    [Plugin] Sketchup Ivy
    732 Posts 172 Posters 511.1k Views 172 Watching
    • leedeeteeL
      leedeetee
      This is probably a ridiculously stupied question but how do I get the ivy leafs to actually show up?! What am I doing wrong?!
      • EarthMoverE
        EarthMover
        CTRL click to bring up the red "+" symbols to indicate where the leaves will go and then SHIFT click to apply and create the leaves.
        Instructions are in the last section of the User Interface.
        Content Creator at Skapeup
        • N
          nomeradona
          i dont knoe why i have this
          Error Loading File LiveIvy.rb
          Can't insert empty component.
          • srxS
            srx
            nomeradona
            go to textures folder and convert skp files to version 7. That worked for me...
            www.saurus.rs
              robert111
              i need help with ivy
              why my ivy ( picture 01) is not same as this good ivy ( picture 02)
              • N
                nomeradona
                thanks srx. good point. iam actually using su7
                • romboutR
                  rombout
                  @srx said:
                  When I start SU it begins with this:
                  This is solved with replacing version 8 leaf components with version 7 in Textures folder...
                  but still not working:
                  Error: #<NoMethodError: undefined method -' for nil:NilClass> C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/LiveIvy/LiveIvy_tool.rb:241:in birth_stem'
                  C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/LiveIvy/LiveIvy_tool.rb:234:in each' C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/LiveIvy/LiveIvy_tool.rb:234:in birth_stem'
                  C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/LiveIvy/LiveIvy_tool.rb:223:in birth' C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/LiveIvy/LiveIvy_tool.rb:99:in onLButtonDown'
                  me to only version 5.04 worked a bit untill the shift click part
                  i got this in SU 6
                  Error; #<ArgumentError; wrong number of arguments (2 for 1)>
                  /Library/Application Support/Google SketchUp 6/SketchUp/Plugins/LiveIvy/LiveIvy_tool.rb;233;in `start_operation'
                  /Library/Application Support/Google SketchUp 6/SketchUp/Plugins/LiveIvy/LiveIvy_tool.rb;233;in `birth_stem'
                  /Library/Application Support/Google SketchUp 6/SketchUp/Plugins/LiveIvy/LiveIvy_tool.rb;223;in `birth'
                  /Library/Application Support/Google SketchUp 6/SketchUp/Plugins/LiveIvy/LiveIvy_tool.rb;98;in `onLButtonDown'
                    rabba89
                    I try to install the last two version but i still have the same problem.
                    This message appears when i open sketchup: Error Loading File LiveIvy.rb Can't insert empty component.
                    Than i'm able to use correctly the plug-in untill the last step.
                    If i hold click+shift nothing happens. It the same when i only click (generate ivy)
                    Can you help me?
                    thanks a lot. Very good work, great idea πŸ˜‰
                    • sadyoS
                      sadyo
                      Shift+Click still not work on My SketchupIvy.0.6.3.beta 😒
                      is there something i should do beside waiting for the next release?
                      • N
                        nomeradona
                        Can you help me?
                        rabba the components inside the texture pluggin two of them were done in sketchup 8. download the su8 free and resaved the file to su7 or su 6 depends on what version you are using,
                        • majidM
                          majid
                          just to say a thousand thanx to you Pierre πŸ‘ πŸ‘ πŸ‘ πŸ‘ πŸ‘ πŸ‘ πŸ‘ πŸ‘
                          • jamalitoJ
                            jamalito
                            hi guyz
                            how is it do this plugin ?
                            I downloaded it but can not use it πŸ˜•
                            Albert Einstein:
                            ((I am enough of an artist to draw freely upon my imagination. Imagination is more important than knowledge. Knowledge is limited. Imagination encircles the world.))
                            • T
                              tomot
                              There are a number of hiccups in each new Ruby that need to be sorted out. I'm sure that will happen. With many thanks to Pierreden for taking on this task. πŸŽ‰
                              I have only 2 plugins currently installed, Vray demo, and Ivy under SU8. I also resaved the 3 ivyleaf_x.skp file to my SU8 version.
                              v.0.5.4 : only produces one statement in the Ruby Console after it installs the Ivy leaves.
                              quietly_force_sync_mats_cb just called
                              but otherwise works flawlessly.
                              v.0.6.2.beta : after 2 clicks, the following is noted in the Ruby Console.
                              (eval);1; warning; Float 0.05 out of range
                              Error; #<TypeError; nil can't be coerced into Fixnum>
                              C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_branch.rb;20;in `-'
                              C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_branch.rb;20;in `initialize'
                              C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_branch.rb;49;in `new'
                              C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_branch.rb;49;in `grow_stem'
                              C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_branch.rb;38;in `each'
                              C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_branch.rb;38;in `grow_stem'
                              C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb;203;in `grow_stem'
                              C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb;202;in `each'
                              C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb;202;in `grow_stem'
                              C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb;201;in `times'
                              C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb;201;in `grow_stem'
                              C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb;96;in `onLButtonDown'
                              crashed!
                              v.0.6.3.beta : after 2 clicks, the following is noted in the Ruby Console.
                              C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb;204;in `grow_stem'
                              C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb;203;in `each'
                              C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb;202;in `times'
                              C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb;90;in `onLButtonUp'
                              crashed!
                              cheers
                              my plugins
                              tomot
                              • rodrigonotorR
                                rodrigonotor
                                Same problem and the Ivy not grow. I use the same parameters of the 0.5.4 version and not achive the same results.
                                SU ver. 8.0.3117
                                β€’ Sketchando.net β€’ www.arqcad.net β€’
                                  The 'LiveIvy' error is because a reference that is set to 'nil' and NOT a 'float' [number] so it can't use '-' on it... See line #20...
                                    driven
                                    hi TIG,
                                    if it actually has that error, why would it work on some setups and not others? just curious...
                                    I can get it to run on the mac if I leave the startup ruby in the folder and load after startup, but only one of the leaves are transparent and in some image format that un-editable on my mac...
                                    • T
                                      tomot
                                      looks like just a simple typing mistake. I found out quickly its best to leave to Ruby console open then run your script to see what errors occur.
                                      driven: Its very difficult to have one ruby satisfy the quirks of 2 OS's. If I had bothered to make my simple rubies work for 2 OS's I would not be enjoying my retirement now. πŸ˜‰
                                      my plugins
                                      tomot
                                        That is generated by V-Ray for SketchUp.
                                        • jamalitoJ
                                          jamalito
                                          @jamalito said:
                                          hi guyz
                                          is anyone tell me how is this work ?
                                          Albert Einstein:
                                          • F
                                            function
                                            extract the rar file (http://www.win-rar.com/) into your Sketchup Plugin folder, located in the Google program files: Both LiveIvy.rb and the directory LiveIvy should be directly in the Plugin folder. Restart sketchup, select the faces you wish the ivy to grow on and access the plugin the the dropdown menu "Plugins" The GUI should appear, click the tab Usage for a full explanation of ...usage.
                                            btw: Pierreden - this is my favorite GUI of any sketchup plugin, bravo πŸ‘
                                            • 11
                                            • 12
                                            • 36
                                            • 37
                                            • 10 / 37
