    [Plugin] Sketchup Ivy
    732 Posts 172 Posters 372.1k Views 172 Watching
    • N Offline
      nomeradona
      i dont knoe why i have this
      Error Loading File LiveIvy.rb
      Can't insert empty component.
      • srxS Offline
        srx
        nomeradona
        go to textures folder and convert skp files to version 7. That worked for me...
        www.saurus.rs
          robert111
          i need help with ivy
          why my ivy ( picture 01) is not same as this good ivy ( picture 02)
          • N Offline
            nomeradona
            thanks srx. good point. iam actually using su7
            • romboutR Offline
              rombout
              @srx said:
              When I start SU it begins with this:
              This is solved with replacing version 8 leaf components with version 7 in Textures folder...
              but still not working:
              Error: #<NoMethodError: undefined method -' for nil:NilClass> C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/LiveIvy/LiveIvy_tool.rb:241:in birth_stem'
              C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/LiveIvy/LiveIvy_tool.rb:234:in each' C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/LiveIvy/LiveIvy_tool.rb:234:in birth_stem'
              C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/LiveIvy/LiveIvy_tool.rb:223:in birth' C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/LiveIvy/LiveIvy_tool.rb:99:in onLButtonDown'
              me to only version 5.04 worked a bit untill the shift click part
              i got this in SU 6
              Error; #<ArgumentError; wrong number of arguments (2 for 1)>
              /Library/Application Support/Google SketchUp 6/SketchUp/Plugins/LiveIvy/LiveIvy_tool.rb;233;in `start_operation'
              /Library/Application Support/Google SketchUp 6/SketchUp/Plugins/LiveIvy/LiveIvy_tool.rb;233;in `birth_stem'
              /Library/Application Support/Google SketchUp 6/SketchUp/Plugins/LiveIvy/LiveIvy_tool.rb;223;in `birth'
              /Library/Application Support/Google SketchUp 6/SketchUp/Plugins/LiveIvy/LiveIvy_tool.rb;98;in `onLButtonDown'
                rabba89
                I try to install the last two version but i still have the same problem.
                This message appears when i open sketchup: Error Loading File LiveIvy.rb Can't insert empty component.
                Than i'm able to use correctly the plug-in untill the last step.
                If i hold click+shift nothing happens. It the same when i only click (generate ivy)
                Can you help me?
                thanks a lot. Very good work, great idea πŸ˜‰
                • sadyoS Offline
                  sadyo
                  Shift+Click still not work on My SketchupIvy.0.6.3.beta 😒
                  is there something i should do beside waiting for the next release?
                  • N Offline
                    nomeradona
                    Can you help me?
                    rabba the components inside the texture pluggin two of them were done in sketchup 8. download the su8 free and resaved the file to su7 or su 6 depends on what version you are using,
                    • majidM Offline
                      majid
                      just to say a thousand thanx to you Pierre πŸ‘ πŸ‘ πŸ‘ πŸ‘ πŸ‘ πŸ‘ πŸ‘ πŸ‘
                      • jamalitoJ Offline
                        jamalito
                        hi guyz
                        how is it do this plugin ?
                        I downloaded it but can not use it πŸ˜•
                        Albert Einstein:
                        ((I am enough of an artist to draw freely upon my imagination. Imagination is more important than knowledge. Knowledge is limited. Imagination encircles the world.))
                          tomot
                          There are a number of hiccups in each new Ruby that need to be sorted out. I'm sure that will happen. With many thanks to Pierreden for taking on this task. πŸŽ‰
                          I have only 2 plugins currently installed, Vray demo, and Ivy under SU8. I also resaved the 3 ivyleaf_x.skp file to my SU8 version.
                          v.0.5.4 : only produces one statement in the Ruby Console after it installs the Ivy leaves.
                          quietly_force_sync_mats_cb just called
                          but otherwise works flawlessly.
                          v.0.6.2.beta : after 2 clicks, the following is noted in the Ruby Console.
