    [Plugin] Sketchup Ivy
    732 Posts 172 Posters 543.6k Views 172 Watching
    • P
      Pierreden
      @thomthom said:
      When you test your point against a face nested inside groups/faces you must trasnform that point to the co-ordinates of the face's containing face.
      So if you have a face nested inside a Group1 > ComponentInstance1 > Face, then you must add up the transformation of Group1 and ComponentInstance1 and apply that to the point to send to face.classify point.
      Thank you, get it! But i dont understand what transformations are applied to a new group (aka what happens when you group entities)?
        When you group, or make a component, out of existing entities they get their own local co-ordinates within the new group/component. (Within the ComponentDefinition)
        The group/component is inserted at the bottom front left corner of the boundingbox of the selected entities. To the grouped entities, this point becomes [0,0,0].
        (Though, when you add a group via Ruby API I think the group's origin is set to the current context's origin.)
        • EarthMoverE
          EarthMover
          Here is an English Ivy leaf that works well.
          Content Creator at Skapeup
          • leedeeteeL
            leedeetee
            This is probably a ridiculously stupied question but how do I get the ivy leafs to actually show up?! What am I doing wrong?!
            • EarthMoverE
              EarthMover
              CTRL click to bring up the red "+" symbols to indicate where the leaves will go and then SHIFT click to apply and create the leaves.
              Instructions are in the last section of the User Interface.
              • N
                nomeradona
                i dont knoe why i have this
                Error Loading File LiveIvy.rb
                Can't insert empty component.
                • srxS
                  srx
                  nomeradona
                  go to textures folder and convert skp files to version 7. That worked for me...
                  www.saurus.rs
                    robert111
                    i need help with ivy
                    why my ivy ( picture 01) is not same as this good ivy ( picture 02)
                    • N
                      nomeradona
                      thanks srx. good point. iam actually using su7
                      • romboutR
                        rombout
                        @srx said:
                        When I start SU it begins with this:
                        This is solved with replacing version 8 leaf components with version 7 in Textures folder...
                        but still not working:
                        Error: #<NoMethodError: undefined method -' for nil:NilClass> C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/LiveIvy/LiveIvy_tool.rb:241:in birth_stem'
                        C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/LiveIvy/LiveIvy_tool.rb:234:in each' C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/LiveIvy/LiveIvy_tool.rb:234:in birth_stem'
                        C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/LiveIvy/LiveIvy_tool.rb:223:in birth' C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/LiveIvy/LiveIvy_tool.rb:99:in onLButtonDown'
                        me to only version 5.04 worked a bit untill the shift click part
                        i got this in SU 6
                        Error; #<ArgumentError; wrong number of arguments (2 for 1)>
                        /Library/Application Support/Google SketchUp 6/SketchUp/Plugins/LiveIvy/LiveIvy_tool.rb;233;in `start_operation'
                        /Library/Application Support/Google SketchUp 6/SketchUp/Plugins/LiveIvy/LiveIvy_tool.rb;233;in `birth_stem'
                        /Library/Application Support/Google SketchUp 6/SketchUp/Plugins/LiveIvy/LiveIvy_tool.rb;223;in `birth'
                        /Library/Application Support/Google SketchUp 6/SketchUp/Plugins/LiveIvy/LiveIvy_tool.rb;98;in `onLButtonDown'
                          rabba89
                          I try to install the last two version but i still have the same problem.
                          This message appears when i open sketchup: Error Loading File LiveIvy.rb Can't insert empty component.
                          Than i'm able to use correctly the plug-in untill the last step.
                          If i hold click+shift nothing happens. It the same when i only click (generate ivy)
                          Can you help me?
                          thanks a lot. Very good work, great idea 😉
                          • sadyoS
                            sadyo
                            Shift+Click still not work on My SketchupIvy.0.6.3.beta 😢
                            is there something i should do beside waiting for the next release?
                            • N
                              nomeradona
                              Can you help me?
                              rabba the components inside the texture pluggin two of them were done in sketchup 8. download the su8 free and resaved the file to su7 or su 6 depends on what version you are using,
                              • majidM
                                majid
                                just to say a thousand thanx to you Pierre 👍 👍 👍 👍 👍 👍 👍 👍
                                • jamalitoJ
                                  jamalito
                                  hi guyz
                                  how is it do this plugin ?
                                  I downloaded it but can not use it 😕
                                  Albert Einstein:
                                  ((I am enough of an artist to draw freely upon my imagination. Imagination is more important than knowledge. Knowledge is limited. Imagination encircles the world.))
                                  • T
                                    tomot
                                    There are a number of hiccups in each new Ruby that need to be sorted out. I'm sure that will happen. With many thanks to Pierreden for taking on this task. 🎉
                                    I have only 2 plugins currently installed, Vray demo, and Ivy under SU8. I also resaved the 3 ivyleaf_x.skp file to my SU8 version.
                                    v.0.5.4 : only produces one statement in the Ruby Console after it installs the Ivy leaves.
                                    quietly_force_sync_mats_cb just called
                                    but otherwise works flawlessly.
                                    v.0.6.2.beta : after 2 clicks, the following is noted in the Ruby Console.
                                    (eval);1; warning; Float 0.05 out of range
                                    Error; #<TypeError; nil can't be coerced into Fixnum>
                                    C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_branch.rb;20;in `-'
                                    C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_branch.rb;20;in `initialize'
                                    C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_branch.rb;49;in `new'
                                    C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_branch.rb;49;in `grow_stem'
                                    C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_branch.rb;38;in `each'
                                    C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_branch.rb;38;in `grow_stem'
                                    C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb;203;in `grow_stem'
                                    C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb;202;in `each'
                                    C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb;202;in `grow_stem'
                                    C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb;201;in `times'
                                    C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb;201;in `grow_stem'
                                    C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb;96;in `onLButtonDown'
                                    crashed!
                                    v.0.6.3.beta : after 2 clicks, the following is noted in the Ruby Console.
                                    C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb;204;in `grow_stem'
                                    C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb;203;in `each'
                                    C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb;202;in `times'
                                    C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb;90;in `onLButtonUp'
                                    crashed!
                                    cheers
                                    my plugins
                                    tomot
                                    • rodrigonotorR
                                      rodrigonotor
                                      Same problem and the Ivy not grow. I use the same parameters of the 0.5.4 version and not achive the same results.
                                      SU ver. 8.0.3117
                                      • Sketchando.net • www.arqcad.net •
                                        The 'LiveIvy' error is because a reference that is set to 'nil' and NOT a 'float' [number] so it can't use '-' on it... See line #20...
                                          driven
                                          hi TIG,
                                          if it actually has that error, why would it work on some setups and not others? just curious...
                                          I can get it to run on the mac if I leave the startup ruby in the folder and load after startup, but only one of the leaves are transparent and in some image format that un-editable on my mac...
                                          • T
                                            tomot
                                            looks like just a simple typing mistake. I found out quickly its best to leave to Ruby console open then run your script to see what errors occur.
                                            driven: Its very difficult to have one ruby satisfy the quirks of 2 OS's. If I had bothered to make my simple rubies work for 2 OS's I would not be enjoying my retirement now. 😉
                                            my plugins
                                            tomot
                                            • 11
                                            • 36
                                            • 37
                                            • 9 / 37
