    [Plugin] Sketchup Ivy
    732 Posts 172 Posters 543.6k Views 172 Watching
    • sadyoS
      sadyo
      Shift+Click still not work on My SketchupIvy.0.6.3.beta 😒
      is there something i should do beside waiting for the next release?
      • N
        nomeradona
        @rabba89 said:
        I try to install the last two version but i still have the same problem.
        This message appears when i open sketchup: Error Loading File LiveIvy.rb Can't insert empty component.
        Than i'm able to use correctly the plug-in untill the last step.
        If i hold click+shift nothing happens. It the same when i only click (generate ivy)
        Can you help me?
        thanks a lot. Very good work, great idea πŸ˜‰
        rabba the components inside the texture pluggin two of them were done in sketchup 8. download the su8 free and resaved the file to su7 or su 6 depends on what version you are using,
        • majidM
          majid
          just to say a thousand thanx to you Pierre πŸ‘ πŸ‘ πŸ‘ πŸ‘ πŸ‘ πŸ‘ πŸ‘ πŸ‘
          • jamalitoJ
            jamalito
            hi guyz
            how is it do this plugin ?
            I downloaded it but can not use it πŸ˜•
            Albert Einstein:
            ((I am enough of an artist to draw freely upon my imagination. Imagination is more important than knowledge. Knowledge is limited. Imagination encircles the world.))
            • T
              tomot
              There are a number of hiccups in each new Ruby that need to be sorted out. I'm sure that will happen. With many thanks to Pierreden for taking on this task. πŸŽ‰
              I have only 2 plugins currently installed, Vray demo, and Ivy under SU8. I also resaved the 3 ivyleaf_x.skp file to my SU8 version.
              v.0.5.4 : only produces one statement in the Ruby Console after it installs the Ivy leaves.
              quietly_force_sync_mats_cb just called
              but otherwise works flawlessly.
              v.0.6.2.beta : after 2 clicks, the following is noted in the Ruby Console.
              (eval);1; warning; Float 0.05 out of range
              Error; #<TypeError; nil can't be coerced into Fixnum>
              C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_branch.rb;20;in `-'
              C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_branch.rb;20;in `initialize'
              C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_branch.rb;49;in `new'
              C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_branch.rb;49;in `grow_stem'
              C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_branch.rb;38;in `each'
              C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_branch.rb;38;in `grow_stem'
              C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb;203;in `grow_stem'
              C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb;202;in `each'
              C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb;202;in `grow_stem'
              C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb;201;in `times'
              C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb;201;in `grow_stem'
              C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb;96;in `onLButtonDown'
              crashed!
              v.0.6.3.beta : after 2 clicks, the following is noted in the Ruby Console.
              C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb;204;in `grow_stem'
              C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb;203;in `each'
              C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb;202;in `times'
              C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb;90;in `onLButtonUp'
              crashed!
              cheers
              my plugins
              tomot
              • rodrigonotorR
                rodrigonotor
                Same problem and the Ivy not grow. I use the same parameters of the 0.5.4 version and not achive the same results.
                SU ver. 8.0.3117
                β€’ Sketchando.net β€’ www.arqcad.net β€’
                  The 'LiveIvy' error is because a reference that is set to 'nil' and NOT a 'float' [number] so it can't use '-' on it... See line #20...
                    driven
                    hi TIG,
                    if it actually has that error, why would it work on some setups and not others? just curious...
                    I can get it to run on the mac if I leave the startup ruby in the folder and load after startup, but only one of the leaves are transparent and in some image format that un-editable on my mac...
                    • T
                      tomot
                      looks like just a simple typing mistake. I found out quickly its best to leave to Ruby console open then run your script to see what errors occur.
                      driven: Its very difficult to have one ruby satisfy the quirks of 2 OS's. If I had bothered to make my simple rubies work for 2 OS's I would not be enjoying my retirement now. πŸ˜‰
                      my plugins
                      tomot
                        That is generated by V-Ray for SketchUp.
                        • jamalitoJ
                          jamalito
                          @jamalito said:
                          hi guyz
                          is anyone tell me how is this work ?