                          (eval);1; warning; Float 0.05 out of range
                          Error; #<TypeError; nil can't be coerced into Fixnum>
                          C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_branch.rb;20;in `-'
                          C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_branch.rb;20;in `initialize'
                          C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_branch.rb;49;in `new'
                          C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_branch.rb;49;in `grow_stem'
                          C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_branch.rb;38;in `each'
                          C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_branch.rb;38;in `grow_stem'
                          C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb;203;in `grow_stem'
                          C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb;202;in `each'
                          C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb;202;in `grow_stem'
                          C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb;201;in `times'
                          C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb;201;in `grow_stem'
                          C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb;96;in `onLButtonDown'
                          crashed!
                          v.0.6.3.beta : after 2 clicks, the following is noted in the Ruby Console.
                          C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb;204;in `grow_stem'
                          C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb;203;in `each'
                          C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb;202;in `times'
                          C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb;90;in `onLButtonUp'
                          crashed!
                          cheers
                          my plugins
                          tomot
                          • rodrigonotorR Offline
                            rodrigonotor
                            Same problem and the Ivy not grow. I use the same parameters of the 0.5.4 version and not achive the same results.
                            SU ver. 8.0.3117
                            β€’ Sketchando.net β€’ www.arqcad.net β€’
                              The 'LiveIvy' error is because a reference that is set to 'nil' and NOT a 'float' [number] so it can't use '-' on it... See line #20...
                                driven
                                hi TIG,
                                if it actually has that error, why would it work on some setups and not others? just curious...
                                I can get it to run on the mac if I leave the startup ruby in the folder and load after startup, but only one of the leaves are transparent and in some image format that un-editable on my mac...
                                  tomot
                                  looks like just a simple typing mistake. I found out quickly its best to leave to Ruby console open then run your script to see what errors occur.
                                  driven: Its very difficult to have one ruby satisfy the quirks of 2 OS's. If I had bothered to make my simple rubies work for 2 OS's I would not be enjoying my retirement now. πŸ˜‰
                                  my plugins
                                  tomot
                                    That is generated by V-Ray for SketchUp.
                                    • jamalitoJ Offline
                                      jamalito
                                      @jamalito said:
                                      hi guyz
                                      is anyone tell me how is this work ?
                                      Albert Einstein:
                                      • F Offline
                                        function
                                        extract the rar file (http://www.win-rar.com/) into your Sketchup Plugin folder, located in the Google program files: Both LiveIvy.rb and the directory LiveIvy should be directly in the Plugin folder. Restart sketchup, select the faces you wish the ivy to grow on and access the plugin the the dropdown menu "Plugins" The GUI should appear, click the tab Usage for a full explanation of ...usage.
                                        btw: Pierreden - this is my favorite GUI of any sketchup plugin, bravo πŸ‘
                                          tomot
                                          I thought I would be able to add a 4th leaf to the LiveIvy.tool.rb script.
                                          Having made a new ivyleaf_4.skp file and adding the following code paragraph
                                          unless ;;Pdn;;LiveIvy;;Definitions.present?("ivyleaf_4")
                                                  #path = File.join(pathname, 'Textures/ivyleaf_4.skp')
                                                  pathname = Sketchup.find_support_file "ivyleaf_4.skp", "Plugins/LiveIvy/Textures/"
                                                  definitions.load pathname
                                          I thought would have worked ......it did not! 😞 any ideas what else needs to be changed to accept a 4th leaf? I also made the leaves into actual cutouts, the procedure is similar to making "face me components". I will post the new revised leaves soon.
                                          my plugins
                                          tomot
                                          • soloS Offline
                                            Oh yes,I agree the leaves need to be .png's with alpha channel, especially for render purposes, I'd like to have something similar to fur plugin that I can choose what to use as leaves if possible.
                                            Face me would be awesome.
                                            • 11
                                            • 12
                                            • 36
                                            • 37
                                            • 10 / 37
