[Plugin] SunTool - new Mar 2009
@suntools said:
an updated version of the installer can be downloaded now.
Hope this solve the problem. Please let me know.Guedi
New version did the trick, no more loading another script during start up.
Ken
Hello Mac Users,
Following the previous announcement, SunTools Plugin for SketchUp is available now also for MAC !!It can be downloaded after registration from: http://tx.technion.ac.il/~arrguedi/SunTools/download.html
A short documentation file can be viewed at: http://tx.technion.ac.il/~arrguedi/SunTools/dwnld_after_reg/stdwnld/sunTools_helpV2.pdfEnjoy!!!
Guedi -
Does any one have this password? please seng to me:phieuluu1985@yhaoo.com.vn
What password do you mean?
[quote="SunTools"]MALAISE
Register at:
http://tx.technion.ac.il/~arrguedi/SunTools/download.htmlHi Guedi,
Ths for the tool. I couldn't register, got a message that the FormBuddy Quota Exceeded.
Any other way?
[]s
Maciel -
This tool was a problem because it rewrote a number of core class/methods that then clashed with many other tools - it hasn't been 'current' for a while - pity as it was potentially useful...
im already register, but still got no password send to me
It also messes with base classes, so it's best avoided ??
This script has caused a lot of problems. Best if it were removed or re-written. But I can't keep up with life lately, so I won't be getting to it anytime soon.
I've tried registering but have recieved no email, is there a problem with it?
could someone foreward me a password to bobat16<at>hotmail<dot>com ?
Cheers
Please, share a password
Please please please please, I beg you. I really need this.
Emailme man<dot>juanel<at>gmail<dot>com
It does not seem to work; its a shame. I have the files. Its seems compatibility might had been broken. Also the website has a broken download link (and generally it seems broken and possibly abandoned). I have some old files from 2013 (unpacked); if someone would want to try and fix the issues I would be grateful.
As was mentioned a few posts back [but ~3 years ago !] http://sketchucation.com/forums/viewtopic.php?p=287700#p287700
The toolset seems abandoned, is flaky AND is potentially harmful to the loading/operation of several other tools anyway.
It is a 'rogue' which messes with native/base classes and its installation is best avoided.
It will also almost certainly not be v2014 compatible [but please complete your SCF User Profile so we might better help you].
The tool's files are encrypted as rbs - effectively making them uneditable and unknowable [without a Trimble-only 'decompiler' app - which would then break the ToS]...As currently supplied in the previous post's ZIP, the files will 'install', but not 'load' as SketchUp starts, because the 'loader' rbs has be disabled using the SketchUcation 'Plugins Manager' [note the final ! on file-type]...
I do not recommend installing OR using it at all !
Instead, why not write a usage-spec and start a new thread that asks for development of a similar new Plugin ?
I have PM'd you with something to try...
the website is not working, is there any alternative i can access to the download? thanks
Look at the post just one before yours - this tool is not recommended for installation/use at all !
Look at the post just two before yours - there's a ZIP file containing the current files.Use at your own risk.
Personally I loved this tool, I would love to see it revived!
I mailed the creator with the question to update / open-source his code...
In the 2nd case, would anybody be interested in updating it for SU 2014+ ?Crossing my fingers..
EDIT - good news:@unknownuser said:
Thanks for your email, good to see that SunTools is useful and helpful during the design process.
As you sure know, SU 2014 uses a new version of Ruby, Iām updating the plug-in, hope it will be ready ASAP. -
please someone give me the password thanx esteban_arq@hotmail.com
SunTool [plugin]
Requires an update!You can make your requests to:
Guedi Capeluto
arrguedi@gmail.comhttp://technion.academia.edu/GuediCapeluto
I have sent the following email requesting an update:
Guedi ,
I was checking in to see if you intended to "update" your SunTool to run on SketchUp 2017? -
That is an educational institution and SunTool, quite possibly, was a project of some sorts of his. I wouldn't hold my breath, although I do agree that it would be good to see the tool updated.