                          Albert Einstein:
                          • F
                            function
                            extract the rar file (http://www.win-rar.com/) into your Sketchup Plugin folder, located in the Google program files: Both LiveIvy.rb and the directory LiveIvy should be directly in the Plugin folder. Restart sketchup, select the faces you wish the ivy to grow on and access the plugin the the dropdown menu "Plugins" The GUI should appear, click the tab Usage for a full explanation of ...usage.
                            btw: Pierreden - this is my favorite GUI of any sketchup plugin, bravo πŸ‘
                            • T
                              tomot
                              I thought I would be able to add a 4th leaf to the LiveIvy.tool.rb script.
                              Having made a new ivyleaf_4.skp file and adding the following code paragraph
                              unless ;;Pdn;;LiveIvy;;Definitions.present?("ivyleaf_4")
                                      #path = File.join(pathname, 'Textures/ivyleaf_4.skp')
                                      pathname = Sketchup.find_support_file "ivyleaf_4.skp", "Plugins/LiveIvy/Textures/"
                                      definitions.load pathname
                              I thought would have worked ......it did not! 😞 any ideas what else needs to be changed to accept a 4th leaf? I also made the leaves into actual cutouts, the procedure is similar to making "face me components". I will post the new revised leaves soon.
                              my plugins
                              tomot
                              • soloS
                                Oh yes,I agree the leaves need to be .png's with alpha channel, especially for render purposes, I'd like to have something similar to fur plugin that I can choose what to use as leaves if possible.
                                Face me would be awesome.
                                • T
                                  tomot
                                  have a look at the attached Texture folder, it contains the Ivy shown above.
                                  let me know how it works!
                                  (if you only have winzip just rename texture.rar to texture.zip and open it with winzip)
                                  Textures.rar
                                  my plugins
                                  tomot
                                    mukul.ar
                                    0.6.3 is the version I'm using now... The ivy is not closing on shift + click. Was playing with 0.5.4 earlier and it worked perfectly. I've playing trying it out on sketchup 8. (yes i deleted the previous version) Just reporting... No complaints..πŸ˜„ great work on the plugin mate..!
                                    My Works
                                    • N
                                      nomeradona
                                      first of all thanks for this pluggin. its wonderful. I have the following request.
                                      1. two skp files were done in su8, its better if they are done in SU6, they can be opened in su7 and su8. if they were done in SU 8 then it has error in SU7 and SU6.
                                      2. Please make the leaf textures as png file with background as transparent. its easier to render. instead of tiff or jpg
                                      3. HOw is the possibility where user can load its own skp files. rather than depending on the three skp file leaves.
                                      again my honest to goodness thanks to you pierre.
                                        mukul.ar
                                        This is just a workaround IMHO. There are 3 skp files in the rubies folder these are the 3 leaves each... you can save your own png textures instead of these leaves, but i'd recommend you place them on the same position as the existing leaf as it might affect leaf position otherwise. (you can save these in the skp format you use)
                                        As solo and a few others have also said it would be definitely great to have some control as to what components to use as "instances" for the leaves like we have in the make fur plugin. It would add more control as to the kind of things we can make with this wonderful plugin... ( FRUIT LADEN TREES is definitely something i might play with πŸ˜„)
                                        My Works
                                          a3rosmith
                                          is an excellent plugin from the beginning was working fine....but now it seems not work properly.....I got this console ruby ivy version 0.6.3
                                          Error: #<Errno::EDOM: Domain error - acos>
                                          C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_branch.rb:35:in acos' C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_branch.rb:35:in grow_stem'
                                          C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb:204:in grow_stem' C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb:203:in each'
                                          C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb:203:in grow_stem' C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb:202:in times'
                                          C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb:202:in grow_stem' C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb:90:in onLButtonUp'
                                          • G
                                            gaonirico
                                            @pierreden said:
                                            @gaonirico said:
                                            I installed the version 0.5.4 but from the previous version 0.3 the menu not shows correctly and function the change of parameters. Happens because my monitor functions only to 800x600? or I must have installed some update of internet explorer?
                                            @gaonarico: I dont know im afraid. It might be a javascript issue, if so, updating you IExplorer might help. But this problem is noted and i really hope to solve it soon.
                                            I resolved the problem. The cause went for some spyware or badware. I decided create a new account of user which solved also other errors in my pc
                                            • 11
                                            • 12
                                            • 36
                                            • 37
                                            • 10 / 37
