            • 36
                                            • 37
                                            • 3 / 37
